I cannot enable the mult-gpu render in Isacc SIm 2022.1.0 and linking memory is reported.
My environment is as below.
Software: Isacc SIm 2022.1.0
OS: Ubuntu 20.04
Displayer Info (when running the below code):
| NVIDIA-SMI 510.73.05 Driver Version: 510.73.05 CUDA Version: 11.6 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:17:00.0 Off | N/A |
| 25% 34C P8 33W / 260W | 818MiB / 11264MiB | 30% Default |
| | | N/A |
| 1 NVIDIA GeForce ... Off | 00000000:65:00.0 On | N/A |
| 52% 66C P2 208W / 260W | 2641MiB / 11264MiB | 98% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1439 G /usr/lib/xorg/Xorg 4MiB |
| 0 N/A N/A 2180 G /usr/lib/xorg/Xorg 4MiB |
| 0 N/A N/A 511962 C+G ....0/kit/python/bin/python3 802MiB |
| 1 N/A N/A 1439 G /usr/lib/xorg/Xorg 53MiB |
| 1 N/A N/A 2180 G /usr/lib/xorg/Xorg 226MiB |
| 1 N/A N/A 2320 G /usr/bin/gnome-shell 49MiB |
| 1 N/A N/A 198391 G ...857603391979510381,131072 126MiB |
| 1 N/A N/A 471586 G ...RendererForSitePerProcess 31MiB |
| 1 N/A N/A 511962 C+G ....0/kit/python/bin/python3 2133MiB |
Code:
#launch Isaac Sim before any other imports
#default first two lines in any standalone application
from omni.isaac.kit import SimulationApp
import numpy as np
config = {
'multi_gpu': True,
'headless': False,
simulation_app = SimulationApp(config) # we can also run as headless.
from omni.isaac.core import World
from omni.isaac.core.objects import DynamicCuboid
import numpy as np
world = World()
world.scene.add_default_ground_plane()
fancy_cube_list = []
for i in range(50):
fancy_cube_list.append(world.scene.add(
DynamicCuboid(
prim_path="/World/random_cube_" + str(i),
name="fancy_cube_" + str(i),
position=np.array([0, 0, 10 * np.random.randn()]),
size=np.array([0.5015, 0.5015, 0.5015]),
color=np.array([0, 0, np.random.random()]),
# Resetting the world needs to be called before querying anything related to an articulation specifically.
# Its recommended to always do a reset after adding your assets, for physics handles to be propagated properly
world.reset()
for i in range(1000):
# position, orientation = fancy_cube_list[0].get_world_pose()
# linear_velocity = fancy_cube_list[0].get_linear_velocity()
# # will be shown on terminal
# print("Cube position is : " + str(position))
# print("Cube's orientation is : " + str(orientation))
# print("Cube's linear velocity is : " + str(linear_velocity))
# # we have control over stepping physics and rendering in this workflow
# # things run in sync
world.step(render=True) # execute one physics step and one rendering step
simulation_app.close() # close Isaac Sim
Terminal info:
Passing the following args to the base kit application: []
[Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[Info] [carb] Logging to file: /home/zzj/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/logs/Kit/Isaac-Sim/2022.1/kit_20220614_145904.log
[0.186s] [ext: omni.stats-0.0.0] startup
[0.202s] [ext: omni.gpu_foundation-0.0.0] startup
2022-06-14 06:59:04 [201ms] [Warning] [carb] FrameworkImpl::setDefaultPlugin(client: omni.gpu_foundation_factory.plugin, desc : [carb::graphics::Graphics v2.5], plugin : carb.graphics-vulkan.plugin) failed. Plugin selection is locked, because the interface was previously acquired by:
[0.211s] [ext: carb.windowing.plugins-1.0.0] startup
[0.227s] [ext: omni.assets.plugins-0.0.0] startup
[0.228s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 510.73.5 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 2080 Ti | Yes: 0 | | 11510 MB | 10de | 0 |
| | | | | | 1e07 | 3290ab32.. |
| 1 | NVIDIA GeForce RTX 2080 Ti | Yes: 1 | | 11510 MB | 10de | 0 |
| | | | | | 1e07 | ced825f2.. |
| OS: Linux zzj, Version: 5.13.0-48-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12013000 (1.20.13.0)
| Processor: Intel(R) Core(TM) i9-9820X CPU @ 3.30GHz | Cores: Unknown | Logical: 20
| Total Memory (MB): 31775 | Free Memory: 27334
| Total Page/Swap (MB): 47679 | Free Page/Swap: 47679
2022-06-14 06:59:06 [1,688ms] [Warning] [carb.cudainterop.plugin] On Linux only, CUDA and the display driver does not support IOMMU-enabled bare-metal PCIe peer to peer memory copy.
