CuRobo docker container streaming issues
hi this is my setup:
  • Issac Sim docker container
  • cuRobo installed in the docker
  • Host omniverse streamer
when I run runheadless.native I can see issacsim running on the omniverse streaming client.
however when I run the curobo example
/isaac-sim/python.sh examples/isaac_sim/collision_checker.py --headless_mode native
this error shows up this is the code for starting the simulation
try:
    # Third Party
    import isaacsim
except ImportError:
    pass
# Third Party
import torch
a = torch.zeros(4, device="cuda:0")
# Standard Library
# Standard Library
import argparse
# Third Party
from omni.isaac.kit import SimulationApp
parser = argparse.ArgumentParser()
parser.add_argument(
    "--nvblox", action="store_true", help="When True, enables headless mode", default=False
    "--headless_mode",
    type=str,
    default=None,
    help="To run headless, use one of [native, websocket], webrtc might not work.",
args = parser.parse_args()
simulation_app = SimulationApp(
        "headless": args.headless_mode is not None,
        "width": "1920",
        "height": "1080",
full log
Starting kit application with the following args:  ['/isaac-sim/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/isaac-sim/apps/omni.isaac.sim.python.kit', '--/app/tokens/exe-path=/isaac-sim/kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True', '--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1920', '--/app/renderer/resolution/height=1080', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--ext-folder', '/isaac-sim/exts', '--ext-folder', '/isaac-sim/apps', '--/physics/cudaDevice=0', '--portable', '--no-window', '--/app/window/hideUi=1', '--allow-root']
Passing the following args to the base kit application:  ['--headless_mode', 'native']
[Info] [carb] Logging to file: /isaac-sim/kit/logs/Kit/Isaac-Sim/4.2/kit_20241018_164209.log
2024-10-18 16:42:09 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[0.091s] [ext: omni.blobkey-1.1.2] startup
[0.091s] [ext: omni.kit.async_engine-0.0.1] startup
[0.589s] [ext: omni.stats-1.0.1] startup
[0.590s] [ext: omni.datastore-0.0.0] startup
[0.594s] [ext: omni.client-1.2.0] startup
[0.612s] [ext: omni.ujitso.default-1.0.0] startup
[0.613s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.615s] [ext: omni.hsscclient-1.1.1] startup
[0.615s] [ext: omni.assets.plugins-0.0.0] startup
[0.616s] [ext: omni.gpu_foundation-0.0.0] startup
[0.622s] [ext: carb.windowing.plugins-1.0.0] startup
2024-10-18 16:42:09 [556ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-10-18 16:42:09 [556ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[0.623s] [ext: omni.kit.renderer.init-0.0.0] startup
2024-10-18 16:42:09 [579ms] [Warning] [omni.platforminfo.plugin] failed to open the default display.  Can't verify X Server version.
| Driver Version: 550.107.02    | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA GeForce RTX 4080 SUPER    | Yes: 0 |     | 16376   MB | 10de      | 0          |
|     |                                  |        |     |            | 2702      | e510b4eb.. |
|     |                                  |        |     |            | 1         |            |
| OS: 22.04.3 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.3, Kernel: 6.8.0-47-generic
| Processor: AMD Ryzen 9 7950X3D 16-Core Processor | Cores: 16 | Logical: 32
| Total Memory (MB): 95681 | Free Memory: 88572
| Total Page/Swap (MB): 8191 | Free Page/Swap: 8191
2024-10-18 16:42:09 [815ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled.
