Cuda kernel
Software Version
DRIVE OS 6.0.10.0
[1] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[1] Linux
QNX
other
Hardware Platform
[1] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
2.1.0
[1] other
Host Machine Version
other
Issue Description
Hi team, I want to know if driveworks samples run on GPU and if they are cuda based then why can’t I see cuda kernel defined in the code?
I could see some memory transfer using CUDA API.
I am new to CUDA and I started exploring it but I got this doubt.
Dear @akshay.tupkar,
The DW APIs which makes use of GPU, uses CUDA kernels internally.
If you are looking for CUDA kernel usage in a DW sample, please see DriveWorks SDK Reference: Image Capture Sample .
Please check generateImage() function in /usr/local/driveworks/samples/src/image/image_common/utils.cu
Thanks @SivaRamaKrishnaNV