However, CUDA and the display driver does support IOMMU via VM pass through. As a consequence, users on Linux,
when running on a native bare metal system, should disable the IOMMU. The IOMMU should be enabled and the VFIO driver
be used as a PCIe pass through for virtual machines.
[1.710s] [ext: omni.kit.pipapi-0.0.0] startup
[1.721s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.730s] [ext: omni.isaac.core_archive-0.3.0] startup
[1.777s] [ext: omni.usd.config-1.0.0] startup
[1.779s] [ext: omni.usd.libs-1.0.0] startup
[1.920s] [ext: omni.isaac.ml_archive-0.1.0] startup
[1.982s] [ext: omni.kit.loop-isaac-0.1.0] startup
[1.983s] [ext: omni.kit.async_engine-0.0.0] startup
[1.985s] [ext: omni.appwindow-1.0.0] startup
[1.997s] [ext: omni.client-0.1.0] startup
[2.017s] [ext: omni.kit.test-0.0.0] startup
[2.075s] [ext: omni.kit.renderer.core-0.0.0] startup
[2.310s] [ext: omni.ui-2.10.3] startup
[2.327s] [ext: carb.audio-0.1.0] startup
[2.347s] [ext: omni.kit.mainwindow-0.0.0] startup
[2.350s] [ext: omni.uiaudio-1.0.0] startup
[2.352s] [ext: omni.kit.uiapp-0.0.0] startup
[2.353s] [ext: omni.usd.schema.physics-1.0.0] startup
[2.399s] [ext: omni.usd.schema.audio-0.0.0] startup
[2.407s] [ext: omni.usd.schema.semantics-0.0.0] startup
[2.418s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[2.426s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.464s] [ext: omni.kit.commands-1.2.2] startup
[2.471s] [ext: omni.timeline-1.0.2] startup
[2.474s] [ext: omni.hydra.scene_delegate-0.2.0] startup
[2.480s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[2.481s] [ext: omni.usd-1.5.3] startup
[2.778s] [ext: omni.kit.asset_converter-1.2.30] startup
[2.805s] [ext: omni.usd.schema.isaac-0.2.0] startup
[2.848s] [ext: omni.usd.schema.physx-0.0.0] startup
[2.876s] [ext: omni.kit.search_core-1.0.2] startup
[2.878s] [ext: omni.renderer-rtx-0.0.0] startup
[2.879s] [ext: omni.kit.widget.graph-1.4.2] startup
[2.888s] [ext: omni.kit.widget.filebrowser-2.2.26] startup
[2.893s] [ext: omni.kit.window.popup_dialog-2.0.7] startup
[2.898s] [ext: omni.mdl.neuraylib-0.1.0] startup
[2.902s] [ext: omni.kit.widget.path_field-2.0.3] startup
[2.903s] [ext: omni.kit.widget.versioning-1.3.8] startup
[2.905s] [ext: omni.kit.notification_manager-1.0.5] startup
[2.911s] [ext: omni.kit.widget.browser_bar-2.0.3] startup
[2.912s] [ext: omni.kit.menu.utils-1.2.11] startup
[2.923s] [ext: omni.kit.window.filepicker-2.4.29] startup
OmniAssetFileFormat
[2.976s] [ext: omni.mdl-0.1.0] startup
[3.032s] [ext: omni.kit.menu.create-1.0.2] startup
[3.034s] [ext: omni.kit.window.file_exporter-1.0.4] startup
[3.035s] [ext: omni.kit.window.drop_support-1.0.0] startup
[3.036s] [ext: omni.kit.material.library-1.3.10] startup
[3.038s] [ext: omni.kit.window.property-1.6.3] startup
[3.040s] [ext: omni.kit.context_menu-1.3.9] startup
[3.043s] [ext: omni.kit.window.file_importer-1.0.4] startup
[3.044s] [ext: omni.kit.stage_templates-1.1.2] startup
[3.046s] [ext: omni.kit.widget.stage-2.6.15] startup
[3.050s] [ext: omni.kit.window.file-1.3.16] startup
[3.052s] [ext: omni.debugdraw-0.1.0] startup
[3.057s] [ext: omni.kit.window.content_browser-2.4.28] startup
[3.077s] [ext: omni.kit.widget.prompt-1.0.1] startup
