Some cuda related issue
Please help to rectify
Ubuntu18.04 or 20.04?
ubuntu 18.04
Did you see this?
Yes, I checked that part. Issue is explained by @kellyg in the last comment but how to rectify is not clearly mentioned.
Are you using a virtual machine?
No. In fact, I am using the first part of documentation file i.e. installing in existing python environment.
Are you trying out Preview3?
nvidia-smi doesn’t work either, right?
yes, I used this link Isaac Gym - Preview Release | NVIDIA Developer
output of nvidia-smi Failed to initialize NVML: Driver/library version mismatch
Do you have the following settings?
Driver Version: 495.29.05 CUDA Version: 11.5
It was after getting the first error(of which I attached the screenshot), I used sudo apt-get cuda
I am installing the cuda as per the toolkit
I installed the appropriate toolkit and rebooted the computer. It worked! Thanks a lot!
