CUDA 9.0 with caffe, error: /usr/local/cuda/include/crt/common_functions.h:64:24: error: token ""__CUDACC_VER__ is no longer supported. Use __CUDACC_VER_MAJOR__, __CUDACC_VER_MINOR__, and __CUDACC_VER_BUILD__ instead."" is not valid i
I installed CUDA 9.0 in my system (GeForce 1070).
NVRM version: NVIDIA UNIX x86_64 Kernel Module.
NVIDIA-SMI 384.130
Driver Version: 384.130
cudnn: 7.5.0
gcc: 5.5.0
Then I got those errors as follows when I ran make inside a caffe code dir.
I have no idea how to solve this problom. Any help would be welcome.
NVCC src/caffe/util/im2col.cu
In file included from /usr/local/cuda/include/common_functions.h:50:0,
                 from /usr/local/cuda/include/cuda_runtime.h:115,
                 from <command-line>:0:
/usr/local/cuda/include/crt/common_functions.h:64:24: error: token ""__CUDACC_VER__ is no longer supported.  Use __CUDACC_VER_MAJOR__, __CUDACC_VER_MINOR__, and __CUDACC_VER_BUILD__ instead."" is not valid in preprocessor expressions
 #define __CUDACC_VER__ "__CUDACC_VER__ is no longer supported.  Use __CUDACC_VER_MAJOR__, __CUDACC_VER_MINOR__, and __CUDACC_VER_BUILD__ instead."
Makefile:598: recipe for target '.build_release/cuda/src/caffe/util/im2col.o' failed
make: *** [.build_release/cuda/src/caffe/util/im2col.o] Error 1
Best Regards,
Amy
