When building samples in the directory /usr/local/cuda/extras/CUPTI/samples/autorange_profiling, I included -Xcompiler -fsanitize=address in NVCCFLAGS. This was done so that I could detect any memory leaks during profiling.
However, after building, I encountered an error when attempting to execute auto_range_profiling.
==3113510==You are trying to dlopen a libnvperf_host.so shared library with RTLD_DEEPBIND flag which is incompatibe with sanitizer runtime (see https://github.com/google/sanitizers/issues/611 for details). If you want to run libnvperf_host.so library under sanitizers please remove RTLD_DEEPBIND from dlopen flags.
To address this issue, I have implemented a workaround by incorporating a dlopen hooker that can modify the RTLD_DEEPBIND flag.
#include <dlfcn.h>
#include <stdio.h>
typedef void* (*orig_dlopen_func_type)(const char*, int);
void* dlopen(const char* filename, int flags) {
void* result;
orig_dlopen_func_type original_dlopen;
original_dlopen = (orig_dlopen_func_type)dlsym(((void*)-1l), "dlopen");
if (flags & RTLD_DEEPBIND) {
printf("Intercepted dlopen(%s, %d)\n", filename, flags);
flags &= ~RTLD_DEEPBIND;
printf("Adjusted flags to %d\n", flags);
result = (*original_dlopen)(filename, flags);
return result;
To build the file, use the following command: gcc -shared -o dlopen_intercept.so hook_dlopen.c.
Next, run the program with the command sudo ASAN_OPTIONS=verify_asan_link_order=0 LD_PRELOAD=/media/nvme/xuzhi/cts/dlopen_intercept.so:/lib/aarch64-linux-gnu/libasan.so.5 ./auto_range_profiling. This should properly execute the binary.
According to the ASAN report, there appears to be a memory leak issue as follow.
Usage: ./auto_range_profiling [device_num] [metric_names comma separated]
CUDA Device Number: 0
Compute Capability of Device: 8.7
Intercepted dlopen(libnvperf_host.so, 266)
Adjusted flags to 258
Launching kernel: blocks 64, thread/block 256
Range Name Metric Name Metric Value
0 smsp__warps_launched.avg 8
1 smsp__warps_launched.avg 8
==3115379==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 685058 byte(s) in 610 object(s) allocated from:
#0 0xffff84482540 in __interceptor_malloc ../../../../src/libsanitizer/asan/asan_malloc_linux.cc:144
#1 0xffff8181b7d8 (/usr/local/cuda/targets/aarch64-linux/lib/libnvperf_host.so+0x1417d8)
#2 0xffff80db5e0c in __libc_start_main ../csu/libc-start.c:308
#3 0xaaaac240da5c (/media/nvme/xuzhi/workspace/tune_space/cupti_samples/autorange_profiling/auto_range_profiling+0xda5c)
Direct leak of 42608 byte(s) in 61 object(s) allocated from:
#1 0xffff8181b034 (/usr/local/cuda/targets/aarch64-linux/lib/libnvperf_host.so+0x141034)
Direct leak of 2752 byte(s) in 6 object(s) allocated from:
#0 0xffff8448293c in __interceptor_realloc ../../../../src/libsanitizer/asan/asan_malloc_linux.cc:163
#1 0xffff8181b860 (/usr/local/cuda/targets/aarch64-linux/lib/libnvperf_host.so+0x141860)
Direct leak of 392 byte(s) in 1 object(s) allocated from:
#1 0xffff7df5eaa0 (/lib/aarch64-linux-gnu/libnvcucompat.so+0x8aa0)
Direct leak of 100 byte(s) in 7 object(s) allocated from:
#1 0xffff7df5eb4c (/lib/aarch64-linux-gnu/libnvcucompat.so+0x8b4c)
Direct leak of 96 byte(s) in 3 object(s) allocated from:
