I get this error when compiling my CUDA code:
error: identifier "float16_t" is undefined
Yet. in the CUDA manual here:
it says that the float16 data type is the most optimal one to use for Compute Capability 5.3 (I.e. Jetson Nano).
How the heck do I use float16 in my code??
The manual indicates 16-bit floating point arithmetic is available. It doesn’t say that the name of the type is float16_t.
Take a look here. And there are other forum questions discussing use of fp16 as well.
And be sure to compile for the architecture you are running on (-arch=sm_53)
Thanks a lot. If only the documents used the correct nomenclature.
system
Closed
4