[1.019s] [ext: omni.kit.pipapi-0.0.0] startup
[1.021s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.021s] [ext: omni.pip.compute-1.4.0] startup
[1.021s] [ext: omni.pip.cloud-1.1.3] startup
[1.023s] [ext: omni.isaac.core_archive-2.3.0] startup
[1.023s] [ext: omni.materialx.libs-1.0.4] startup
[1.029s] [ext: omni.isaac.ml_archive-2.0.1] startup
[1.029s] [ext: omni.kit.telemetry-0.5.0] startup
[1.060s] [ext: omni.usd.config-1.0.4] startup
[1.064s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.064s] [ext: omni.usd.libs-1.0.1] startup
[1.124s] [ext: omni.iray.libs-0.0.0] startup
[1.128s] [ext: omni.mdl.neuraylib-0.2.8] startup
[1.130s] [ext: omni.mdl-55.0.1] startup
[1.146s] [ext: omni.kit.usd.mdl-1.0.1] startup
[1.224s] [ext: omni.kit.loop-isaac-1.2.0] startup
[1.225s] [ext: omni.kit.test-1.1.0] startup
[1.253s] [ext: omni.appwindow-1.1.8] startup
2024-10-18 16:42:10 [1,187ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-10-18 16:42:10 [1,187ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[1.255s] [ext: omni.kit.renderer.core-1.0.2] startup
2024-10-18 16:42:10 [1,192ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-10-18 16:42:10 [1,192ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2024-10-18 16:42:10 [1,197ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-10-18 16:42:10 [1,197ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[1.265s] [ext: omni.kit.renderer.capture-0.0.0] startup
[1.266s] [ext: omni.kit.renderer.imgui-1.0.1] startup
2024-10-18 16:42:10 [1,201ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-10-18 16:42:10 [1,201ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2024-10-18 16:42:10 [1,202ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-10-18 16:42:10 [1,202ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2024-10-18 16:42:10 [1,203ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-10-18 16:42:10 [1,203ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[1.316s] [ext: omni.ui-2.25.22] startup
[1.324s] [ext: omni.kit.mainwindow-1.0.3] startup
[1.324s] [ext: carb.audio-0.1.0] startup
[1.328s] [ext: omni.uiaudio-1.0.0] startup
[1.329s] [ext: omni.kit.uiapp-0.0.0] startup
[1.329s] [ext: omni.usd.schema.isaac-2.1.0] startup
[1.335s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.337s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.351s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[1.353s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.355s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[1.359s] [ext: omni.anim.navigation.schema-106.1.0] startup
[1.361s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[1.363s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[1.366s] [ext: omni.anim.graph.schema-106.1.0] startup
[1.370s] [ext: omni.usd.schema.physx-106.1.9] startup
[1.392s] [ext: omni.usd.schema.forcefield-106.1.9] startup
[1.395s] [ext: omni.graph.exec-0.9.4] startup
[1.396s] [ext: omni.kit.usd_undo-0.1.8] startup
[1.397s] [ext: omni.kit.actions.core-1.0.0] startup
[1.398s] [ext: omni.kit.exec.core-0.13.4] startup
[1.400s] [ext: omni.usd_resolver-1.0.0] startup
[1.402s] [ext: omni.kit.commands-1.4.9] startup
[1.405s] [ext: omni.activity.core-1.0.1] startup
[1.406s] [ext: omni.usd.core-1.4.1] startup
[1.408s] [ext: omni.resourcemonitor-105.0.1] startup
[1.409s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[1.412s] [ext: omni.timeline-1.0.10] startup
[1.413s] [ext: omni.kit.widget.nucleus_connector-1.1.9] startup
[1.414s] [ext: usdrt.scenegraph-7.5.0] startup
[1.443s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[1.444s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[1.453s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[1.457s] [ext: omni.usd-1.12.2] startup
[1.478s] [ext: omni.kit.menu.core-1.0.4] startup
[1.479s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[1.479s] [ext: omni.kit.property.adapter.core-1.0.1] startup
[1.481s] [ext: omni.kit.menu.utils-1.5.27] startup
[1.486s] [ext: omni.kit.clipboard-1.0.4] startup
[1.487s] [ext: omni.kit.collaboration.channel_manager-1.0.12] startup
[1.487s] [ext: omni.kit.property.adapter.usd-1.0.1] startup
[1.488s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[1.490s] [ext: omni.kit.widget.graph-1.12.15] startup
[1.493s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[1.494s] [ext: omni.kit.widget.filter-1.1.4] startup
