CUDA Toolkit for L4T install failed!
Use SDK manager 0.9.14.4964 to install related tools automatically, and the host related tools are all installed successfully. The image has been burned to the target device, but the target CUDA cannot be installed correctly.
How to solve it?
17:01:28 INFO : CUDA Toolkit for L4T : Err:5 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
17:01:28 INFO : CUDA Toolkit for L4T : Cannot initiate the connection to ports.ubuntu.com:80 (2001:67c:1360:8001::22). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (91.189.88.150), connection timed out
17:01:28 INFO : CUDA Toolkit for L4T : Err:6 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
17:01:28 INFO : CUDA Toolkit for L4T : Err:7 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
17:01:28 INFO : CUDA Toolkit for L4T : Err:8 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
17:01:29 INFO : CUDA Toolkit for L4T : Reading package lists...
17:01:29 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic/InRelease Cannot initiate the connection to ports.ubuntu.com:80 (2001:67c:1360:8001::22). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (91.189.88.150), connection timed out
17:01:29 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease Cannot initiate the connection to ports.ubuntu.com:80 (2001:67c:1360:8001::22). - connect (101: Network is unreachable)
17:01:29 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-backports/InRelease Cannot initiate the connection to ports.ubuntu.com:80 (2001:67c:1360:8001::22). - connect (101: Network is unreachable)
17:01:29 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease Cannot initiate the connection to ports.ubuntu.com:80 (2001:67c:1360:8001::22). - connect (101: Network is unreachable)
17:01:29 INFO : CUDA Toolkit for L4T : W: Some index files failed to download. They have been ignored, or old ones used instead.
17:01:29 INFO : CUDA Toolkit for L4T : Waiting 5 seconds for apt to be available
17:01:34 INFO : CUDA Toolkit for L4T : *begin sudo apt-get -y install cuda-toolkit-10-0 , 5
17:01:34 INFO : CUDA Toolkit for L4T : Reading package lists...
17:01:34 INFO : CUDA Toolkit for L4T : Building dependency tree...
17:01:34 INFO : CUDA Toolkit for L4T : Reading state information...
17:01:34 INFO : CUDA Toolkit for L4T : Some packages could not be installed. This may mean that you have
17:01:34 INFO : CUDA Toolkit for L4T : requested an impossible situation or if you are using the unstable
17:01:34 INFO : CUDA Toolkit for L4T : distribution that some required packages have not yet been created
17:01:34 INFO : CUDA Toolkit for L4T : or been moved out of Incoming.
17:01:34 INFO : CUDA Toolkit for L4T : The following information may help to resolve the situation:
17:01:34 INFO : CUDA Toolkit for L4T : The following packages have unmet dependencies:
17:01:34 INFO : CUDA Toolkit for L4T : cuda-toolkit-10-0 : Depends: cuda-samples-10-0 (>= 10.0.326) but it is not going to be installed
17:01:34 INFO : CUDA Toolkit for L4T : Depends: cuda-documentation-10-0 (>= 10.0.326) but it is not going to be installed
17:01:34 INFO : CUDA Toolkit for L4T : E: Unable to correct problems, you have held broken packages.
17:01:34 INFO : CUDA Toolkit for L4T : Unhandled error when running sudo apt-get -y install cuda-toolkit-10-0
17:01:34 INFO : CUDA Toolkit for L4T : exit status 1
17:01:34 INFO : CUDA Toolkit for L4T : [ Package Install Finished with Error ]
17:01:34 INFO : CUDA Toolkit for L4T : [ 56.00 KB used. Disk Avail: 410.46 GB ]
17:01:34 INFO : CUDA Toolkit for L4T : [ NV_L4T_CUDA_TARGET_POST_INSTALL_COMP Install took 2m16s ]
17:01:34 ERROR : CUDA Toolkit for L4T : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh jcdz@10.168.112.122:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no jcdz@10.168.112.122 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh" finished with error
17:01:34 ERROR : CUDA Toolkit for L4T : command terminated with error
17:01:34 ERROR : install 'CUDA Toolkit for L4T' failure, command < cd '/home/jcdz/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P2888' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_CUDA_TARGET_POST_INSTALL_COMP' -v='10.0' -l='/home/jcdz/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P2888' -L='/home/jcdz/.nvsdkm/logs/JetPack_4.2.2_Linux_GA' -p='31158' -t='P2888' -e='/home/jcdz/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb' > terminated with error
SDKM_logs_2019-10-21_10-52-02.zip (713 KB)
According to that your host cannot use the internet to connect to http://ports.ubuntu.com. Are you behind a firewall or proxy? Can you “ping ubuntu.com”? The host PC must have internet access.