[3.077s] [ext: omni.kit.property.usd-3.14.8] startup
[3.110s] [ext: omni.hydra.engine.stats-1.0.0] startup
[3.116s] [ext: omni.kit.widget.settings-1.0.0] startup
[3.117s] [ext: omni.graph.tools-1.3.5] startup
[3.141s] [ext: omni.graph.core-2.27.0] startup
[3.145s] [ext: omni.hydra.rtx-0.1.0] startup
[3.153s] [ext: omni.kit.viewport.legacy_gizmos-1.0.0] startup
[3.156s] [ext: omni.ui_query-1.1.1] startup
[3.158s] [ext: omni.graph-1.22.1] startup
[3.210s] [ext: omni.kit.window.viewport-0.0.0] startup
[4.539s] [ext: omni.kit.window.preferences-1.2.1] startup
[4.574s] [ext: omni.kit.ui_test-1.2.0] startup
[4.576s] [ext: omni.graph.ui-1.6.1] startup
[4.600s] [ext: omni.kvdb-0.0.0] startup
[4.603s] [ext: omni.kit.widget.searchfield-1.0.6] startup
[4.605s] [ext: omni.convexdecomposition-1.4.12] startup
[4.608s] [ext: omni.graph.action-1.17.0] startup
[4.620s] [ext: omni.localcache-0.0.0] startup
[4.623s] [ext: omni.usdphysics-1.4.12] startup
[4.626s] [ext: omni.graph.scriptnode-0.5.0] startup
[4.628s] [ext: omni.physx-1.4.12-5.1] startup
[4.671s] [ext: omni.kit.usd_undo-0.1.0] startup
[4.676s] [ext: omni.graph.nodes-1.25.0] startup
[4.713s] [ext: omni.physx.commands-1.4.12-5.1] startup
[4.774s] [ext: omni.syntheticdata-0.2.1] startup
[4.807s] [ext: omni.physx.ui-1.4.12-5.1] startup
[4.896s] [ext: omni.warp-0.2.1] startup
Warp initialized:
Version: 0.2.1
Using CUDA device: NVIDIA GeForce RTX 2080 Ti
Using CPU compiler: /usr/bin/g++
[6.630s] [ext: omni.kit.renderer.capture-0.0.0] startup
[6.634s] [ext: omni.kit.property.material-1.8.5] startup
[6.637s] [ext: omni.physx.demos-1.4.12-5.1] startup
[6.640s] [ext: omni.physics.tensors-0.1.0] startup
[6.647s] [ext: omni.kit.property.physx-0.1.0] startup
2022-06-14 06:59:11 [6,730ms] [Warning] [omni.physx.plugin] Deprecated: getSimulationEventStream is deprecated, please use getSimulationEventStreamV2
[6.741s] [ext: omni.kit.window.toolbar-1.2.4] startup
[6.747s] [ext: omni.physx.tensors-0.1.0] startup
[6.753s] [ext: omni.physx.vehicle-1.4.12-5.1] startup
[6.764s] [ext: omni.physx.tests-1.4.12-5.1] startup
[6.807s] [ext: omni.kit.numpy.common-0.1.0] startup
[6.810s] [ext: omni.physx.camera-1.4.12-5.1] startup
[6.817s] [ext: omni.physx.cct-1.4.12-5.1] startup
[6.869s] [ext: omni.isaac.version-1.0.0] startup
[6.870s] [ext: omni.isaac.dynamic_control-1.0.0] startup
[6.878s] [ext: omni.physx.bundle-1.4.12-5.1] startup
[6.878s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[6.882s] [ext: omni.command.usd-1.0.1] startup
[6.886s] [ext: omni.isaac.core-1.15.1] startup
[7.057s] [ext: omni.replicator.core-1.2.0] startup
[7.253s] [ext: omni.kit.window.extensions-1.1.0] startup
[7.258s] [ext: omni.isaac.core_nodes-0.9.0] startup
[7.268s] [ext: omni.isaac.ui-0.2.1] startup
[7.270s] [ext: omni.kit.window.script_editor-1.6.2] startup
[7.277s] [ext: omni.isaac.wheeled_robots-0.5.4] startup
[7.288s] [ext: omni.kit.menu.common-1.0.0] startup
[7.289s] [ext: omni.kit.graph.delegate.default-1.0.15] startup
[7.291s] [ext: omni.kit.graph.delegate.modern-1.6.0] startup
[7.293s] [ext: omni.kit.widget.zoombar-1.0.3] startup
[7.294s] [ext: omni.kit.graph.editor.core-1.3.3] startup
