can i use cuda on Suse 11.0?
OpenSUSE 11.0 is not currently supported. It will be supported in the next release.
If this is your first time using CUDA, you’d likely be better using a supported Linux distribution so that any problems you run into aren’t due to incompatibilities (which do exist).
So there is no way to use CUDA with SUSE 11.0 at this point ?
