Hello All
I installed CUDA 2,0 on SUSE 10,3
I installed the driver and toolkit as root, The as root I also installed the SDK int /root/NVIDIA_CUDA_SDK
As root everything worked fine, Including all the openGL examples like oceanFFT and so on
When I installed the SDK as my own user, I get problems as below, The CUDA enabled GPU is not visible
I removed the SDK from root and rebooted my system and so on.
I have a 8800GTX and a 7300GT on my system
All the SDK examples fail
pmistry@pino:~/NVIDIA_CUDA_SDK/bin/linux/release> ./deviceQuery
NVIDIA: could not open the device file /dev/nvidiactl (Permission denied).
There is no device supporting CUDA.
Device 0: “Device Emulation (CPU)”
Major revision number: 9999
Minor revision number: 9999
Total amount of global memory: 4294967295 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 1
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.35 GHz
Concurrent copy and execution: No
Test PASSED
Press ENTER to exit…
In emulation mode too I get the /dev/nvidiactl (Permission denied). error
Can anyone shed some light on what I need to do???