[1.495s] [ext: omni.kit.property.adapter.fabric-1.0.1] startup
[1.495s] [ext: omni.ui_query-1.1.4] startup
[1.496s] [ext: omni.kit.window.extensions-1.4.11] startup
[1.500s] [ext: omni.kit.usd.layers-2.1.36] startup
[1.505s] [ext: omni.kit.widget.context_menu-1.2.2] startup
[1.506s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[1.507s] [ext: omni.kit.notification_manager-1.0.9] startup
[1.508s] [ext: omni.kit.hotkeys.core-1.3.5] startup
[1.508s] [ext: omni.kit.context_menu-1.8.1] startup
[1.509s] [ext: omni.kit.widget.prompt-1.0.7] startup
[1.510s] [ext: omni.kit.helper.file_utils-0.1.8] startup
[1.511s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[1.511s] [ext: omni.kit.widget.filebrowser-2.10.51] startup
[1.514s] [ext: omni.kit.search_core-1.0.5] startup
[1.515s] [ext: omni.kit.widget.path_field-2.0.10] startup
[1.515s] [ext: omni.ui.scene-1.10.3] startup
[1.518s] [ext: omni.kit.widget.search_delegate-1.0.5] startup
[1.519s] [ext: omni.kit.widget.options_button-1.0.3] startup
[1.520s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[1.520s] [ext: omni.volume-0.5.0] startup
[1.522s] [ext: omni.kit.window.filepicker-2.10.40] startup
[1.531s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[1.531s] [ext: omni.kit.window.file_exporter-1.0.30] startup
[1.533s] [ext: omni.ujitso.client-0.0.0] startup
[1.533s] [ext: omni.kit.widget.stage-2.11.2] startup
[1.540s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[1.541s] [ext: omni.kit.collaboration.presence_layer-1.0.9] startup
[1.543s] [ext: omni.hydra.rtx-1.0.0] startup
[1.555s] [ext: omni.inspect-1.0.1] startup
[1.557s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[1.557s] [ext: omni.kit.window.file_importer-1.1.12] startup
[1.558s] [ext: omni.kit.stage_template.core-1.1.22] startup
[1.558s] [ext: omni.kit.widget.settings-1.2.2] startup
[1.560s] [ext: omni.kit.window.file-1.3.54] startup
[1.562s] [ext: omni.kit.window.drop_support-1.0.3] startup
[1.562s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[1.562s] [ext: omni.kit.window.preferences-1.6.0] startup
[1.566s] [ext: omni.kit.window.content_browser-2.9.18] startup
[1.576s] [ext: omni.kit.widget.live_session_management-1.2.20] startup
[1.578s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[1.579s] [ext: omni.kit.hydra_texture-1.3.9] startup
[1.581s] [ext: omni.kit.viewport.legacy_gizmos-1.1.0] startup
[1.583s] [ext: omni.kit.raycast.query-1.0.5] startup
[1.587s] [ext: omni.kit.material.library-1.5.6] startup
[1.591s] [ext: omni.kit.widget.viewport-106.1.0] startup
[1.594s] [ext: omni.kit.viewport.registry-104.0.6] startup
[1.594s] [ext: omni.hydra.engine.stats-1.0.2] startup
[1.596s] [ext: omni.kit.widget.highlight_label-1.0.2] startup
[1.596s] [ext: omni.kit.viewport.window-107.0.6] startup
[1.608s] [ext: omni.kit.window.property-1.11.3] startup
[1.610s] [ext: omni.graph.core-2.179.2] startup
[1.611s] [ext: omni.graph.tools-1.79.0] startup
[1.626s] [ext: omni.kit.viewport.utility-1.0.17] startup
[1.627s] [ext: omni.kit.property.usd-4.2.8] startup
[1.633s] [ext: omni.debugdraw-0.1.3] startup
[1.635s] [ext: omni.graph-1.140.0] startup
[1.665s] [ext: omni.graph.ui-1.70.2] startup
[1.677s] [ext: omni.kvdb-106.1.9] startup
[1.680s] [ext: omni.graph.image.core-0.4.5] startup
[1.681s] [ext: omni.localcache-106.1.9] startup
[1.683s] [ext: omni.graph.image.nodes-1.1.0] startup
[1.685s] [ext: omni.usdphysics-106.1.9] startup
[1.688s] [ext: omni.physx.foundation-106.1.9] startup
[1.689s] [ext: omni.convexdecomposition-106.1.9] startup
[1.693s] [ext: omni.graph.nodes-1.146.1] startup
[1.700s] [ext: omni.physx.cooking-106.1.9] startup
[1.708s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[1.710s] [ext: omni.physx-106.1.9] startup
[1.719s] [ext: omni.kit.stage_templates-1.2.5] startup
[1.721s] [ext: omni.isaac.version-1.1.0] startup
[1.722s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[1.723s] [ext: omni.isaac.nucleus-0.3.1] startup
[1.724s] [ext: omni.physics.tensors-106.1.9] startup
[1.729s] [ext: omni.physx.stageupdate-106.1.9] startup
[1.730s] [ext: omni.graph.action_core-1.1.6] startup
[1.733s] [ext: omni.warp.core-1.2.1] startup
[1.804s] [ext: omni.physx.tensors-106.1.9] startup
[1.808s] [ext: omni.graph.scriptnode-1.20.1] startup