[7.296s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[7.298s] [ext: omni.kit.browser.core-2.0.12] startup
[7.302s] [ext: omni.kit.graph.widget.variables-2.0.2] startup
[7.304s] [ext: omni.kit.window.stage-2.3.7] startup
[7.307s] [ext: omni.kit.browser.folder.core-1.1.13] startup
[7.310s] [ext: omni.graph.window.core-1.22.1] startup
[7.316s] [ext: omni.isaac.lula-1.1.0] startup
[7.326s] [ext: omni.graph.instancing-1.1.4] startup
[7.332s] [ext: omni.graph.window.action-1.3.8] startup
[7.333s] [ext: omni.graph.tutorials-1.1.2] startup
[7.348s] [ext: omni.rtx.window.settings-0.6.1] startup
[7.354s] [ext: omni.isaac.motion_planning-0.2.0] startup
[7.360s] [ext: omni.graph.bundle.action-1.0.0] startup
[7.361s] [ext: omni.rtx.settings.core-0.5.5] startup
[7.365s] [ext: omni.isaac.motion_generation-3.1.2] startup
[7.370s] [ext: omni.isaac.kit-0.1.9] startup
[7.370s] [ext: omni.isaac.debug_draw-0.1.2] startup
[7.376s] [ext: omni.kit.selection-0.1.0] startup
[7.377s] [ext: omni.isaac.franka-0.0.0] startup
[7.379s] [ext: omni.kit.widget.layers-1.5.17] startup
[7.392s] [ext: omni.kit.menu.edit-1.0.6] startup
[7.394s] [ext: omni.isaac.isaac_sensor-0.3.4] startup
2022-06-14 06:59:11 [7,391ms] [Warning] [omni.physx.plugin] Deprecated: getSimulationEventStream is deprecated, please use getSimulationEventStreamV2
[7.401s] [ext: omni.kit.widget.live-0.1.0] startup
[7.405s] [ext: omni.isaac.surface_gripper-0.1.2] startup
[7.410s] [ext: omni.kit.property.layer-1.1.2] startup
[7.412s] [ext: omni.isaac.range_sensor-0.4.2] startup
[7.439s] [ext: omni.graph.window.generic-1.3.8] startup
[7.441s] [ext: omni.isaac.utils-0.1.11] startup
[7.444s] [ext: omni.isaac.universal_robots-0.2.1] startup
[7.445s] [ext: omni.kit.property.audio-1.0.5] startup
[7.446s] [ext: omni.kit.property.skel-1.0.1] startup
[7.448s] [ext: omni.kit.property.render-1.1.0] startup
[7.449s] [ext: omni.kit.property.camera-1.0.3] startup
[7.450s] [ext: omni.kit.property.geometry-1.2.0] startup
[7.452s] [ext: omni.kit.property.light-1.0.5] startup
[7.453s] [ext: omni.kit.property.transform-1.0.2] startup
[7.457s] [ext: omni.isaac.occupancy_map-0.2.4] startup
[7.469s] [ext: omni.ui.scene-1.4.6] startup
[7.476s] [ext: omni.kit.window.console-0.2.0] startup
[7.482s] [ext: omni.kit.window.status_bar-0.1.1] startup
[7.486s] [ext: omni.kit.property.bundle-1.2.4] startup
[7.488s] [ext: omni.kit.menu.file-1.0.8] startup
[7.489s] [ext: omni.kit.manipulator.viewport-1.0.6] startup
[7.491s] [ext: omni.isaac.urdf-0.2.2] startup
[7.521s] [ext: omni.isaac.dofbot-0.2.0] startup
[7.522s] [ext: omni.kit.window.title-1.1.1] startup
[7.525s] [ext: omni.kit.profiler.window-1.4.4] startup
[7.531s] [ext: omni.graph.visualization.nodes-1.1.1] startup
[7.536s] [ext: omni.isaac.synthetic_utils-0.2.1] startup
[7.543s] [ext: semantics.schema.editor-0.2.2] startup
[7.546s] [ext: omni.isaac.sim.python-2022.1.0] startup
[7.547s] Simulation App Starting
2022-06-14 06:59:12 [7,543ms] [Warning] [gpu.foundation.plugin] Different GPUs have different available VRAM. The texture streaming system will be limited to the lower VRAM number
[8.601s] app ready
[37.744s] Simulation App Startup Complete
