Software Version
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.4.0.7363
Host Machine Version
native Ubuntu 18.04
Hey,
So I’m trying to run some code that uses dwSAL_createSensor, but I’m getting an error.
When I tried using the basic sample_camera executable, I got the following error:
nvidia@tegra-ubuntu:/usr/local/driveworks/bin$ ./sample_camera --rig=/usr/local/driveworks/data/samples/sensors/camera/camera/rig.json
[21-09-2019 06:33:15] Platform: Detected DDPX - Tegra A
[21-09-2019 06:33:15] TimeSource: monotonic epoch time offset is 1569027511212199
[21-09-2019 06:33:15] PTP Time is available from NVPPS Driver
[21-09-2019 06:33:15] Platform: number of GPU devices detected 2
[21-09-2019 06:33:15] Platform: currently selected GPU device discrete ID 0
[21-09-2019 06:33:15] Context::getDataPathFromSelfLocation DATA_ROOT found at: /usr/local/driveworks-3.5/data
[21-09-2019 06:33:15] SDK: No resources(.pak) mounted, some modules will not function properly
[21-09-2019 06:33:15] SDK: Create NvMediaDevice
[21-09-2019 06:33:15] SDK: Create NvMedia2D
[21-09-2019 06:33:15] SDK: use EGL display as provided
[21-09-2019 06:33:15] Initialize DriveWorks SDK v3.5.75
[21-09-2019 06:33:15] Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gc61a9a35bd0 against Drive PDK v5.2.0.0
[21-09-2019 06:33:15] Rig::fromFile: Loading rig file: /usr/local/driveworks/data/samples/sensors/camera/camera/rig.json
[21-09-2019 06:33:15] No valid data file found for camera:sample0 in parameter string: camera-name=SF3324,interface=csi-a,link=0,output-format=processed (using configuration folder /usr/local/driveworks/data/samples/sensors/camera/camera/)
onInitialize: creating camera.gmsl with params: camera-name=SF3324,interface=csi-a,link=0,output-format=processed
[21-09-2019 06:33:15] SensorFactory::createSensor() -> camera.gmsl, camera-name=SF3324,interface=csi-a,link=0,output-format=processed
[21-09-2019 06:33:15] CameraBase: pool size set to 8
[21-09-2019 06:33:15] SensorFactory::createSensor() -> camera.gmsl.master,
libnvsipl_query.so: CNvMCameraModuleInfo.cpp : 76: ParseJson: Could not find matching serializer
libnvsipl_query.so: CNvMDeviceInfoList.cpp : 100: GetCustomCameraModule: Failed to find matching module MAX96712TPG
libnvsipl_query.so: CNvMDeviceBlockInfo.cpp : 156: ParseJson: Failed to find matching camera module
libnvsipl_query.so: CNvMPlatformCfgInfo.cpp : 50: ParseJson: CNvMPlatformCfgInfo::ParseJson failed.
libnvsipl_query.so: CNvMQuery.cpp : 45: ParsePlatformConfig: Failed to parse a PlatformCfg
[21-09-2019 06:33:15] CameraMaster::parseDevBlock Getting device info list.
[21-09-2019 06:33:15] devBlock: 1 Slave = 0 Interface = csi-a Camera_name = SF3324 Link = 0
[21-09-2019 06:33:15] std::exception thrown: std::bad_alloc
terminate called after throwing an instance of 'std::runtime_error'
what(): [2019-09-21 06:33:15] DW Error DW_FAILURE executing DW function:
dwSAL_createSensor(&m_camera[m_totalCameras], paramsClient, m_sal)
at /dvs/git/dirty/gitlab-master_av/dw/sdk/samples/sensors/camera/camera/main.cpp:234
Aborted (core dumped)
Worth to mention that the code worked on DRIVE OS 5.1.9 and driveworks 2.2
Thank you!
