Getting error while executing Driveworks samples
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
Tried executing driveworks samples on the host machine getting following error.
adascoe@adascoe-Nuvo-7000-Series:/usr/local/driveworks/bin$ ./sample_camera_replay
[21-04-2023 10:58:47] Platform: Detected Generic x86 Platform
[21-04-2023 10:58:47] TimeSource: monotonic epoch time offset is 1682053790223472
[21-04-2023 10:58:47] Platform: number of GPU devices detected 1
[21-04-2023 10:58:47] Platform: currently selected GPU device discrete ID 0
[21-04-2023 10:58:47] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-4.0/bin/data/’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-4.0/bin/data/[.pak]’
[21-04-2023 10:58:47] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-4.0/bin/…/data
[21-04-2023 10:58:47] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-4.0/bin/…/data/’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-4.0/bin/…/data/[.pak]’
[21-04-2023 10:58:47] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-4.0/data
[21-04-2023 10:58:47] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-4.0/data/’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-4.0/data/[.pak]’
[21-04-2023 10:58:47] SDK: No resources(.pak) mounted, some modules will not function properly
[21-04-2023 10:58:47] Initialize DriveWorks SDK v4.0.0
[21-04-2023 10:58:47] Release build with GNU 7.4.0 from no-gitversion-build
[21-04-2023 10:58:47] Initialize DriveWorks VisualizationSDK v4.0.0
[21-04-2023 10:58:47] Initialize DriveWorksGL SDK v4.0.0
[21-04-2023 10:58:47] GL-SDK: initialize OpenGL
[21-04-2023 10:58:48] SensorFactory::createSensor() → camera.virtual, video=/usr/local/driveworks-4.0/data/samples/sfm/triangulation/video_0.h264
[21-04-2023 10:58:48] CameraVirtual: defaulting to non SIPL
[21-04-2023 10:58:48] CameraBase: pool size set to 8
[21-04-2023 10:58:48] CameraNVCUVID: no seek table found at /usr/local/driveworks-4.0/data/samples/sfm/triangulation/video_0.h264.seek, seeking is not available.
Camera image with 1280x800 at 30.000000 FPS
[21-04-2023 10:58:48] Context: create, error returned by cudaGLGetDevices. GL interop will be disabled.
[21-04-2023 10:58:48] Driveworks exception thrown: . Line: src/dw/cuda/CudaEventQueue.hpp:105. Error cudaErrorUnknown: unknown error
terminate called after throwing an instance of ‘std::runtime_error’
what(): [2023-04-21 10:58:48] DW Error DW_CUDA_ERROR executing DW function:
dwImageStreamerGL_initialize(&m_image2GL, &from, DW_IMAGE_GL, m_context)
at samples/sensors/camera/camera_replay/main.cpp:141
Aborted (core dumped)
Dear @alksainath.medam,
It seems you have Ampere based GPU. Please check “Hardware prerequisites” at DriveWorks SDK Reference: Getting Started
adascoe@adascoe-Nuvo-7000-Series:~$ nvidia-smi
Fri Apr 21 15:47:24 2023
| NVIDIA-SMI 470.182.03   Driver Version: 470.182.03   CUDA Version: 11.4     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  Tesla T4            Off  | 00000000:01:00.0 Off |                  Off |
| N/A   55C    P8    11W /  70W |      0MiB / 16127MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
This is the GPU I am using and it is of Turing architecture I think.
Can, you please check @SivaRamaKrishnaNV.
Yes it is turing based GPU. Are you running sample on remote session?
I am not running sample on remote session; I am directly running on Ubuntu host.
It seems CUDA isn’t 10.2 which is compatible with DRIVE OS 5.2.6.
Please make sure running samples on a host set up by sdkmanager with DRIVE OS 5.2.6.