[1.809s] [ext: omni.kit.manipulator.viewport-107.0.0] startup
[1.810s] [ext: omni.graph.action_nodes-1.24.0] startup
[1.815s] [ext: omni.kit.ui_test-1.3.2] startup
[1.820s] [ext: omni.isaac.core-3.19.5] startup
[2.055s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[2.060s] [ext: omni.graph.action-1.102.1] startup
[2.062s] [ext: omni.kit.window.cursor-1.1.2] startup
[2.064s] [ext: omni.isaac.ui-0.16.0] startup
[2.072s] [ext: omni.kit.viewport.menubar.core-106.1.0] startup
[2.085s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[2.086s] [ext: omni.syntheticdata-0.6.9] startup
[2.106s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[2.109s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[2.113s] [ext: omni.kit.numpy.common-0.1.2] startup
[2.115s] [ext: omni.warp-1.2.1] startup
[2.126s] [ext: omni.kit.window.material_graph-1.8.18] startup
[2.181s] [ext: omni.isaac.dynamic_control-1.3.8] startup
[2.196s] [ext: omni.replicator.core-1.11.20] startup
2024-10-18 16:42:11 [2,146ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
Warp 1.2.1 initialized:
   CUDA Toolkit 11.8, Driver 12.4
   Devices:
     "cpu"      : "x86_64"
     "cuda:0"   : "NVIDIA GeForce RTX 4080 SUPER" (16 GiB, sm_89, mempool enabled)
   Kernel cache:
     /root/.cache/warp/1.2.1
[2.306s] [ext: omni.isaac.lula-3.0.1] startup
[2.313s] [ext: omni.isaac.surface_gripper-1.0.1] startup
[2.317s] [ext: omni.isaac.core_nodes-1.16.3] startup
[2.333s] [ext: omni.isaac.motion_generation-7.1.0] startup
[2.346s] [ext: omni.isaac.manipulators-2.1.0] startup
[2.348s] [ext: omni.isaac.franka-0.4.1] startup
[2.355s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[2.362s] [ext: omni.kit.graph.delegate.modern-1.10.6] startup
[2.368s] [ext: omni.isaac.cortex-0.3.9] startup
[2.370s] [ext: omni.graph.window.core-1.113.1] startup
[2.391s] [ext: omni.isaac.wheeled_robots-2.3.3] startup
[2.406s] [ext: omni.isaac.cortex.sample_behaviors-1.0.6] startup
[2.406s] [ext: omni.graph.window.generic-1.26.0] startup
[2.418s] [ext: omni.isaac.menu-0.7.3] startup
[2.422s] [ext: omni.kit.widget.live-2.1.8] startup
[2.429s] [ext: omni.kit.actions.window-1.1.1] startup
[2.438s] [ext: omni.kit.widget.cache_indicator-2.0.10] startup
[2.494s] [ext: omni.kit.hotkeys.window-1.4.5] startup
2024-10-18 16:42:11 [2,427ms] [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. Consider installing it for better IO performance.
[2.504s] [ext: omni.kit.ui.actions-1.0.2] startup
[2.506s] [ext: omni.kit.widget.stage_icons-1.0.5] startup
[2.510s] [ext: omni.kit.menu.common-1.1.7] startup
[2.515s] [ext: omni.kit.selection-0.1.4] startup
[2.518s] [ext: omni.isaac.kit-1.13.2] startup
[2.519s] [ext: omni.isaac.block_world-1.0.0] startup
[2.526s] [ext: omni.kit.window.stage-2.5.10] startup
[2.529s] [ext: omni.isaac.debug_draw-1.1.0] startup
[2.532s] [ext: omni.kit.menu.edit-1.1.24] startup
[2.536s] [ext: omni.kit.menu.file-1.1.14] startup
[2.537s] [ext: omni.kit.profiler.window-2.2.3] startup
[2.543s] [ext: omni.kit.menu.stage-1.2.5] startup
[2.545s] [ext: omni.isaac.occupancy_map-1.0.3] startup
[2.549s] [ext: omni.importer.mjcf-1.1.1] startup
[2.554s] [ext: omni.graph.window.action-1.28.0] startup
[2.559s] [ext: omni.kit.property.camera-1.0.8] startup
[2.561s] [ext: omni.kit.property.light-1.0.10] startup
[2.562s] [ext: omni.kit.property.geometry-1.3.1] startup
[2.565s] [ext: omni.hydra.scene_api-0.1.2] startup
[2.568s] [ext: omni.kit.property.audio-1.0.14] startup
[2.570s] [ext: omni.kit.property.render-1.1.2] startup
[2.571s] [ext: omni.kit.property.transform-1.5.9] startup
[2.574s] [ext: omni.kit.property.material-1.10.8] startup
[2.578s] [ext: omni.kit.widget.layers-1.8.0] startup
[2.586s] [ext: omni.kit.property.isaac-0.2.3] startup
[2.587s] [ext: omni.kit.property.bundle-1.3.1] startup
[2.588s] [ext: omni.sensors.nv.common-1.2.2-isaac-1] startup
[2.596s] [ext: omni.kit.property.layer-1.1.8] startup
[2.598s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[2.599s] [ext: omni.isaac.scene_blox-0.1.2] startup
[2.600s] [ext: omni.sensors.nv.materials-1.2.1-isaac-1] startup
[2.602s] [ext: omni.sensors.nv.wpm-1.2.1-isaac-1] startup
[2.602s] [ext: omni.kit.viewport.actions-106.0.2] startup
[2.605s] [ext: omni.sensors.nv.lidar-1.2.2-isaac-1] startup
[2.608s] [ext: omni.sensors.nv.radar-1.2.1-isaac-1] startup
