ksterx
August 12, 2021, 8:42am
#1
I downloaded isaacgym, and I ran the code “joint_monkey.py” on the Ubuntu Terminal .
But in my enviroment, I got an error message:
root@d967d924ca56:/opt/isaacgym/python/examples# python joint_monkey.py
Importing module 'gym_38' (/opt/isaacgym/python/isaacgym/_bindings/linux-x86_64/gym_38.so)
Setting GYM_USD_PLUG_INFO_PATH to /opt/isaacgym/python/isaacgym/_bindings/linux-x86_64/usd/plugInfo.json
WARNING: Forcing CPU pipeline.
Not connected to PVD
+++ Using GPU PhysX
Physics Engine: PhysX
Physics Device: cuda:0
GPU Pipeline: disabled
[Error] [carb.windowing-glfw.plugin] GLFW initialization failed.
[Error] [carb.windowing-glfw.plugin] GLFW window creation failed!
[Error] [carb.gym.plugin] Failed to create Window in CreateGymViewerInternal
*** Failed to create viewer
I built my environment with docker in docker
folder with bash build.sh
and bash run.sh
FYI
OS: Ubuntu 20.04
Nvidia Driver: 470.57.02
GPU: RTX 3070
Any idea to solve this?
Thank you.
kellyg
August 16, 2021, 8:01pm
#2
Hi @ksterx ,
With the default docker build and run scripts shipped in Isaac Gym, we do not support running in docker with the viewer. You can try adding the --headless
flag on examples that support headless mode to run without the viewer. Alternatively, you can give this docker run script a try (it’s not well tested yet) to see if you can get the viewer running in docker. run.sh (201 Bytes)
kellyg:
i also have this problem, i only use conda environment.
OS: Ubuntu 20.04
Nvidia Driver: 495.44
GPU: RTX 3090
If have any solutions to solve this?
Thank you.
Hello, i met same problem as yours. Have you ever solved it yet?
Hi,I also meet a similar problem when I ran the Isaac Sim container follow this:https://github.com/NVIDIA-Omniverse/IsaacSim-dockerfiles ,the error is shown like below:
OS: Mint 21
Nvidia Driver: 510.108.03
GPU: RTX 2060 Max-P
