~/caffe/build$ make -j"$(nproc)"
[ 4%] Built target proto
[ 4%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile.dir/util/cuda_compile_generated_math_functions.cu.o
[ 4%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile.dir/solvers/cuda_compile_generated_adam_solver.cu.o
[ 4%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile.dir/solvers/cuda_compile_generated_nesterov_solver.cu.o
[ 4%] Building NVCC (Device) object src/caffe/CMakeFiles/cuda_compile.dir/solvers/cuda_compile_generated_sgd_solver.cu.o
nvcc fatal : Unsupported gpu architecture 'compute_20'
CMake Error at cuda_compile_generated_adam_solver.cu.o.cmake:207 (message):
Error generating
/home/reid/caffe/build/src/caffe/CMakeFiles/cuda_compile.dir/solvers/./cuda_compile_generated_adam_solver.cu.o
src/caffe/CMakeFiles/caffe.dir/build.make:77: recipe for target 'src/caffe/CMakeFiles/cuda_compile.dir/solvers/cuda_compile_generated_adam_solver.cu.o' failed
make[2]: *** [src/caffe/CMakeFiles/cuda_compile.dir/solvers/cuda_compile_generated_adam_solver.cu.o] Error 1
make[2]: *** Waiting for unfinished jobs....
CMake Error at cuda_compile_generated_nesterov_solver.cu.o.cmake:207 (message):
Error generating
/home/reid/caffe/build/src/caffe/CMakeFiles/cuda_compile.dir/solvers/./cuda_compile_generated_nesterov_solver.cu.o
src/caffe/CMakeFiles/caffe.dir/build.make:63: recipe for target 'src/caffe/CMakeFiles/cuda_compile.dir/solvers/cuda_compile_generated_nesterov_solver.cu.o' failed
make[2]: *** [src/caffe/CMakeFiles/cuda_compile.dir/solvers/cuda_compile_generated_nesterov_solver.cu.o] Error 1
CMake Error at cuda_compile_generated_sgd_solver.cu.o.cmake:207 (message):
Error generating
/home/reid/caffe/build/src/caffe/CMakeFiles/cuda_compile.dir/solvers/./cuda_compile_generated_sgd_solver.cu.o
src/caffe/CMakeFiles/caffe.dir/build.make:70: recipe for target 'src/caffe/CMakeFiles/cuda_compile.dir/solvers/cuda_compile_generated_sgd_solver.cu.o' failed
make[2]: *** [src/caffe/CMakeFiles/cuda_compile.dir/solvers/cuda_compile_generated_sgd_solver.cu.o] Error 1
CMake Error at cuda_compile_generated_math_functions.cu.o.cmake:207 (message):
Error generating
/home/reid/caffe/build/src/caffe/CMakeFiles/cuda_compile.dir/util/./cuda_compile_generated_math_functions.cu.o
src/caffe/CMakeFiles/caffe.dir/build.make:476: recipe for target 'src/caffe/CMakeFiles/cuda_compile.dir/util/cuda_compile_generated_math_functions.cu.o' failed
make[2]: *** [src/caffe/CMakeFiles/cuda_compile.dir/util/cuda_compile_generated_math_functions.cu.o] Error 1
CMakeFiles/Makefile2:272: recipe for target 'src/caffe/CMakeFiles/caffe.dir/all' failed
make[1]: *** [src/caffe/CMakeFiles/caffe.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
Was trying to install Caffe so I could startup DIGITS for my Jetson TX2 and this error occurred. I followed the instructions of GitHub’s 2 Days to a Demo.
I have Ubuntu 16.04. CUDA 9.0. cuDNN 7.1.4
