I posted this on the Ubuntu forums, but have yet to get a reply so thought I’d see if you guys could help.
I am trying to install the NVIDIA CUDA drivers on a fresh install of Intrepid. The version I am using is NVIDIA-Linux-x86_64-177.73-pkg2.run. It detects that I am using a xen kernel, which from some googling seems related to the xen virtual server. This halts the installer as CUDA apparently doesn’t support the xen kernel. I am, however, totally unaware of running such a kernel (I have never used xen anyway). The kernel I am running is 2.6.27-7-generic .
Logs are below. Any bright ideas? Thanks in advance!
/var/log/nvidia-installer.log :
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sat Nov 8 20:11:47 2008
installer version: 1.0.7
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
precompiled interfaces : true
no ncurses color : false
query latest version : false
OpenGL header files : true
no questions : false
silent : false
no recursion : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : false
no ABI note : false
no RPMs : false
no kernel module : false
force SELinux : default
no X server check : false
no cc version check : false
force tls : (not specified)
force compat32 tls : (not specified)
X install prefix : (not specified)
X library install path : (not specified)
X module install path : (not specified)
OpenGL install prefix : (not specified)
OpenGL install libdir : (not specified)
compat32 install chroot : (not specified)
compat32 install prefix : (not specified)
compat32 install libdir : (not specified)
utility install prefix : (not specified)
utility install libdir : (not specified)
doc install prefix : (not specified)
kernel name : (not specified)
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp mirror : ftp://download.nvidia.com
RPM file list : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 177.73.
-> No precompiled kernel interface was found to match your kernel; would you li
ke the installer to attempt to download a kernel interface for your kernel f
rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: Yes)
-> No matching precompiled kernel interface was found on the NVIDIA ftp site;
this means that the installer will need to compile a kernel interface for
your kernel.
-> Performing CC sanity check with CC="cc".
-> Performing CC version check with CC="cc".
-> Kernel source path: '/lib/modules/2.6.27-7-generic/build'
-> Kernel output path: '/lib/modules/2.6.27-7-generic/build'
-> Performing rivafb check.
-> Performing nvidiafb check.
-> Performing Xen check.
ERROR: The kernel you are installing for is a Xen kernel!
The NVIDIA driver does not currently work on Xen kernels. If
you are using a stock distribution kernel, please install
a variant of this kernel without Xen support; if this is a
custom kernel, please install a standard Linux kernel. Then
try installing the NVIDIA kernel module again.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at www.nvidia.com.
