This is an issue I’ve been attempting to understand and find a work around for a while now on my jetson Nano 2gb.
I’ve modified the xorg file to include the option “Interactive” “0”
I’ve gone into sysctl and turned
watchdog=0
nmi_watchdog=0
watchdog_soft=0
watchdog_thresh=0
I’ve attempted to remove rtkit that comes preinstalled in the image.
I’ve attempted to run in init 3 to avoid the use of xorg
I honestly do not know what else to try, In the xorg log files I do find an error. this is the file.
Any suggestion, clarity, or direction you could provide me would be appreciated.
[ 7.107]
X. Org X Server 1.19.6
Release Date: 2017-12-20
[ 7.107] X Protocol Version 11, Revision 0
[ 7.107] Build Operating System: Linux 4.15.0-124-generic aarch64 Ubuntu
[ 7.107] Current Operating System: Linux bowl 4.9.201-tegra #1 SMP PREEMPT Fri Jan 15 14:41:02 PST 2021 aarch64
[ 7.107] Kernel command line: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 7.108] Build Date: 30 November 2020 08:05:15PM
[ 7.108] xorg-server 2:1.19.6-1ubuntu4.8 (For technical support please see
[ 7.108] Current version of pixman: 0.34.0
[ 7.108] Before reporting problems, check
to make sure that you have the latest version.
[ 7.108] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 7.108] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Feb 24 04:29:03 2021
[ 7.145] (==) Using config file: “/etc/X11/xorg.conf”
[ 7.145] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 7.159] (==) No Layout section. Using the first Screen section.
[ 7.159] (==) No screen section available. Using defaults.
[ 7.159] () |–>Screen “Default Screen Section” (0)
[ 7.159] () | |–>Monitor “”
[ 7.160] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 7.160] () | |–>Device “Tegra0”
[ 7.160] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 7.160] (==) Automatically adding devices
[ 7.160] (==) Automatically enabling devices
[ 7.160] (==) Automatically adding GPU devices
[ 7.160] (==) Automatically binding GPU devices
[ 7.160] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 7.182] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 7.182] Entry deleted from font path.
[ 7.182] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 7.182] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 7.193] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 7.193] Entry deleted from font path.
[ 7.193] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 7.193] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 7.193] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 7.193] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 7.193] (II) Loader magic: 0x555b420010
[ 7.193] (II) Module ABI versions:
[ 7.193] X .Org ANSI C Emulation: 0.4
[ 7.193] X .Org Video Driver: 23.0
[ 7.193] X .Org XInput driver : 24.1
[ 7.193] X .Org Server Extension : 10.0
[ 7.195] (++) using VT number 7[ 7.195] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 7.196] (II) no primary bus or device found
[ 7.196] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 7.196] (II) “glx” will be loaded by default.
[ 7.196] (II) LoadModule: “extmod”
[ 7.196] (II) Module “extmod” already built-in
[ 7.196] (II) LoadModule: “glx”
[ 7.273] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 7.394] (II) Module glx: vendor=“X .Org Foundation”
[ 7.394] compiled for 1.19.6, module version = 1.0.0
[ 7.394] ABI class: X .Org Server Extension, version 10.0
[ 7.394] (II) LoadModule: “nvidia”
[ 7.395] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 7.466] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 7.466] compiled for 4.0.2, module version = 1.0.0
[ 7.466] Module class: X .Org Video Driver
[ 7.485] (II) NVIDIA dlloader X Driver 32.5.0 Release Build (integ_stage_rel) (buildbrain@mobile-u64-4415) Fri Jan 15 14:44:38 PST 2021
[ 7.485] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 7.486] (WW) Falling back to old probe method for NVIDIA
[ 7.486] (II) Loading sub module “fb”
[ 7.486] (II) LoadModule: “fb”
[ 7.487] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 7.501] (II) Module fb: vendor=“X .Org Foundation”
[ 7.501] compiled for 1.19.6, module version = 1.0.0
[ 7.501] ABI class: X .Org ANSI C Emulation, version 0.4
[ 7.501] (II) Loading sub module “wfb”
[ 7.501] (II) LoadModule: “wfb”
[ 7.501] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 7.533] (II) Module wfb: vendor=“X .Org Foundation”
[ 7.533] compiled for 1.19.6, module version = 1.0.0
[ 7.533] ABI class: X .Org ANSI C Emulation, version 0.4
[ 7.533] (II) Loading sub module “ramdac”
[ 7.533] (II) LoadModule: “ramdac”
[ 7.533] (II) Module “ramdac” already built-in
[ 7.534] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 7.535] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 7.535] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 7.535] (==) NVIDIA(0): RGB weight 888
[ 7.535] (==) NVIDIA(0): Default visual is TrueColor
[ 7.535] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.535] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 7.535] () NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
[ 7.535] () NVIDIA(0): Option “Interactive” “false”
[ 7.535] () NVIDIA(0): Enabling 2D acceleration
[ 7.535] (II) Loading sub module “glxserver_nvidia”
[ 7.535] (II) LoadModule: “glxserver_nvidia”
[ 7.535] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 7.799] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 7.799] compiled for 4.0.2, module version = 1.0.0
[ 7.799] Module class: X .Org Server Extension
[ 7.799] (II) NVIDIA GLX Module 32.5.0 Release Build (integ_stage_rel) (buildbrain@mobile-u64-4415) Fri Jan 15 14:43:01 PST 2021
[ 7.840] (–) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 7.840] (–) NVIDIA(0): DFP-0
[ 7.841] (II) NVIDIA(0): NVIDIA GPU NVIDIA Tegra X1 (nvgpu) (GM20B) at SoC (GPU-0)
[ 7.841] (–) NVIDIA(0): Memory: 2027380 kBytes
[ 7.841] (–) NVIDIA(0): VideoBIOS:
[ 7.841] (==) NVIDIA(0):
[ 7.841] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 7.841] (==) NVIDIA(0): will be used as the requested mode.