if you are behind a firewall/proxy
you may try using VPN or adding ports.ubuntu.com to hosts file /etc/hosts
what is the ip address that you resolve for the hostname?
Yes ,I can “ping ubuntu.com”.
Does the Target Device need to be connected?
When I burn flash, there will be an Error.
10:03:40 ERROR : Flash Jetson AGX Xavier : Board ID(2888) version(400) sku(0001) revision(J.0)
10:20:16 ERROR : Flash Jetson AGX Xavier :
10:20:16 ERROR : Flash Jetson AGX Xavier : 0: RAW: 4263936( 1041 blks) ==> 28:4263948
10:20:16 ERROR : Flash Jetson AGX Xavier : 4: RAW: 4096( 1 blks) ==> 4268108:4108
10:20:16 ERROR : Flash Jetson AGX Xavier : 5: SKP: 33550336( 8191 blks) ==> 4272216:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 6: RAW: 24576( 6 blks) ==> 4272228:24588
10:20:16 ERROR : Flash Jetson AGX Xavier : 7: SKP: 96292864( 23509 blks) ==> 4296816:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 9: SKP: 4448256( 1086 blks) ==> 4317320:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 10: RAW: 3448832( 842 blks) ==> 4317332:3448844
10:20:16 ERROR : Flash Jetson AGX Xavier : 13: SKP: 397312( 97 blks) ==> 7831736:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 14: RAW: 15548416( 3796 blks) ==> 7831748:15548428
10:20:16 ERROR : Flash Jetson AGX Xavier : 15: SKP: 49152( 12 blks) ==> 23380176:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 16: RAW: 147456( 36 blks) ==> 23380188:147468
10:20:16 ERROR : Flash Jetson AGX Xavier : 18: RAW: 77824( 19 blks) ==> 23527668:77836
10:20:16 ERROR : Flash Jetson AGX Xavier : 20: RAW: 331776( 81 blks) ==> 23605516:331788
10:20:16 ERROR : Flash Jetson AGX Xavier : 22: RAW: 790528( 193 blks) ==> 23937316:790540
10:20:16 ERROR : Flash Jetson AGX Xavier : 24: RAW: 57344( 14 blks) ==> 24727868:57356
10:20:16 ERROR : Flash Jetson AGX Xavier : 26: RAW: 143360( 35 blks) ==> 24785236:143372
10:20:16 ERROR : Flash Jetson AGX Xavier : 27: SKP: 290816( 71 blks) ==> 24928608:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 28: RAW: 4190208( 1023 blks) ==> 24928620:4190220
10:20:16 ERROR : Flash Jetson AGX Xavier : 30: RAW: 196608( 48 blks) ==> 29118852:196620
10:20:16 ERROR : Flash Jetson AGX Xavier : 31: SKP: 274432( 67 blks) ==> 29315472:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 32: RAW: 278528( 68 blks) ==> 29315484:278540
10:20:16 ERROR : Flash Jetson AGX Xavier : 34: RAW: 434176( 106 blks) ==> 29594036:434188
10:20:16 ERROR : Flash Jetson AGX Xavier : 37: SKP: 1339392( 327 blks) ==> 30032344:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 38: RAW: 49152( 12 blks) ==> 30032356:49164
10:20:16 ERROR : Flash Jetson AGX Xavier : 39: SKP: 368640( 90 blks) ==> 30081520:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 40: RAW: 20480( 5 blks) ==> 30081532:20492
10:20:16 ERROR : Flash Jetson AGX Xavier : 42: RAW: 16384( 4 blks) ==> 30102036:16396
10:20:16 ERROR : Flash Jetson AGX Xavier : 43: SKP: 4096( 1 blks) ==> 30118432:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 44: RAW: 4096( 1 blks) ==> 30118444:4108
10:20:16 ERROR : Flash Jetson AGX Xavier : 45: SKP: 16384( 4 blks) ==> 30122552:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 46: RAW: 4096( 1 blks) ==> 30122564:4108
10:20:16 ERROR : Flash Jetson AGX Xavier : 47: SKP: 4096( 1 blks) ==> 30126672:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 48: RAW: 4096( 1 blks) ==> 30126684:4108
10:20:16 ERROR : Flash Jetson AGX Xavier : 52: RAW: 4096( 1 blks) ==> 30134924:4108
10:20:16 ERROR : Flash Jetson AGX Xavier : 54: RAW: 6426624( 1569 blks) ==> 30139044:6426636
10:20:16 ERROR : Flash Jetson AGX Xavier : 55: SKP: 69632( 17 blks) ==> 36565680:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 57: SKP: 8192( 2 blks) ==> 36577992:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 58: RAW: 1597440( 390 blks) ==> 36578004:1597452
