I recently installed the Cuda Toolkit 3.2.16 for 64bit Ubuntu 10.04 on my machine that is running 10.10 with a GeForce GTX 260 card. I was able to install and compile SDK examples fine. On running deviceQuery it passes:
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: “GeForce GTX 260”
CUDA Driver Version: 3.20
CUDA Runtime Version: 3.20
CUDA Capability Major/Minor version number: 1.3
Total amount of global memory: 1878327296 bytes
Multiprocessors x Cores/MP = Cores: 24 (MP) x 8 (Cores/MP) = 192 (Cores)
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 256 bytes
Clock rate: 1.08 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Concurrent kernel execution: No
Device has ECC support enabled: No
Device is using TCC driver mode: No
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 3.20, CUDA Runtime Version = 3.20, NumDevs = 1, Device = GeForce GTX 260
PASSED
Press to Quit…
but running bandwithTest fails with:
./bandwidthTest Starting…
Running on…
Device 0: GeForce GTX 260
Quick Mode
bandwidthTest.cu(598) : cudaSafeCall() Runtime API error : all CUDA-capable devices are busy or unavailable.
Running matrixMul gives the same busy/unavailable error. I then ran matrixMulDrv to check the error code and got an unknown:
./matrixMulDrv
[ matrixMulDrv (Driver API) ]
Using CUDA Device [0]: GeForce GTX 260
GPU Device has SM 1.3 compute capability
64-bit Memory Address: NO
cuSafeCallNoSync() Driver API error = 0999 from file <matrixMulDrv.cpp>, line 89.
I tried drivers 260.19.36 and 260.19.26.
Does anybody know what problem I might be having? Is it just not possible to run the toolkit designed for 10.04 on 10.10?
Thanks for any help!
