I saw some posts about the same/similar problem and the suggested solution was to install libgl1-mesa-dev or mesa-common-dev. I’m sure the installation will solve the problem on Debian or Ubuntu distros. However, I’m using a Redhat Enterprise Linux 5.3 Client, and I haven’t found libgl1-mesa-dev or mesa-common-dev for RHEL.
My question is: which libraries/packages should I install on RHEL? in other words: what is the equivalent of libgl1-mesa-dev or mesa-common-dev for RHEL distro?
Below is my system configuration:
CPU: Intel Core2 Duo 2.66GHz; GPU: nVidia Quadro NVS 290; RHEL Client 5.3, Linux kernel 2.6.18-128.1.14.el5, X86-64; GCC 4.1.2
Any help/information would be greatly appreciated.
and saw freeglut-2.4.0-7.1.el5. Looks like freeglut is installed, but not the devl version.
Also, I just found glx-utils-6.5.1-7.7.el5.x86_64.rpm and mesa-libGLU-6.5.1-7.7.el5.x86_64.rpm on Redhat’s website. I guess at least one of them is also an openGL utility library. What’s the difference between these libraries and freeflut ?
