- 10:07:26 ERROR : CUDA Toolkit for L4T : NV_L4T_CUDA_TARGET_POST_INSTALL_COMP command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh xavier@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no xavier@192.168.55.1 “~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh” finished with error
- 10:07:26 INFO : CUDA Toolkit for L4T :
- 10:07:26 INFO : CUDA Toolkit for L4T : [ 16.00 KB used. Disk Avail: 12.20 GB ]
- 10:07:26 INFO : CUDA Toolkit for L4T : [ NV_L4T_CUDA_TARGET_POST_INSTALL_COMP Install took 3m41s ]
- 10:07:26 INFO : CUDA Toolkit for L4T : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh xavier@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no xavier@192.168.55.1 “~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh” finished with error
- 10:07:26 ERROR : CUDA Toolkit for L4T : command terminated with error
Hi lt15511013708,
Please try install sdk components using eth0 IP address instead of USB device IP address (192.168.55.1).
If still got issue, please provide ~/.nvsdkm/sdkm.log for check. Thanks!
Regardless of which IP address you use, make sure you can manually ssh in to that IP address using the name/pass you provide for SDKM.
