Dear All,
I got installed a 2 NVIDIA tesla M60 and I got the right PASSED test from deviceQuery, see logs below,
still when I launch the bandwidthTest i got the follwoing error:
[CUDA Bandwidth Test] - Starting…
Running on…
Device 0: Tesla M60
Quick Mode
CUDA error at bandwidthTest.cu:730 code=46(cudaErrorDevicesUnavailable) “cudaEventCreate(&start)”
any idea hot to solve this ?
Thanks,
Antonio
Logs:
Linux s-jrciprhpc103p 3.10.0-957.5.1.el7.x86_64 #1 SMP Fri Feb 1 14:54:57 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 418.39 Sat Feb 9 19:19:37 CST 2019
GCC version: gcc version 4.8.5 20150623 (Red Hat 4.8.5-36) (GCC)
./deviceQuery
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 4 CUDA Capable device(s)
Device 0: “Tesla M60”
CUDA Driver Version / Runtime Version 10.1 / 10.1
CUDA Capability Major/Minor version number: 5.2
Total amount of global memory: 8129 MBytes (8524136448 bytes)
(16) Multiprocessors, (128) CUDA Cores/MP: 2048 CUDA Cores
GPU Max Clock rate: 1178 MHz (1.18 GHz)
Memory Clock rate: 2505 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 2097152 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: No
Supports Cooperative Kernel Launch: No
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 131 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: “Tesla M60”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 132 / 0
Compute Mode:
Device 2: “Tesla M60”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 195 / 0
Compute Mode:
Device 3: “Tesla M60”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 196 / 0
Compute Mode:
Peer access from Tesla M60 (GPU0) → Tesla M60 (GPU1) : Yes
Peer access from Tesla M60 (GPU0) → Tesla M60 (GPU2) : No
Peer access from Tesla M60 (GPU0) → Tesla M60 (GPU3) : No
Peer access from Tesla M60 (GPU1) → Tesla M60 (GPU0) : Yes
Peer access from Tesla M60 (GPU1) → Tesla M60 (GPU2) : No
Peer access from Tesla M60 (GPU1) → Tesla M60 (GPU3) : No
Peer access from Tesla M60 (GPU2) → Tesla M60 (GPU0) : No
Peer access from Tesla M60 (GPU2) → Tesla M60 (GPU1) : No
Peer access from Tesla M60 (GPU2) → Tesla M60 (GPU3) : Yes
Peer access from Tesla M60 (GPU3) → Tesla M60 (GPU0) : No
Peer access from Tesla M60 (GPU3) → Tesla M60 (GPU1) : No
Peer access from Tesla M60 (GPU3) → Tesla M60 (GPU2) : Yes
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.1, CUDA Runtime Version = 10.1, NumDevs = 4
Result = PASS
