I just installed issac gym via anaconda in ubuntu 20.04 (wsl2)
and I get this error when I tried to run the example joint_monkey.py
*** Warning: failed to preload CUDA lib
*** Warning: failed to preload PhysX libs
Importing module ‘gym_37’ (/home/ranat/issacgym/python/isaacgym/_bindings/linux-x86_64/gym_37.so)
[Error] [carb] [Plugin: libcarb.gym.plugin.so] Could not load the dynamic library from /home/ranat/issacgym/python/isaacgym/_bindings/linux-x86_64/libcarb.gym.plugin.so. Error: libcuda.so.1: cannot open shared object file: No such file or directory
[Warning] [carb] Potential plugin preload failed: /home/ranat/issacgym/python/isaacgym/_bindings/linux-x86_64/libcarb.gym.plugin.so
Setting GYM_USD_PLUG_INFO_PATH to /home/ranat/issacgym/python/isaacgym/_bindings/linux-x86_64/usd/plugInfo.json
[Error] [carb] Failed to acquire interface: [carb::gym::Gym v0.1], by client: carb.gym.python.gym_37 (plugin name: (null))
File “joint_monkey.py”, line 59, in
gym = gymapi.acquire_gym()
RuntimeError: Failed to acquire interface: carb::gym::Gym (pluginName: nullptr)
DDPG7
May 20, 2021, 10:08am
2
I hope it works with wsl2 as soon as possible
Hi @DDPG7 ,
Isaac Gym doesn’t support wsl2 because of driver limitations. Is using Windows a hard requirement for you?
DDPG7
August 24, 2021, 5:16am
4
No.
But the standard OS for my company is Windows. I can’t connect my Linux PC to the company networks.
I also get such problem with my ubuntu 20.04, and it is not wsl. Why?
@vmakoviychuk Is there any intention to support Isaac Gym in Windows 11 + WSL2 which has full CUDA support?
kaykay
October 25, 2021, 1:14am
7
I am facing the same error in Ubuntu 20.04 LTS as well. I am just using a virtual machine to run the ubuntu.
Please, help us out with this.
DDPG7
October 25, 2021, 1:34am
8
Hi
It does not work as a specification in a virtual environment.
2021年10月25日(月) 10:15 kaykay via NVIDIA Developer Forums <nvidia@discoursemail.com >:
kaykay
October 25, 2021, 2:06am
10
I see people using ubuntu 20.04 also facing this as pointed out by @liming18 . So, not sure if is really due to the virtual environment. Hopefully, we hear something soon from the NVIDIA team.
DDPG7
October 25, 2021, 2:21am
11
The first thing to check is whether the driver version is correct. I also have the experience of changing the driver and doing well.
However, if you were using WSL etc., you will not be able to access the GPU.
2021年10月25日(月) 11:07 kaykay via NVIDIA Developer Forums <nvidia@discoursemail.com >:
Check if your PC has an Nvidia GPU
I use docker in WSL2 Ubuntu 20.04 and it finally works out.
cd isaacgym/docker
bash build.sh
bash run.sh
and clone the IsaacGymEnvs ,follow the README.md
because I don’t have a display, so I set headless=True in the docker
python train.py task=Ant headless=True
I was also facing similar issues. Finally I figured out in my case it is because of a conflict with the SDF library in SimNet. Check it out here. Potential conflict between Isaac Gym and Modulus (SimNet)
I had the exact same error code ! After some research i found this Isaac Gym test python example error - #6 by DDPG7
After setting up the Cuda Toolkit i had no issues anymore !
This may be a niche solution, but I got this error when I tried to copy the Isaac Gym code from one machine to another - it worked on the original machine but the second machine was giving me this error, both similar machines with Ubuntu 20.04. All I did was download a fresh version from NVIDIA onto the new machine, re-ran the install and it worked.
rzma
January 29, 2023, 1:50pm
18
Hi, I had the same problem with ubuntu 18.04
this could solve it.
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:‘/path to your conda/envs/your_env/lib’
I used docker WSL 2, when running the examples, the UI window is blur:
after few seconds, the window quit with Segmentation fault
same problem with you, have you solved it?