[2.613s] [ext: omni.kit.viewport.menubar.display-107.0.2] startup
[2.614s] [ext: omni.kit.manipulator.transform-104.7.4] startup
[2.616s] [ext: omni.kit.widget.toolbar-1.7.2] startup
[2.620s] [ext: omni.sensors.tiled-0.0.6] startup
[2.622s] [ext: omni.sensors.nv.ids-1.1.0-isaac-1] startup
[2.625s] [ext: omni.isaac.range_sensor-3.1.2] startup
[2.633s] [ext: omni.usdphysics.ui-106.1.9] startup
[2.648s] [ext: omni.physx.commands-106.1.9] startup
[2.651s] [ext: omni.kit.manipulator.tool.snap-1.5.11] startup
[2.655s] [ext: omni.isaac.sensor-12.9.1] startup
[2.701s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[2.704s] [ext: omni.physx.ui-106.1.9] startup
[2.731s] [ext: omni.isaac.quadruped-2.0.1] startup
[2.737s] [ext: omni.kit.viewport.manipulator.transform-107.0.2] startup
[2.739s] [ext: omni.physx.demos-106.1.9] startup
[2.752s] [ext: omni.kit.property.physx-106.1.9] startup
[2.803s] [ext: omni.kit.widget.calendar-1.0.8] startup
[2.806s] [ext: omni.kit.manipulator.prim.core-107.0.4] startup
[2.811s] [ext: omni.fabric.commands-1.1.5] startup
[2.813s] [ext: omni.physx.vehicle-106.1.9] startup
[2.826s] [ext: omni.kit.widget.extended_searchfield-1.0.28] startup
[2.833s] [ext: omni.kit.manipulator.prim.fabric-107.0.3] startup
[2.835s] [ext: omni.kit.manipulator.prim.usd-107.0.2] startup
[2.836s] [ext: omni.kit.widget.timeline-105.0.1] startup
[2.838s] [ext: omni.kit.window.commands-0.2.6] startup
[2.839s] [ext: omni.physx.camera-106.1.9] startup
[2.848s] [ext: omni.kit.manipulator.camera-105.0.5] startup
[2.850s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[2.853s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[2.854s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[2.855s] [ext: omni.kit.window.toolbar-1.6.1] startup
[2.856s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[2.858s] [ext: omni.kit.viewport.menubar.render-106.1.1] startup
[2.859s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[2.862s] [ext: omni.physx.cct-106.1.9] startup
[2.870s] [ext: omni.physx.graph-106.1.9] startup
[2.885s] [ext: omni.physx.supportui-106.1.9] startup
[2.899s] [ext: omni.physx.telemetry-106.1.9] startup
[2.902s] [ext: omni.graph.ui_nodes-1.26.0] startup
[2.907s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[2.907s] [ext: omni.isaac.universal_robots-0.3.5] startup
[2.908s] [ext: omni.kit.window.console-0.2.13] startup
[2.922s] [ext: omni.kit.window.script_editor-1.7.6] startup
[2.924s] [ext: omni.kit.menu.create-1.0.16] startup
[2.926s] [ext: omni.graph.bundle.action-2.4.1] startup
[2.928s] [ext: omni.physx.bundle-106.1.9] startup
[2.929s] [ext: omni.rtx.window.settings-0.6.17] startup
[2.933s] [ext: omni.kit.window.status_bar-0.1.7] startup
[2.937s] [ext: omni.kit.window.title-1.1.5] startup
[2.940s] [ext: omni.replicator.isaac-1.15.2] startup
[2.958s] [ext: omni.replicator.replicator_yaml-2.0.6] startup
[2.974s] [ext: omni.rtx.settings.core-0.6.3] startup
[2.983s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[2.990s] [ext: semantics.schema.editor-0.3.8] startup
[2.994s] [ext: semantics.schema.property-1.0.4] startup
[2.995s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[2.995s] [ext: omni.isaac.utils-1.0.1] startup
[2.998s] [ext: omni.isaac.cloner-0.8.1] startup
[3.000s] [ext: omni.importer.urdf-1.14.1] startup
[3.029s] [ext: omni.kit.window.stats-0.1.6] startup
[3.033s] [ext: omni.isaac.sim.python-4.2.0] startup
[3.034s] Simulation App Starting
[4.413s] app ready
2024-10-18 16:42:13 [4,842ms] [Warning] [omni.kit.imgui_renderer.plugin] _createExtendCursor: No windowing.
[5.088s] Simulation App Startup Complete
2024-10-18 16:42:16 [7,187ms] [Warning] [curobo] Running in headless mode: native
[7.263s] [ext: omni.kit.asset_converter-2.1.21] startup
[7.279s] [ext: omni.kit.tool.asset_importer-2.5.5] startup
[7.328s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[7.330s] [ext: omni.kit.browser.core-2.3.11] startup
[7.333s] [ext: omni.kit.browser.folder.core-1.9.13] startup
[7.336s] [ext: omni.isaac.asset_browser-0.5.1] startup
[7.380s] [ext: omni.kit.livestream.core-4.3.6] startup
[7.383s] [ext: omni.kit.streamsdk.plugins-4.5.3] startup
[7.383s] [ext: omni.kit.livestream.native-4.1.0] startup
Warning: Possible version incompatibility. Attempting to load carb::cudainterop::CudaInterop with version v0.13 against v0.11.