2022-06-14 06:59:42 [37,873ms] [Warning] [omni.client.python] Waiting for a request that has taken longer than 20ms to complete:
File "/home/zzj/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.examples/omni/isaac/examples/user_examples/my_applicaiton.py", line 19, in <module>
File "/home/zzj/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core/omni/isaac/core/scenes/scene.py", line 184, in add_default_ground_plane
File "/home/zzj/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core/omni/isaac/core/utils/nucleus.py", line 494, in get_assets_root_path
File "/home/zzj/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core/omni/isaac/core/utils/nucleus.py", line 183, in check_server
File "/home/zzj/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extscore/omni.client/omni/client/__init__.py", line 133, in stat
2022-06-14 06:59:43 [38,935ms] [Warning] [carb.flatcache.plugin] Type tag does not have a corresponding USD type
2022-06-14 06:59:43 [38,949ms] [Warning] [gpu.foundation.plugin] Requesting texture to use texture streaming, but the service isn't available.The texture will be created as a regular resource.
[49.276s] Simulation App Shutting Down
[49.276s] [ext: omni.isaac.sim.python-2022.1.0] shutdown
[49.276s] [ext: omni.graph.visualization.nodes-1.1.1] shutdown
[49.295s] [ext: omni.graph.bundle.action-1.0.0] shutdown
[49.295s] [ext: omni.graph.window.action-1.3.8] shutdown
[49.324s] [ext: omni.graph.window.generic-1.3.8] shutdown
[49.361s] [ext: omni.graph.window.core-1.22.1] shutdown
[49.379s] [ext: omni.isaac.universal_robots-0.2.1] shutdown
[49.380s] [ext: omni.isaac.surface_gripper-0.1.2] shutdown
[49.494s] [ext: omni.isaac.wheeled_robots-0.5.4] shutdown
[49.494s] [ext: omni.isaac.dofbot-0.2.0] shutdown
[49.494s] [ext: omni.isaac.franka-0.0.0] shutdown
[49.494s] [ext: omni.isaac.motion_generation-3.1.2] shutdown
[49.495s] [ext: omni.isaac.isaac_sensor-0.3.4] shutdown
[49.624s] [ext: omni.isaac.motion_planning-0.2.0] shutdown
[49.628s] [ext: omni.isaac.core_nodes-0.9.0] shutdown
[49.629s] [ext: omni.isaac.range_sensor-0.4.2] shutdown
[49.666s] [ext: omni.isaac.occupancy_map-0.2.4] shutdown
[49.889s] [ext: omni.isaac.synthetic_utils-0.2.1] shutdown
[49.889s] [ext: omni.isaac.utils-0.1.11] shutdown
[50.003s] [ext: omni.isaac.core-1.15.1] shutdown
[50.004s] [ext: omni.isaac.ml_archive-0.1.0] shutdown
[50.004s] [ext: omni.isaac.core_archive-0.3.0] shutdown
[50.004s] [ext: omni.isaac.debug_draw-0.1.2] shutdown
[50.005s] [ext: omni.isaac.dynamic_control-1.0.0] shutdown
[50.153s] [ext: omni.isaac.kit-0.1.9] shutdown
[50.153s] [ext: omni.isaac.lula-1.1.0] shutdown
[50.173s] [ext: omni.isaac.urdf-0.2.2] shutdown
[50.319s] [ext: omni.isaac.ui-0.2.1] shutdown
[50.319s] [ext: omni.isaac.version-1.0.0] shutdown
[50.320s] [ext: omni.kit.asset_converter-1.2.30] shutdown
[50.339s] [ext: omni.graph.instancing-1.1.4] shutdown
[50.341s] [ext: omni.kit.browser.folder.core-1.1.13] shutdown
[50.360s] [ext: omni.kit.browser.core-2.0.12] shutdown
[50.380s] [ext: omni.kit.graph.widget.variables-2.0.2] shutdown
[50.398s] [ext: omni.kit.graph.editor.core-1.3.3] shutdown
[50.418s] [ext: omni.kit.graph.delegate.default-1.0.15] shutdown
[50.435s] [ext: omni.kit.graph.delegate.modern-1.6.0] shutdown
