When I tried the python example joint_monkey.py I got the error message below.
It’s on Ubuntu 20.04, RTX 2070, no docker or something like that. The GPU works when using PyTorch. The smi results are also below.
How do I enable the GPU pipeline?
Then there are some subsequent problems but I assume those follow from this.
Grateful for your help!
(rlgpu) karl@omen:~$ python apps/isaacgym/python/examples/joint_monkey.py
Importing module ‘gym_37’ (/home/karl/apps/isaacgym/python/isaacgym/_bindings/linux-x86_64/gym_37.so)
Setting GYM_USD_PLUG_INFO_PATH to /home/karl/apps/isaacgym/python/isaacgym/_bindings/linux-x86_64/usd/plugInfo.json
WARNING: Forcing CPU pipeline.
Not connected to PVD
+++ Using GPU PhysX
Physics Engine: PhysX
Physics Device: cuda:0
GPU Pipeline: disabled
Loading asset ‘mjcf/nv_humanoid.xml’ from ‘…/…/assets’
[Error] [carb.gym.plugin] *** Failed to load ‘…/…/assets/mjcf/nv_humanoid.xml’
[Error] [carb.gym.plugin] *** Failed to load ‘mjcf/nv_humanoid.xml’ from ‘…/…/assets’
Creating 36 environments
File “apps/isaacgym/python/examples/joint_monkey.py”, line 214, in
print(“Animating DOF %d (‘%s’)” % (current_dof, dof_names[current_dof]))
IndexError: list index out of range
(rlgpu) karl@omen:~$ nvidia-smi
Tue Mar 22 23:48:04 2022
| NVIDIA-SMI 470.63.01 Driver Version: 470.63.01 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 On | N/A |
| 30% 34C P8 23W / 210W | 1065MiB / 7948MiB | 2% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 899 G /usr/lib/xorg/Xorg 102MiB |
| 0 N/A N/A 1599 G /usr/lib/xorg/Xorg 512MiB |
| 0 N/A N/A 1736 G /usr/bin/gnome-shell 163MiB |
| 0 N/A N/A 13774 G …750682524097145037,131072 179MiB |
| 0 N/A N/A 27981 G …AAAAAAAAA= --shared-files 94MiB |