Failed to open [/var/run/utmp]
Active user not found. Using default user [kiosk]Streaming server started.
**** Click Play to start simulation *****
main: thread_init: already added for thread
2024-10-18 16:42:26 [17,150ms] [Warning] [carb.livestream.plugin] onClientEventRaised: NVST_CCE_DISCONNECTED when m_connectionCount 0 != 1  <-- happens when I try to connect
streaming client
any help is greatly appreciated, thank you!
Hello and thanks for your question. So, you are saying that you can get Isaac Sim to stream correctly, but not the CuRobo example ? I not familiar with this example.
@rdarbha
Please provide the exact command how you run IsaacSim in the docker.
Do you run the OV streaming client on the same physical/virtual server/PC?
Hello, thank you for getting back. It looks like the cuRobo code base is old and has not been update. I have figured a way to fix this issue.
I have gone through the documentation and rewrote the code for headless streaming from docker.
try:
    # Third Party
    import isaacsim
except ImportError:
    pass
# Third Party
import torch
# Standard Library
import argparse
from scipy.spatial.transform import Rotation as R
from isaacsim import SimulationApp
# This sample enables a livestream server to connect to when running headless
CONFIG = {
    "width": 1280,
    "height": 720,
    "window_width": 1920,
    "window_height": 1080,
    "headless": True,
    "hide_ui": False,  # Show the GUI
    "renderer": "RayTracedLighting",
    "display_options": 3286,  # Set display options to show default grid
# Start the omniverse application
kit = SimulationApp(launch_config=CONFIG)
from omni.isaac.core.utils.extensions import enable_extension
# Default Livestream settings
kit.set_setting("/app/window/drawMouse", True)
kit.set_setting("/app/livestream/proto", "ws")
kit.set_setting("/ngx/enabled", False)
# Note: Only one livestream extension can be enabled at a time
# Enable Native Livestream extension
# Default App: Streaming Client from the Omniverse Launcher
enable_extension("omni.kit.streamsdk.plugins-3.2.1")
enable_extension("omni.kit.livestream.core-3.2.0")
enable_extension("omni.kit.livestream.native")
# Enable WebRTC Livestream extension
# Default URL: http://localhost:8211/streaming/webrtc-client/
# enable_extension("omni.services.streamclient.webrtc")
# Third Party
import carb
import numpy as np
from omni.isaac.core import World
from omni.isaac.core.materials import OmniPBR
from omni.isaac.core.objects import sphere
# CuRobo
# from curobo.wrap.reacher.ik_solver import IKSolver, IKSolverConfig
from curobo.geom.sdf.world import CollisionCheckerType
from curobo.geom.types import WorldConfig, Cuboid, Mesh
from curobo.types.base import TensorDeviceType
from curobo.types.math import Pose
########### OV #################
from curobo.util.logger import setup_curobo_logger
from curobo.util.usd_helper import UsdHelper
from curobo.util_file import get_world_configs_path, join_path, load_yaml
from curobo.wrap.model.robot_world import RobotWorld, RobotWorldConfig
from omni.isaac.core.robots import Robot
from omni.isaac.core.objects import DynamicCuboid
from omni.isaac.core.objects.ground_plane import GroundPlane
from omni.isaac.core.physics_context import PhysicsContext
from omni.isaac.core.objects import VisualSphere
# CuRobo
from curobo.util.logger import log_warn
from curobo.util.usd_helper import set_prim_transform
from curobo.types.state import JointState
from typing import Dict, List
ISAAC_SIM_23 = False
try:
    # Third Party
    from omni.isaac.urdf import _urdf  # isaacsim 2022.2
except ImportError:
    # Third Party
    from omni.importer.urdf import _urdf  # isaac sim 2023.1 or above
    ISAAC_SIM_23 = True
# Standard Library
from typing import Optional
# Third Party
# CuRobo
from curobo.util_file import get_assets_path, get_filename, get_path_of_dir, join_path
from curobo.wrap.reacher.motion_gen import MotionGen, MotionGenConfig, MotionGenPlanConfig
def quaternion_to_euler(q):
    """Convert quaternion to Euler angles (roll, pitch, yaw)"""
    r = R.from_quat(q)
    return r.as_euler('xyz', degrees=True)
def euler_to_quaternion(euler):
    """Convert Euler angles to quaternion"""
    r = R.from_euler('xyz', euler, degrees=True)
    return r.as_quat()
def calculate_face_centers(position, orientation, scale):
    # Create rotation matrix from quaternion