[50.453s] [ext: semantics.schema.editor-0.2.2] shutdown
[50.581s] [ext: omni.replicator.core-1.2.0] shutdown
[50.600s] [ext: omni.kit.primitive.mesh-1.0.0] shutdown
[50.607s] [ext: omni.syntheticdata-0.2.1] shutdown
[50.609s] [ext: omni.graph.tutorials-1.1.2] shutdown
[50.610s] [ext: omni.graph.nodes-1.25.0] shutdown
[50.611s] [ext: omni.graph.scriptnode-0.5.0] shutdown
[50.611s] [ext: omni.graph.action-1.17.0] shutdown
[50.612s] [ext: omni.graph.ui-1.6.1] shutdown
2022-06-14 06:59:55 [50,705ms] [Warning] [omni.kit.menu.utils.scripts.utils] omni.kit.menu.utils remove_menu_items "Create" failed list.remove(x): x not in list
[50.735s] [ext: omni.warp-0.2.1] shutdown
[50.752s] [ext: omni.graph-1.22.1] shutdown
2022-06-14 06:59:55 [50,765ms] [Warning] [omni.ext.impl._internal] omni.graph-1.22.1 -> <class 'omni.graph.core._impl.extension.PublicExtension'>: extension object is still alive, something holds a reference on it. References: ["[0]:type: <class 'frame'>, id: 170194736", "[1]:type: <class 'frame'>, id: 352673584", "[2]:type: <class 'frame'>, id: 215364544", "[3]:type: <class 'frame'>, id: 161615712", "[4]:type: <class 'frame'>, id: 354001216", '[*] ...']
[50.773s] [ext: omni.kit.menu.edit-1.0.6] shutdown
[50.780s] [ext: omni.command.usd-1.0.1] shutdown
[50.780s] [ext: omni.physx.bundle-1.4.12-5.1] shutdown
[50.780s] [ext: omni.physx.cct-1.4.12-5.1] shutdown
[50.798s] [ext: omni.physx.tests-1.4.12-5.1] shutdown
[50.814s] [ext: omni.kit.window.extensions-1.1.0] shutdown
[50.814s] [ext: omni.kit.manipulator.viewport-1.0.6] shutdown
[50.830s] [ext: omni.ui.scene-1.4.6] shutdown
[50.830s] [ext: omni.rtx.settings.core-0.5.5] shutdown
[50.833s] [ext: omni.physx.vehicle-1.4.12-5.1] shutdown
[50.868s] [ext: omni.physx.camera-1.4.12-5.1] shutdown
[50.884s] [ext: omni.physx.demos-1.4.12-5.1] shutdown
[50.900s] [ext: omni.kit.property.physx-0.1.0] shutdown
[50.919s] [ext: omni.physx.ui-1.4.12-5.1] shutdown
[50.944s] [ext: omni.kit.widget.searchfield-1.0.6] shutdown
[50.959s] [ext: omni.kit.ui_test-1.2.0] shutdown
[50.960s] [ext: omni.ui_query-1.1.1] shutdown
[50.960s] [ext: omni.kit.window.preferences-1.2.1] shutdown
2022-06-14 06:59:55 [50,983ms] [Warning] [omni.ext.impl._internal] omni.kit.window.preferences-1.2.1 -> <class 'omni.kit.window.preferences.scripts.preferences_window.PreferencesExtension'>: extension object is still alive, something holds a reference on it. References: ["[0]:type: <class 'frame'>, id: 338787616", "[1]:type: <class 'frame'>, id: 345521632", "[2]:type: <class 'frame'>, id: 170070976"]
[50.991s] [ext: omni.rtx.window.settings-0.6.1] shutdown
[50.991s] [ext: omni.kit.property.bundle-1.2.4] shutdown
[50.991s] [ext: omni.kit.property.audio-1.0.5] shutdown
[50.992s] [ext: omni.kit.property.layer-1.1.2] shutdown
[50.992s] [ext: omni.kit.widget.layers-1.5.17] shutdown
[50.993s] [ext: omni.kit.property.transform-1.0.2] shutdown
[50.993s] [ext: omni.kit.property.material-1.8.5] shutdown
[50.993s] [ext: omni.kit.property.skel-1.0.1] shutdown
[50.994s] [ext: omni.kit.property.camera-1.0.3] shutdown
[50.994s] [ext: omni.kit.property.geometry-1.2.0] shutdown
[50.994s] [ext: omni.kit.property.light-1.0.5] shutdown
