jpvans
March 26, 2022, 10:48pm
#1
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
I am testing the Sensor/Camera_USB sample application and it seems that only supports USB cameras with YUYV 4:2:2 output? I have a camera which supports UYVY and MJPEG.
Just wondering if it is possible to develop a plugin to support UYVY ?
Dear @jpvans ,
Plugin development is not possible for camera. May I know camera details and what error you encounter?
jpvans
March 27, 2022, 6:41pm
#4
I am using a E-ConSystems Camera See3CAM_CU135
The sample application is the following:
jptalledo@CCIDev:~/nvidia_sdk3/src/sensors/camera/camera_usb$ ./sample_camera_usb
[27-03-2022 14:35:36] Platform: Detected Generic x86 Platform
[27-03-2022 14:35:36] TimeSource: monotonic epoch time offset is 1648405858279585
[27-03-2022 14:35:36] Platform: number of GPU devices detected 1
[27-03-2022 14:35:36] Platform: currently selected GPU device discrete ID 0
[27-03-2022 14:35:36] Context::getDataPathFromSelfLocation DATA_ROOT found at: /usr/local/driveworks-3.0/data
[27-03-2022 14:35:36] SDK: Resources mounted from /usr/local/driveworks-3.0/data/
[27-03-2022 14:35:37] TimeSource: monotonic epoch time offset is 1648405858279585
[27-03-2022 14:35:37] Initialize DriveWorks SDK v3.0.5819-experimental
[27-03-2022 14:35:37] Experimental Release build with GNU 7.4.0 from heads/buildbrain-branch-0-ge470818d679
[27-03-2022 14:35:37] Initialize DriveWorks VisualizationSDK v3.0.5819-experimental
[27-03-2022 14:35:37] Initialize DriveWorksGL SDK v3.0.5819-experimental
[27-03-2022 14:35:37] GL-SDK: initialize OpenGL
[27-03-2022 14:35:37] SensorFactory::createSensor() -> camera.usb, device=0,mode=0
[27-03-2022 14:35:37] Driveworks exception thrown: DW_SAL_CANNOT_CREATE_SENSOR: CameraV4L: Could not select appropriate capture settings(Invalid argument)
**** Stack trace ****
/usr/local/driveworks/targets/x86_64-Linux/lib/libdriveworks.so.3: dw_9450038259943f6d4a10e2c3a893c970616b81c4()+0x8f [0x7ff0b693775f]
/usr/local/driveworks/targets/x86_64-Linux/lib/libdriveworks.so.3: dw_51b177af7a62fed1f8025ccc03016576b7c3d6d0()+0xbed [0x7ff0b6cb179d]
/usr/local/driveworks/targets/x86_64-Linux/lib/libdriveworks.so.3: dw_210110e7963074615e869856b33ff0f539a0e83a()+0x34b [0x7ff0b6cb1b9b]
/usr/local/driveworks/targets/x86_64-Linux/lib/libdriveworks.so.3: dw_86390dae6bc1e149e888f8493cace40ee30b4790()+0x23 [0x7ff0b6ddba33]
/usr/local/driveworks/targets/x86_64-Linux/lib/libdriveworks.so.3: dw_fdb46ec6eb0d354c03ea7c9156c303e49be5a442()+0x4e8 [0x7ff0b6dcfd68]
/usr/local/driveworks/targets/x86_64-Linux/lib/libdriveworks.so.3: dwSAL_createSensor()+0x2ea [0x7ff0b6de2d9a]
./sample_camera_usb: ()+0xbe17 [0x557aca5fce17]
./sample_camera_usb: ()+0x11804 [0x557aca602804]
./sample_camera_usb: ()+0x7759 [0x557aca5f8759]
/lib/x86_64-linux-gnu/libc.so.6: __libc_start_main()+0xe7 [0x7ff0b3cdbc87]
./sample_camera_usb: ()+0x79ea [0x557aca5f89ea]
terminate called after throwing an instance of 'std::runtime_error'
what(): [2022-03-27 14:35:37] DW Error DW_SAL_CANNOT_CREATE_SENSOR executing DW function:
dwSAL_createSensor(&m_camera, params, m_sal)
at /usr/local/driveworks/samples/src/sensors/camera/camera_usb/main.cpp:127
Aborted (core dumped)
v4l2 shows:
jptalledo@CCIDev:~/nvidia_sdk3/src/sensors/camera/camera_usb$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘UYVY’
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1920x1080
Size: Discrete 3840x2160
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Size: Discrete 4208x3120
Interval: Discrete 0.111s (9.000 fps)
Interval: Discrete 0.222s (4.500 fps)
Size: Discrete 4096x2160
Interval: Discrete 0.008s (120.000 fps)
Size: Discrete 1920x1440
Interval: Discrete 0.022s (45.000 fps)
Interval: Discrete 0.044s (22.500 fps)
Size: Discrete 2880x2160
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Index : 1
Pixel Format: ‘MJPG’ (compressed)
Dear @jpvans ,
Yes UYVY is not supported. Also, I notice you seems to be using DW 3.0 release which is not part of Devzone release( DRIVE SW 10.0 has DW 2.2)
jpvans
March 28, 2022, 12:08pm
#6
Thanks for confirming. I am using both DW 10 and Nvidia Drive 3.0