    rot_matrix = R.from_quat(orientation).as_matrix()
    # Half extents of the cuboid
    half_extents = scale / 2
    # Define the face centers in local coordinates
    local_centers = np.array([
        [half_extents[0], 0, 0],  # +X face
        [-half_extents[0], 0, 0], # -X face
        [0, half_extents[1], 0],  # +Y face
        [0, -half_extents[1], 0], # -Y face
        [0, 0, half_extents[2]],  # +Z face
        [0, 0, -half_extents[2]]  # -Z face
    # Transform local centers to world coordinates
    world_centers = []
    for local_center in local_centers:
        world_center = np.dot(rot_matrix, local_center) + position
        world_centers.append(world_center)
    return np.array(world_centers)
def add_robot_to_scene(
    robot_config: Dict,
    my_world: World,
    load_from_usd: bool = False,
    subroot: str = "",
    robot_name: str = "robot",
    position: np.array = np.array([0, 0, 0]),
    urdf_interface = _urdf.acquire_urdf_interface()
    # Set the settings in the import config
    import_config = _urdf.ImportConfig()
    import_config.merge_fixed_joints = False
    import_config.convex_decomp = False
    import_config.fix_base = True
    import_config.make_default_prim = True
    import_config.self_collision = False
    import_config.create_physics_scene = True
    import_config.import_inertia_tensor = False
    import_config.default_drive_strength = 1047.19751
    import_config.default_position_drive_damping = 52.35988
    import_config.default_drive_type = _urdf.UrdfJointTargetType.JOINT_DRIVE_POSITION
    import_config.distance_scale = 1
    import_config.density = 0.0
    asset_path = get_assets_path()
    if (
    "external_asset_path" in robot_config["kinematics"]
    and robot_config["kinematics"]["external_asset_path"] is not None
        asset_path = robot_config["kinematics"]["external_asset_path"]
    full_path = join_path(asset_path, robot_config["kinematics"]["urdf_path"])
    robot_path = get_path_of_dir(full_path)
    filename = get_filename(full_path)
    imported_robot = urdf_interface.parse_urdf(robot_path, filename, import_config)
    dest_path = subroot
    robot_path = urdf_interface.import_robot(
        robot_path,
        filename,
        imported_robot,
        import_config,
        dest_path,
    base_link_name = robot_config["kinematics"]["base_link"]
    robot_p = Robot(
        prim_path=robot_path + "/" + base_link_name,
        name=robot_name,
    robot_prim = robot_p.prim
    stage = robot_prim.GetStage()
    linkp = stage.GetPrimAtPath(robot_path)
    set_prim_transform(linkp, [position[0], position[1], position[2], 1, 0, 0, 0])
    robot = my_world.scene.add(robot_p)
    return robot, robot_path
def main():
    usd_help = UsdHelper()
    act_distance = 0.4
    ignore_list = ["/World/target", "/World/defaultGroundPlane"]
    # assuming obstacles are in objects_path:
    my_world = World(stage_units_in_meters=1.0)
    my_world.scene.add_default_ground_plane()
    dynamicCuboid = DynamicCuboid(prim_path="/World/cube", position=np.array([-.5, -.2, 1.0]), scale=np.array([.5, .5, .5]), color=np.array([.2,.3,0.]))
    cuboid = my_world.scene.add(
        dynamicCuboid
    face_markers = []
    for i in range(6):
        marker = VisualSphere(prim_path=f"/World/face_marker_{i}",
                              name=f"face_marker_{i}",
                              radius=0.05,
                              color=np.array([1.0, 0.0, 0.0]))
        my_world.scene.add(marker)
        face_markers.append(marker)
    stage = my_world.stage
    usd_help.load_stage(stage)
    xform = stage.DefinePrim("/World", "Xform")
    stage.SetDefaultPrim(xform)
    stage.DefinePrim("/curobo", "Xform")
    tensor_args = TensorDeviceType()
    world_config_1 = WorldConfig(cuboid=[dynamicCuboid])
    initial_quat = [0, 0, 0, 1]
    initial_euler = quaternion_to_euler(initial_quat)
    print(f"Initial Euler angles: {initial_euler}")
    # Keep roll and pitch constant, iterate over yaw
    roll, pitch, yaw = initial_euler[0], initial_euler[1], initial_euler[2]
    yaw_range = np.linspace(0, 360, 37)  # 0 to 360 degrees in 10-degree steps
    print("Loading robot...")
    robot_cfg = load_yaml("/root/Project/config/curobo.yml")["robot_cfg"]
    print(robot_cfg["kinematics"])
    print("Robot config loaded.")