10:20:16 ERROR : Flash Jetson AGX Xavier : 60: RAW: 327680( 80 blks) ==> 38175468:327692
10:20:16 ERROR : Flash Jetson AGX Xavier : 62: RAW: 266240( 65 blks) ==> 38503172:266252
10:20:16 ERROR : Flash Jetson AGX Xavier : 64: RAW: 12288( 3 blks) ==> 38769436:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 67: SKP: 45056( 11 blks) ==> 38785856:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 68: RAW: 6791168( 1658 blks) ==> 38785868:6791180
10:20:16 ERROR : Flash Jetson AGX Xavier : 73: SKP: 4096( 1 blks) ==> 45618056:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 74: RAW: 864256( 211 blks) ==> 45618068:864268
10:20:16 ERROR : Flash Jetson AGX Xavier : 78: RAW: 18403328( 4493 blks) ==> 46523332:18403340
10:20:16 ERROR : Flash Jetson AGX Xavier : 79: SKP: 7372800( 1800 blks) ==> 64926672:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 87: SKP: 16699392( 4077 blks) ==> 64967728:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 88: RAW: 47394816( 11571 blks) ==> 64967740:47394828
10:20:16 ERROR : Flash Jetson AGX Xavier : 89: SKP: 2936832( 717 blks) ==> 112362568:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 90: RAW: 87322624( 21319 blks) ==> 112362580:87322636
10:20:16 ERROR : Flash Jetson AGX Xavier : 91: SKP: 4952064( 1209 blks) ==> 199685216:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 92: RAW: 33574912( 8197 blks) ==> 199685228:33574924
10:20:16 ERROR : Flash Jetson AGX Xavier : 93: SKP: 8368128( 2043 blks) ==> 233260152:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 94: RAW: 16760832( 4092 blks) ==> 233260164:16760844
10:20:16 ERROR : Flash Jetson AGX Xavier : 96: RAW: 16646144( 4064 blks) ==> 250021020:16646156
10:20:16 ERROR : Flash Jetson AGX Xavier : 98: RAW: 33472512( 8172 blks) ==> 266667188:33472524
10:20:16 ERROR : Flash Jetson AGX Xavier : 100: RAW: 14446592( 3527 blks) ==> 300139724:14446604
10:20:16 ERROR : Flash Jetson AGX Xavier : 101: SKP: 2330624( 569 blks) ==> 314586328:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 102: RAW: 15781888( 3853 blks) ==> 314586340:15781900
10:20:16 ERROR : Flash Jetson AGX Xavier : 105: SKP: 917504( 224 blks) ==> 330437896:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 106: RAW: 31621120( 7720 blks) ==> 330437908:31621132
10:20:16 ERROR : Flash Jetson AGX Xavier : 108: RAW: 487424( 119 blks) ==> 362059052:487436
10:20:16 ERROR : Flash Jetson AGX Xavier : 110: RAW: 69632( 17 blks) ==> 362546500:69644
10:20:16 ERROR : Flash Jetson AGX Xavier : 111: SKP: 1363968( 333 blks) ==> 362616144:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 112: RAW: 31408128( 7668 blks) ==> 362616156:31408140
10:20:16 ERROR : Flash Jetson AGX Xavier : 113: SKP: 2146304( 524 blks) ==> 394024296:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 114: RAW: 22134784( 5404 blks) ==> 394024308:22134796
10:20:16 ERROR : Flash Jetson AGX Xavier : 124: RAW: 49152( 12 blks) ==> 416232940:49164
10:20:16 ERROR : Flash Jetson AGX Xavier : 126: RAW: 16384( 4 blks) ==> 416282116:16396
10:20:16 ERROR : Flash Jetson AGX Xavier : 127: SKP: 8192( 2 blks) ==> 416298512:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 128: RAW: 40960( 10 blks) ==> 416298524:40972
10:20:16 ERROR : Flash Jetson AGX Xavier : 134: RAW: 12288( 3 blks) ==> 416355940:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 138: RAW: 12288( 3 blks) ==> 416372372:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 139: SKP: 4096( 1 blks) ==> 416384672:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 140: RAW: 4096( 1 blks) ==> 416384684:4108
