Hello, trying to set up Cuda to work in conjunction with Adobe Premiere Pro as I’m trying to edit with some 4k files and its stuttering to the point of uselessness. I’m running Windows 10, CPU/ i9-9900k, gpu/ Geforce RTX 2080 Ti
Installed Visual Studio 2019 C++ for Desktop
Ran Cuda Toolkit installer and finished
Followed through the quick guide
-ran nbody_vs2019.sin /output showed build succeeded
-ran nbody.exe …
Not sure what to do here as the quick guide just stops with no explanations. Theres a window which runs a never ending particle simulation and then another with some basic info then tells me what my gpu is, that it has a 7.5 capability, and leaves a cmd prompt.
So far, Premiere Pro is showing very little, if any, improvements in performance. (Project settings renderer is set to CUDA)
I went back to the longer installation guide and there are steps not included in the quick guide - 2.5 verify installation. I ran nvcc -V and it checked out. But I have no idea how to build a sample program from VS solution files to run the device query. So I’m pretty much stuck at this point with no way of knowing if everythings running like it should be. I’m really hoping Adobe can perform better than this…