    j_names = robot_cfg["kinematics"]["cspace"]["joint_names"]
    default_config = robot_cfg["kinematics"]["cspace"]["retract_config"]
    robot, robot_prim_path = add_robot_to_scene(robot_cfg, my_world, position=np.array([-1.5, -.2, 1.0]))
    idx_list = [robot.get_dof_index(x) for x in j_names]
    robot.set_joint_positions(default_config, idx_list)
    robot._articulation_view.set_max_efforts(
        values=np.array([5000 for i in range(len(idx_list))]), joint_indices=idx_list
    world_cfg_table = WorldConfig.from_dict(
        load_yaml("/root/curobo/src/curobo/curobo/content/configs/world/collision_table.yml")
    world_cfg_table.cuboid[0].pose[2] -= 0.02
    world_cfg1 = WorldConfig.from_dict(
    ).get_mesh_world()
    world_cfg1.mesh[0].name += "_mesh"
    world_cfg1.mesh[0].pose[2] = -10.5
    world_cfg = WorldConfig(cuboid=world_cfg_table.cuboid, mesh=world_cfg1.mesh)
    setup_curobo_logger("warn")
    past_pose = None
    n_obstacle_cuboids = 30
    n_obstacle_mesh = 10
    motion_gen_config = MotionGenConfig.load_from_robot_config(
        robot_cfg,
        world_cfg,
        tensor_args,
        collision_checker_type=CollisionCheckerType.MESH,
        use_cuda_graph=True,
        interpolation_dt=0.03,
        collision_cache={"obb": n_obstacle_cuboids, "mesh": n_obstacle_mesh},
        collision_activation_distance=0.025,
        fixed_iters_trajopt=True,
        maximum_trajectory_dt=0.5,
    motion_gen = MotionGen(motion_gen_config)
    # Initialize motion generators for both arms
    motion_gen_left = MotionGen(motion_gen_config)
    motion_gen_right = MotionGen(motion_gen_config)
    articulation_controller = robot.get_articulation_controller()
    # Get initial joint positions
    initial_joint_positions = robot.get_joint_positions()
    link_names = motion_gen.kinematics.link_names
    ee_link_name = motion_gen.kinematics.ee_link
    kin_state = motion_gen.kinematics.get_state(motion_gen.get_retract_config().view(1, -1))
    link_retract_pose = kin_state.link_pose
    print("ee_link_name: ", ee_link_name)
    while kit._app.is_running() and not kit.is_exiting():
        # Update the simulation
        position = np.array([-.5, -.2, 1.0])
        quat = euler_to_quaternion([roll, pitch, yaw])
        face_centers = calculate_face_centers(position, quat, np.array([.25, .25, .25]))
        for i, center in enumerate(face_centers):
            face_markers[i].set_world_pose(position=center)
        # Choose two face markers as targets (e.g., face 0 for left arm, face 5 for right arm)
        left_target = face_centers[0]
        #load left target on cuda tensor
        left_target = torch.tensor(left_target, device="cuda:0", dtype=torch.float32)
        right_target = face_centers[5]
        #load right target on cuda tensor
        right_target = torch.tensor(right_target, device="cuda:0", dtype=torch.float32)
        quat = torch.tensor(np.array([1, 0, 0, 0]), device="cuda:0", dtype=torch.float32)
        sim_js = robot.get_joints_state()
        sim_js_names = robot.dof_names
        cu_js = JointState(
            position=tensor_args.to_device(sim_js.positions),
            velocity=tensor_args.to_device(sim_js.velocities) * 0.0,
            acceleration=tensor_args.to_device(sim_js.velocities) * 0.0,
            jerk=tensor_args.to_device(sim_js.velocities) * 0.0,
            joint_names=sim_js_names,
        cu_js = cu_js.get_ordered_joint_state(motion_gen.kinematics.joint_names)
        # compute curobo solution:
        ik_goal = Pose(
            position=tensor_args.to_device(ee_translation_goal),
            quaternion=tensor_args.to_device(ee_orientation_teleop_goal),
        # add link poses:
        link_poses = {}
        for i in target_links.keys():
            c_p, c_rot = target_links[i].get_world_pose()
            link_poses[i] = Pose(
                position=tensor_args.to_device(c_p),
                quaternion=tensor_args.to_device(c_rot),
        result = motion_gen.plan_single(
            cu_js.unsqueeze(0), ik_goal, plan_config.clone(), link_poses=link_poses
        # Generate motion for left arm
        left_result = motion_gen_left.plan_single(
            initial_joint_positions,
            Pose(position=left_target, quaternion=quat),
        # Generate motion for right arm
        right_result = motion_gen_right.plan_single(
            Pose(position=right_target, quaternion=quat),
        # Check if both plans were successful
        if left_result.success and right_result.success:
            # Interpolate and apply joint positions for both arms
            left_traj = left_result.get_interpolated_plan()
            right_traj = right_result.get_interpolated_plan()
            for i in range(len(left_traj)):
                # Combine left and right arm positions
                combined_positions = np.concatenate([left_traj[i], right_traj[i]])
                # Apply the joint positions to the robot
                articulation_controller.apply_action(combined_positions)
                # Step the simulation
                my_world.step(render=True)
                kit.update()
        # Update initial joint positions for the next iteration
        initial_joint_positions = robot.get_joints_positions()
        # Step the world and render
        kit.update()
    # Cleanup
    kit.close()
if __name__ == "__main__":
    main()
However I’m unable to make the robot move with cuRoBo. which may not be directly linked to isaacsim.
Are you still having issues with this?
