2Day I tried Linux x64 260.1929 driver released on December 13, 2010 (the only one available for GTX 570) - it’s gives errors on each WU. Time-wise it’s different - from 4 secs to 3+ minutes.
Which driver should I try? I’m ready to be a beta-tester External Image
There aren’t any drivers with the fix available yet, I think we only fixed it for our internal builds on Friday or something like that. It’ll take a little while for that to percolate out.
Would anyone know if either of these updates fixes a NV-GLX freeze/halt issue I had with (upgrade or fresh installs) F13 and F14 when trying to install 260.19/CUDA 3.2 from 256.xx/CUDA 3.1? The failed effort and every attempted modification over weeks is well documented in the OS section of the forums so I won’t detail it further here. TIA, V.
Working fine with PrimeGrid actually doesn’t mean the problem is fixed. I got so tired of telling users to downgrade to 256.53 that I added a work-around so even the buggy drivers will work fine, just a bit slower.
This means the only indication you’d get if the bug was fixed is if your work started running faster. If the 270 drivers are slower, that doesn’t sound good! External Image
I’ve got GTX570 so I do not have that luxury to downgrade further then 260.1929 though…
I tried kernels 2.6.32.24 through 2.6.32.27 for both drivers (I know that’s sounds weird, but there is difference in performance for combination kernel/driver). For example, for my previous GTX275 the fastest combination was 2.6.32.24 and 190.53
For sure - 270.18 is slower then 260.1936. But that’s OK for now - it’s beta only and the very 1st drivers with xserver 1.10 support. 2-3 releases down the road and it will be just fine :-)
What I’m happy about is that I can get back on linux. Home, sweet home :-)
Game is not over yet, 260.1936 for linux are definitely slower then 266.58 for windows.
on windows it takes 623-624 sec for one WU (work unit) and on linux 660-666 secs and some WUs are 722-723 sec. It’s not application problem…
I wonder if some1 will take care about this issue…