[50.994s] [ext: omni.kit.property.render-1.1.0] shutdown
[50.994s] [ext: omni.kit.property.usd-3.14.8] shutdown
2022-06-14 06:59:55 [51,010ms] [Warning] [omni.ext.impl._internal] omni.kit.property.usd-3.14.8 -> <class 'omni.kit.property.usd.widgets.UsdPropertyWidgets'>: extension object is still alive, something holds a reference on it. References: ["[0]:type: <class 'frame'>, id: 215287488", "[1]:type: <class 'frame'>, id: 215761776", "[2]:type: <class 'cell'>, id: 139908661001744"]
[51.017s] [ext: omni.kit.window.content_browser-2.4.28] shutdown
2022-06-14 06:59:55 [51,042ms] [Warning] [omni.ext.impl._internal] omni.kit.window.content_browser-2.4.28 -> <class 'omni.kit.window.content_browser.extension.ContentBrowserExtension'>: extension object is still alive, something holds a reference on it. References: ["[0]:type: <class 'frame'>, id: 139908666533904", "[1]:type: <class 'frame'>, id: 212623392", "[2]:type: <class 'frame'>, id: 154844560"]
[51.050s] [ext: omni.kit.menu.file-1.0.8] shutdown
[51.059s] [ext: omni.kit.window.file-1.3.16] shutdown
[51.059s] [ext: omni.kit.window.file_exporter-1.0.4] shutdown
[51.059s] [ext: omni.kit.window.file_importer-1.0.4] shutdown
[51.060s] [ext: omni.kit.window.stage-2.3.7] shutdown
[51.060s] [ext: omni.kit.widget.stage-2.6.15] shutdown
[51.060s] [ext: omni.kit.window.filepicker-2.4.29] shutdown
[51.060s] [ext: omni.kit.widget.filebrowser-2.2.26] shutdown
[51.060s] [ext: omni.kit.search_core-1.0.2] shutdown
[51.061s] [ext: omni.kit.window.status_bar-0.1.1] shutdown
[51.062s] [ext: omni.kit.window.viewport-0.0.0] shutdown
[58.096s] [ext: omni.kit.window.toolbar-1.2.4] shutdown
[58.097s] [ext: omni.kit.context_menu-1.3.9] shutdown
[58.098s] [ext: omni.kit.material.library-1.3.10] shutdown
[58.101s] [ext: omni.kit.window.popup_dialog-2.0.7] shutdown
[58.101s] [ext: omni.kit.window.property-1.6.3] shutdown
[58.101s] [ext: omni.kit.widget.browser_bar-2.0.3] shutdown
[58.101s] [ext: omni.kit.widget.path_field-2.0.3] shutdown
[58.101s] [ext: omni.kit.widget.prompt-1.0.1] shutdown
[58.101s] [ext: omni.kit.selection-0.1.0] shutdown
[58.101s] [ext: omni.kit.notification_manager-1.0.5] shutdown
[58.102s] [ext: omni.kit.widget.graph-1.4.2] shutdown
[58.102s] [ext: omni.kit.widget.live-0.1.0] shutdown
[58.103s] [ext: omni.kit.window.script_editor-1.6.2] shutdown
[58.103s] [ext: omni.kit.window.console-0.2.0] shutdown
[58.104s] [ext: omni.kit.menu.common-1.0.0] shutdown
[58.104s] [ext: omni.kit.menu.create-1.0.2] shutdown
[58.105s] [ext: omni.kit.menu.utils-1.2.11] shutdown
[58.105s] [ext: omni.kit.profiler.window-1.4.4] shutdown
[58.123s] [ext: omni.kit.widget.settings-1.0.0] shutdown
[58.123s] [ext: omni.kit.uiapp-0.0.0] shutdown
[58.123s] [ext: omni.kit.mainwindow-0.0.0] shutdown
[58.123s] [ext: omni.kit.widget.versioning-1.3.8] shutdown
[58.123s] [ext: omni.kit.widget.zoombar-1.0.3] shutdown
[58.140s] [ext: omni.kit.window.drop_support-1.0.0] shutdown
[58.140s] [ext: omni.ui-2.10.3] shutdown
[58.140s] [ext: omni.physx.commands-1.4.12-5.1] shutdown
[58.156s] [ext: omni.kit.usd_undo-0.1.0] shutdown
[58.156s] [ext: omni.kit.test-0.0.0] shutdown
[58.157s] [ext: omni.kit.window.title-1.1.1] shutdown