10:20:16 ERROR : Flash Jetson AGX Xavier : 141: SKP: 8192( 2 blks) ==> 416388792:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 142: RAW: 12288( 3 blks) ==> 416388804:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 145: SKP: 8192( 2 blks) ==> 416405224:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 146: RAW: 12288( 3 blks) ==> 416405236:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 147: SKP: 8192( 2 blks) ==> 416417536:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 148: RAW: 12288( 3 blks) ==> 416417548:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 150: RAW: 8192( 2 blks) ==> 416429860:8204
10:20:16 ERROR : Flash Jetson AGX Xavier : 152: RAW: 12288( 3 blks) ==> 416438076:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 153: SKP: 8192( 2 blks) ==> 416450376:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 154: RAW: 12288( 3 blks) ==> 416450388:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 156: RAW: 12288( 3 blks) ==> 416462700:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 158: RAW: 8192( 2 blks) ==> 416475012:8204
10:20:16 ERROR : Flash Jetson AGX Xavier : 159: SKP: 8192( 2 blks) ==> 416483216:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 160: RAW: 12288( 3 blks) ==> 416483228:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 162: RAW: 12288( 3 blks) ==> 416495540:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 164: RAW: 12288( 3 blks) ==> 416507852:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 165: SKP: 8192( 2 blks) ==> 416520152:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 166: RAW: 8192( 2 blks) ==> 416520164:8204
10:20:16 ERROR : Flash Jetson AGX Xavier : 168: RAW: 12288( 3 blks) ==> 416528380:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 170: RAW: 12288( 3 blks) ==> 416540692:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 172: RAW: 8192( 2 blks) ==> 416553004:8204
10:20:16 ERROR : Flash Jetson AGX Xavier : 173: SKP: 8192( 2 blks) ==> 416561208:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 174: RAW: 12288( 3 blks) ==> 416561220:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 176: RAW: 12288( 3 blks) ==> 416573532:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 178: RAW: 8192( 2 blks) ==> 416585844:8204
10:20:16 ERROR : Flash Jetson AGX Xavier : 179: SKP: 8192( 2 blks) ==> 416594048:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 180: RAW: 12288( 3 blks) ==> 416594060:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 182: RAW: 12288( 3 blks) ==> 416606372:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 184: RAW: 8192( 2 blks) ==> 416618684:8204
10:20:16 ERROR : Flash Jetson AGX Xavier : 185: SKP: 8192( 2 blks) ==> 416626888:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 186: RAW: 12288( 3 blks) ==> 416626900:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 188: RAW: 8192( 2 blks) ==> 416639212:8204
10:20:16 ERROR : Flash Jetson AGX Xavier : 190: RAW: 12288( 3 blks) ==> 416647428:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 193: SKP: 16384( 4 blks) ==> 416663848:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 196: RAW: 4096( 1 blks) ==> 416672076:4108
10:20:16 ERROR : Flash Jetson AGX Xavier : 197: SKP: 12288( 3 blks) ==> 416676184:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 198: RAW: 20480( 5 blks) ==> 416676196:20492
10:20:16 ERROR : Flash Jetson AGX Xavier : 204: RAW: 16384( 4 blks) ==> 416721324:16396
10:20:16 ERROR : Flash Jetson AGX Xavier : 206: RAW: 12288( 3 blks) ==> 416737732:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 208: RAW: 8192( 2 blks) ==> 416750044:8204
10:20:16 ERROR : Flash Jetson AGX Xavier : 209: SKP: 8192( 2 blks) ==> 416758248:12
10:20:16 ERROR : Flash Jetson AGX Xavier : 210: RAW: 12288( 3 blks) ==> 416758260:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 212: RAW: 12288( 3 blks) ==> 416770572:12300
