I compile under cuda-5.5 w/nvcc some application which worked under cuda-4. But
now under cuda-5.5 I obtained the message about error:
streamdp_orig.cu:26:26: fatal error: cutil_inline.h: No such file or directory
compilation terminated.
How should I correct the situation (*cu source ?)
Mikhail
cesarcx
2
Thanks !
The problem is that I can’t find cutil_inline.h in Samples and cuda 5.5 itself ! :
c6ws3:~/NVIDIA_CUDA-5.5_Samples/NVIDIA_CUDA-5.5_Samples/common/inc # ls
cuda_drvapi_dynlink.c GL helper_math.h nvQuaternion.h rendercheck_d3d11.h
drvapi_error_string.h helper_cuda_drvapi.h helper_string.h nvShaderUtils.h rendercheck_d3d9.h
dynlink helper_cuda_gl.h helper_timer.h nvVector.h rendercheck_gl.h
dynlink_d3d10.h helper_cuda.h multithreading.h paramgl.h timer.h
dynlink_d3d11.h helper_functions.h nvMath.h param.h
exception.h helper_image.h nvMatrix.h rendercheck_d3d10.h
c6ws3:~/NVIDIA_CUDA-5.5_Samples/NVIDIA_CUDA-5.5_Samples/common/inc # grep -R cutil *
The output is empty !
I don’t find cutil_inline.h in cuda-5.5 itself :-(
Mikhail
