Cuda, cudnn, pip, torch version for Isaacgym?
I installed cuda 11.3, cudnn 8.2.1, pip 20.3.1 ~ 22.1.2, torch 1.10.0+cu113.
joint_monkey.py test was OK, but train.py test has some error.(RuntimeError: Error building extension ‘gymtorch’)
Therefore i want to know optimal version of each program for Isaacgym.
Thank you
I am facing the same error. Do you have any updates on the error .(RuntimeError: Error building extension ‘gymtorch’)?
I’m getting the same error with Isaac Gym Preview Release 4. Are there any updates on this?
Hi, can you provide a full minimum working example with all the complete installation steps you followed, so that we can reproduce the error?
Hi I am facing an error that I am not sure if it is related to this one. The pose is here:
IsaacGymEnv task run issue
Since I used
conda list -f pytorch
to find the required CUDA and cuDNN versions, I am currently using CUDA 11.1 and cuDNN 8.0.5 on a Driver version of 525.89. Could you please provide some information on this? If you require more information please let me know! Thank you