#1 0xffff8181b6ec (/usr/local/cuda/targets/aarch64-linux/lib/libnvperf_host.so+0x1416ec)
Direct leak of 28 byte(s) in 1 object(s) allocated from:
#1 0xffff7df5f204 (/lib/aarch64-linux-gnu/libnvcucompat.so+0x9204)
Direct leak of 20 byte(s) in 1 object(s) allocated from:
#1 0xffff7df5f244 (/lib/aarch64-linux-gnu/libnvcucompat.so+0x9244)
#1 0xffff7df5f264 (/lib/aarch64-linux-gnu/libnvcucompat.so+0x9264)
Direct leak of 16 byte(s) in 1 object(s) allocated from:
#1 0xffff7df5ef78 (/lib/aarch64-linux-gnu/libnvcucompat.so+0x8f78)
Direct leak of 12 byte(s) in 1 object(s) allocated from:
#1 0xffff7df5f174 (/lib/aarch64-linux-gnu/libnvcucompat.so+0x9174)
#1 0xffff7df5f224 (/lib/aarch64-linux-gnu/libnvcucompat.so+0x9224)
Direct leak of 8 byte(s) in 1 object(s) allocated from:
#1 0xffff7df5f194 (/lib/aarch64-linux-gnu/libnvcucompat.so+0x9194)
Direct leak of 6 byte(s) in 1 object(s) allocated from:
#1 0xffff8181b8dc (/usr/local/cuda/targets/aarch64-linux/lib/libnvperf_host.so+0x1418dc)
Direct leak of 1 byte(s) in 1 object(s) allocated from:
#1 0xffff7df5ebdc (/lib/aarch64-linux-gnu/libnvcucompat.so+0x8bdc)
Indirect leak of 120631 byte(s) in 128 object(s) allocated from:
Indirect leak of 9280 byte(s) in 59 object(s) allocated from:
Indirect leak of 1448 byte(s) in 1 object(s) allocated from:
#1 0xffff82818948 (/usr/local/cuda/targets/aarch64-linux/lib/libcupti.so.11.4+0xd5948)
Indirect leak of 1216 byte(s) in 2 object(s) allocated from:
#1 0xffff8181ac94 (/usr/local/cuda/targets/aarch64-linux/lib/libnvperf_host.so+0x140c94)
Indirect leak of 136 byte(s) in 1 object(s) allocated from:
#1 0xffff8284ce24 (/usr/local/cuda/targets/aarch64-linux/lib/libcupti.so.11.4+0x109e24)
Indirect leak of 128 byte(s) in 1 object(s) allocated from:
#0 0xffff84482724 in __interceptor_calloc ../../../../src/libsanitizer/asan/asan_malloc_linux.cc:153
#1 0xffff82a9d7b0 (/usr/local/cuda/targets/aarch64-linux/lib/libcupti.so.11.4+0x35a7b0)
Indirect leak of 64 byte(s) in 1 object(s) allocated from:
#1 0xffff8284c028 (/usr/local/cuda/targets/aarch64-linux/lib/libcupti.so.11.4+0x109028)
Indirect leak of 52 byte(s) in 6 object(s) allocated from:
Indirect leak of 48 byte(s) in 1 object(s) allocated from:
#1 0xffff82a9d74c (/usr/local/cuda/targets/aarch64-linux/lib/libcupti.so.11.4+0x35a74c)
Indirect leak of 24 byte(s) in 1 object(s) allocated from:
#1 0xffff82a9d0f4 (/usr/local/cuda/targets/aarch64-linux/lib/libcupti.so.11.4+0x35a0f4)
Indirect leak of 16 byte(s) in 1 object(s) allocated from:
#1 0xffff82a9d88c (/usr/local/cuda/targets/aarch64-linux/lib/libcupti.so.11.4+0x35a88c)
#1 0xffff82a9d134 (/usr/local/cuda/targets/aarch64-linux/lib/libcupti.so.11.4+0x35a134)
SUMMARY: AddressSanitizer: 864188 byte(s) leaked in 900 allocation(s).
I have identified that the memory leakage occurs when calling NVPW_InitializeHost in the code block provided.
NVPW_InitializeHost_Params initializeHostParams = {
NVPW_InitializeHost_Params_STRUCT_SIZE};
NVPW_API_CALL(NVPW_InitializeHost(&initializeHostParams));
Could you kindly provide some insight into the root cause of this memory leakage issue and any potential solutions to fix it? Thank you very much
