cuda on fedora 29
I have a GTX 750 running on Fedora 29. I have installed NVIDIA-Linux-x86_64-390.87-patched.run ( from [url]Fedora 36/35/34/33/32 NVIDIA FAQ - If Not True Then False ). (410.78 and 415.13 fail in gnome-display-manager). cuda_10.0.130_410.48_linux.run fails on driver incompatablity. cuda_9.1.85_387.26_linux.run installs and precompiled binaries work, but the Nvidia compiler, nvcc fails because my gcc version in greater than 6. I would like to install cuda 10.0 and run it with nvidia 410 or 415. Is there a patched version of one of these newer drivers or instructions on how to create one? thanks
The solution to make the current drivers work is removing and reinstalling xorg-x11-server 1.20.3-1.fc29
Then cuda 10 should also work. Additional driver patching should be unneccessary.
So, removing and reinstalling xorg-x11-server should make 410.78 driver work unpatched?
Yes. Provided you updated the kernel to the current fedora one.
How to remove and reinstall the xorg?
See this:
[url]https://devtalk.nvidia.com/default/topic/1045859/linux/centos-7-geforce-gt740-unable-to-start-x-server/post/5307199/#5307199[/url]