10:20:16 ERROR : Flash Jetson AGX Xavier : 214: RAW: 12288( 3 blks) ==> 416782884:1230
10:22:26 ERROR : Flash Jetson AGX Xavier : 4798: RAW: 32768( 8 blks) ==> 4371181828:32780
10:22:26 ERROR : Flash Jetson AGX Xavier : 4800: RAW: 32768( 8 blks) ==> 4371214620:32780
10:22:26 ERROR : Flash Jetson AGX Xavier : 4802: RAW: 32768( 8 blks) ==> 4371247412:32780
10:22:26 ERROR : Flash Jetson AGX Xavier : 4804: RAW: 20897792( 5102 blks) ==> 4371280204:20897804
10:22:27 ERROR : Flash Jetson AGX Xavier : 4805: SKP: 1472266240( 359440 blks) ==> 4392178008:12
10:22:27 ERROR : Flash Jetson AGX Xavier : -- Total: ---------------------------------------------------
Xavier starts automatically, then clicks Next, a cuda error occurs.
10:36:13 ERROR : CUDA Toolkit for L4T : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh xavier@10.168.112.236:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no xavier@10.168.112.236 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh" finished with error
10:36:13 ERROR : CUDA Toolkit for L4T : command terminated with error
10:36:13 ERROR : install 'CUDA Toolkit for L4T' failure, command < cd '/home/xumoxiao/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P2888' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_CUDA_TARGET_POST_INSTALL_COMP' -v='10.0' -l='/home/xumoxiao/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P2888' -L='/home/xumoxiao/.nvsdkm/logs/JetPack_4.2.2_Linux_GA' -p='3077' -t='P2888' -e='/home/xumoxiao/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb' > terminated with error
10:37:33 ERROR : Unavailable components detected, please check log
10:37:33 ERROR : cuDNN on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
10:37:33 ERROR : TensorRT on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
10:37:33 ERROR : OpenCV on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
10:37:33 ERROR : VisionWorks on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
10:37:33 ERROR : Multimedia API Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
I don’t understand what is going on here.
Sorry, I am a newbie. I do not know if I am behind a firewall/proxy .but I can “ping ubuntu.com”.
The host Ip is inet 10.168.113.213 netmask 255.255.254.0 broadcast 10.168.113.255.
My Device Ip is inet 10.168.112.110 netmask 255.255.254.0 broadcast 10.168.113.255.
Host can ping device.
As long as you told JetPack/SDK Manager to use that same address, and that address works for manually using ssh to connect, then this is ok for networking between host and Jetson.
The error log you showed was incomplete, and if you could post the full log it would help. The networking would need to be fully functional between host and Jetson at the time it tried to install CUDA. There isn’t enough logging there to see anything more specific.
Thank you for your reply.
All the logs have been packaged and uploaded. I have tried many times here and still can’t.
I am far from expert with those log files, but I see some “.mtd” files were corrupt. You might be better off if you start from scratch (I don’t mean flashing from scratch, I just mean deleting the temp SDK Manager files and downloads, then running the SDKM again while checking that you only want to add packages to the Jetson without adding anything else).
Try deleting your “~/Downloads/nvidia/sdkm_downloads/", and your "~/nvidia/nvidia_sdk/”, along with the “~/.nvsdkm/*”, and then run the app again. Any downloads or other metadata will be loaded again…just make sure the Xavier is already fully booted (not in recovery mode) and that you can ssh to the Xavier. Then the “package” steps (not flash, and not package to host) might work again. This is probably a necessary verification step even if it isn’t a fix, so a failure of this to work would add more information.
