I am running DriveWorks modified-release m7. (Patch over 2.0 to 3.0.5819 for driveav)
Ubuntu 18.04 LTS
GPS RTX2080
When trying to run drivenet sample application, I am getting the following error:
~/test/src/drivenet/drivenet$ ./sample_drivenet --video=/home/jptalledo/highway.h264
[12-03-2022 10:35:58] Platform: Detected Generic x86 Platform
[12-03-2022 10:35:58] TimeSource: monotonic epoch time offset is 1646746384811534
[12-03-2022 10:35:58] Platform: number of GPU devices detected 1
[12-03-2022 10:35:58] Platform: currently selected GPU device discrete ID 0
[12-03-2022 10:35:58] Context::getDataPathFromSelfLocation DATA_ROOT found at: /usr/local/driveworks-3.0/data
[12-03-2022 10:35:58] SDK: Resources mounted from /home/jptalledo/test/_data/
[12-03-2022 10:35:58] Initialize DriveWorks SDK v3.0.5819-experimental
[12-03-2022 10:35:58] Experimental Release build with GNU 7.4.0 from heads/buildbrain-branch-0-ge470818d679
[12-03-2022 10:35:58] Initialize DriveWorks VisualizationSDK v3.0.5819-experimental
[12-03-2022 10:35:58] Initialize DriveWorksGL SDK v3.0.5819-experimental
[12-03-2022 10:35:58] GL-SDK: initialize OpenGL
[12-03-2022 10:35:58] SensorFactory::createSensor() -> camera.virtual, dla=0,dlaEngineNo=0,enableUrgency=0,offscreen=0,precision=fp16,profiling=1,stateless=0,stopFrame=0,useCudaGraph=0,video=/home/jptalledo/highway.h264,isp-mode=yuv444-uint16
[12-03-2022 10:35:58] CameraVirtual: defaulting to non SIPL
[12-03-2022 10:35:58] Driveworks exception thrown: DW_NOT_AVAILABLE: CameraVirtualNVCUVID: only isp-mode yuv420-uint8 is available
**** Stack trace ****
/usr/local/driveworks-3.0/targets/x86_64-Linux/lib/libdriveworks.so.3: dw_9450038259943f6d4a10e2c3a893c970616b81c4()+0x8f [0x7f24f167975f]
/usr/local/driveworks-3.0/targets/x86_64-Linux/lib/libdriveworks.so.3: dw_34419e0daa7e08a43bd9a5a4c6de2e8d26754163()+0xfd1 [0x7f24f1a202e1]
/usr/local/driveworks-3.0/targets/x86_64-Linux/lib/libdriveworks.so.3: dw_e17b3abc802451a65cdbd445a06d069e1627a60c()+0x6ec [0x7f24f19a330c]
/usr/local/driveworks-3.0/targets/x86_64-Linux/lib/libdriveworks.so.3: dw_e36d9610af0f7a65daf1f057675751089fc92ee9()+0x5ed [0x7f24f19a3d0d]
/usr/local/driveworks-3.0/targets/x86_64-Linux/lib/libdriveworks.so.3: dw_92d96c932ebc21693a69a42202fa07a5e2f4e8ef()+0x23 [0x7f24f1b1d0d3]
/usr/local/driveworks-3.0/targets/x86_64-Linux/lib/libdriveworks.so.3: dw_fdb46ec6eb0d354c03ea7c9156c303e49be5a442()+0x4e8 [0x7f24f1b11d68]
/usr/local/driveworks-3.0/targets/x86_64-Linux/lib/libdriveworks.so.3: dwSAL_createSensor()+0x2ea [0x7f24f1b24d9a]
./sample_drivenet: ()+0x296d2 [0x55a867e8e6d2]
./sample_drivenet: ()+0x2c8b7 [0x55a867e918b7]
./sample_drivenet: ()+0xf108 [0x55a867e74108]
./sample_drivenet: ()+0x19684 [0x55a867e7e684]
./sample_drivenet: ()+0x848c [0x55a867e6d48c]
/lib/x86_64-linux-gnu/libc.so.6: __libc_start_main()+0xe7 [0x7f24eea1dc87]
./sample_drivenet: ()+0x87ea [0x55a867e6d7ea]
terminate called after throwing an instance of 'std::runtime_error'
what(): [2022-03-12 10:35:58] DW Error DW_NOT_AVAILABLE executing DW function:
dwSAL_createSensor(&m_sensor, params, m_sal)
at /usr/local/driveworks-3.0/samples/src/framework/SimpleCamera.cpp:87
Aborted (core dumped)
Any ideas what could be happening? Should I upgrade to the latest DW and DriveOS?