[ 7.841] (–) NVIDIA(0): No enabled display devices found; starting anyway because
[ 7.841] (–) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 7.841] (II) NVIDIA(0): Validated MetaModes:
[ 7.841] (II) NVIDIA(0): “NULL”
[ 7.841] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 7.841] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 7.841] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 7.841] (–) Depth 24 pixmap format is 32 bpp
[ 7.841] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[ 7.841] (II) NVIDIA: access.
[ 7.843] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 7.844] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 7.844] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 7.844] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 7.844] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 7.844] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 7.844] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 7.844] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 7.844] (II) NVIDIA(0): Config Options in the README.
[ 7.895] (II) NVIDIA(0): Setting mode “NULL”
[ 7.899] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 7.899] (==) NVIDIA(0): Backing store enabled
[ 7.899] (==) NVIDIA(0): Silken mouse enabled
[ 7.899] (==) NVIDIA(0): DPMS enabled
[ 7.899] (II) Loading sub module “dri2”
[ 7.899] (II) LoadModule: “dri2”
[ 7.899] (II) Module “dri2” already built-in
[ 7.899] (II) NVIDIA(0): [DRI2] Setup complete
[ 7.899] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 7.900] (–) RandR disabled
[ 7.907] (II) SELinux: Disabled on system
[ 7.908] (II) Initializing extension GLX
[ 7.908] (II) Indirect GLX disabled.
[ 8.097] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=3 (/dev/input/event0)
[ 8.097] (II) No input driver specified, ignoring this device.
[ 8.097] (II) This device may have been added with another device file.
[ 8.098] (II) config/udev: Adding input device gpio-keys (/dev/input/event1)
[ 8.098] () gpio-keys: Applying InputClass “libinput keyboard catchall”
[ 8.098] (II) LoadModule: “libinput”
[ 8.098] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 8.112] (II) Module libinput: vendor=“X .Org Foundation”
[ 8.112] compiled for 1.19.6, module version = 0.27.1
[ 8.112] Module class: X .Org XInput Driver
[ 8.112] ABI class: X .Org XInput driver, version 24.1
[ 8.113] (II) Using input driver ‘libinput’ for ‘gpio-keys’
[ 8.113] () gpio-keys: always reports core events
[ 8.113] () Option “Device” “/dev/input/event1”
[ 8.113] () Option “_source” “server/udev”
[ 8.114] (II) event1 - gpio-keys: is tagged by udev as: Keyboard
[ 8.114] (II) event1 - gpio-keys: device is a keyboard
[ 8.114] (II) event1 - gpio-keys: device removed
[ 8.136] () Option “config_info” “udev:/sys/devices/gpio-keys/input/input1/event1”
[ 8.136] (II) XINPUT: Adding extended input device “gpio-keys” (type: KEYBOARD, id 6)
[ 8.136] () Option “xkb_model” “pc105”
[ 8.136] () Option “xkb_layout” “us”
[ 8.137] (II) event1 - gpio-keys: is tagged by udev as: Keyboard
[ 8.137] (II) event1 - gpio-keys: device is a keyboard
[ 26.105] (II) config/udev: Adding input device iClever IC-BK05 Keyboard (/dev/input/event2)
[ 26.105] () iClever IC-BK05 Keyboard: Applying InputClass “libinput keyboard catchall”
[ 26.105] (II) Using input driver ‘libinput’ for ‘iClever IC-BK05 Keyboard’
[ 26.105] () iClever IC-BK05 Keyboard: always reports core events
[ 26.105] () Option “Device” “/dev/input/event2”
[ 26.105] () Option “_source” “server/udev”
[ 26.107] (II) event2 - iClever IC-BK05 Keyboard: is tagged by udev as: Keyboard
[ 26.107] (II) event2 - iClever IC-BK05 Keyboard: device is a keyboard
[ 26.107] (II) event2 - iClever IC-BK05 Keyboard: device removed
[ 26.132] () Option “config_info” “udev:/sys/devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1:1.0/bluetooth/hci0/hci0:1/0005:04E8:7021.0001/input/input2/event2”
[ 26.132] (II) XINPUT: Adding extended input device “iClever IC-BK05 Keyboard” (type: KEYBOARD, id 7)
[ 26.132] () Option “xkb_model” “pc105”
[ 26.132] (**) Option “xkb_layout” “us”
[ 26.132] (WW) Option “xkb_variant” requires a string value
[ 26.132] (WW) Option “xkb_options” requires a string value
[ 26.134] (II) event2 - iClever IC-BK05 Keyboard: is tagged by udev as: Keyboard
[ 26.134] (II) event2 - iClever IC-BK05 Keyboard: device is a keyboard
