Hi all,
I ran cudnn v4 samples on Tesla M40.
The driver version is 352.79, which is the newest for M40.
The OS is CentOS 7 64bit.
When I ran, it reports:
./mnistCUDNN
cudnnGetVersion() : 3002 , CUDNN_VERSION from cudnn.h : 4007 (4.0.7)
Host compiler version : GCC 4.8.3
There are 2 CUDA capable devices on your machine :
device 0 : sms 24 Capabilities 5.2, SmClock 1112.0 Mhz, MemSize (Mb) 11519, MemClock 3004.0 Mhz, Ecc=1, boardGroupID=0
device 1 : sms 24 Capabilities 5.2, SmClock 1112.0 Mhz, MemSize (Mb) 11519, MemClock 3004.0 Mhz, Ecc=1, boardGroupID=1
Using device 0
Testing single precision
Loading image data/one_28x28.pgm
Performing forward propagation ...
Testing cudnnGetConvolutionForwardAlgorithm ...
Fastest algorithm is Algo 1
Testing cudnnFindConvolutionForwardAlgorithm ...
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.031136 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.044992 time requiring 3464 memory
Segment Fault(Core Dumped)
You seem to have a mismatch. The library is version 3, the header is from version 4.
It solved! I removed the libcudnn.so* and copy all libcudnn v4 into my lib path, the results:
# ./mnistCUDNN
cudnnGetVersion() : 4007 , CUDNN_VERSION from cudnn.h : 4007 (4.0.7)
Using device 0
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.032320 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.055776 time requiring 57600 memory
Resulting weights from Softmax:
0.0000000 0.9999399 0.0000000 0.0000000 0.0000561 0.0000000 0.0000012 0.0000017 0.0000010 0.0000000
Loading image data/three_28x28.pgm
0.0000000 0.0000000 0.0000000 0.9999288 0.0000000 0.0000711 0.0000000 0.0000000 0.0000000 0.0000000
Loading image data/five_28x28.pgm
0.0000000 0.0000008 0.0000000 0.0000002 0.0000000 0.9999820 0.0000154 0.0000000 0.0000012 0.0000006
Result of classification: 1 3 5
Test passed!
Testing half precision (math in single precision)
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.033504 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.055488 time requiring 28800 memory
0.0000001 1.0000000 0.0000001 0.0000000 0.0000563 0.0000001 0.0000012 0.0000017 0.0000010 0.0000001
0.0000000 0.0000000 0.0000000 1.0000000 0.0000000 0.0000720 0.0000000 0.0000000 0.0000000 0.0000000
0.0000000 0.0000008 0.0000000 0.0000002 0.0000000 1.0000000 0.0000154 0.0000000 0.0000012 0.0000006
Test passed!