2022-06-14 07:00:02 [58,169ms] [Warning] [omni.ext.impl._internal] omni.kit.window.title-1.1.1 -> <class 'omni.kit.window.title.title.WindowTitle'>: extension object is still alive, something holds a reference on it. References: ["[0]:type: <class 'frame'>, id: 41060304"]
[58.176s] [ext: omni.kit.renderer.capture-0.0.0] shutdown
[58.177s] [ext: omni.kit.renderer.core-0.0.0] shutdown
2022-06-14 07:00:02 [58,180ms] [Warning] [omni.kit.renderer.plugin] Found 14 dangling textures
[58.222s] [ext: omni.appwindow-1.0.0] shutdown
[58.223s] [ext: omni.kit.loop-isaac-0.1.0] shutdown
[58.223s] [ext: omni.usd.schema.isaac-0.2.0] shutdown
[58.224s] [ext: omni.physx.tensors-0.1.0] shutdown
[58.225s] [ext: omni.physx-1.4.12-5.1] shutdown
[58.253s] [ext: omni.convexdecomposition-1.4.12] shutdown
[58.269s] [ext: omni.localcache-0.0.0] shutdown
[58.285s] [ext: omni.kvdb-0.0.0] shutdown
[58.300s] [ext: omni.physics.tensors-0.1.0] shutdown
[58.315s] [ext: omni.usdphysics-1.4.12] shutdown
[58.315s] [ext: omni.usd.schema.physx-0.0.0] shutdown
[58.331s] [ext: omni.graph.core-2.27.0] shutdown
[58.331s] [ext: omni.hydra.engine.stats-1.0.0] shutdown
[58.331s] [ext: omni.debugdraw-0.1.0] shutdown
[58.331s] [ext: omni.kit.stage_templates-1.1.2] shutdown
[58.331s] [ext: omni.kit.viewport.legacy_gizmos-1.0.0] shutdown
[58.332s] [ext: omni.usd-1.5.3] shutdown
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000000 (/tmp/carb.NqQBWd/plus.24x32.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000001 (/tmp/carb.NqQBWd/angle_left.32x32.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000002 (/tmp/carb.NqQBWd/angle_right.32x32.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000003 (/tmp/carb.NqQBWd/bookmark_grey.36x36.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000004 (/tmp/carb.NqQBWd/settings.28x40.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000005 (/tmp/carb.NqQBWd/search.32x32.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000006 (/tmp/carb.NqQBWd/filter.28x32.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000007 (/tmp/carb.NqQBWd/list.32x40.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000008 (/tmp/carb.NqQBWd/toolbar_select_model.56x56.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000009 (/tmp/carb.NqQBWd/toolbar_select_prim.56x56.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x10000000a (/tmp/carb.NqQBWd/toolbar_select_models.56x56.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x10000000b (/tmp/carb.NqQBWd/toolbar_move_global.56x56.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x10000000c (/tmp/carb.NqQBWd/toolbar_rotate_global.56x56.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x10000000d (/tmp/carb.NqQBWd/toolbar_scale.56x56.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x10000000e (/tmp/carb.NqQBWd/toolbar_snap.56x56.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x10000000f (/tmp/carb.NqQBWd/toolbar_play.56x56.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000010 (/tmp/carb.NqQBWd/toolbar_pause.56x56.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000011 (/tmp/carb.NqQBWd/filter.28x28.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000012 (/tmp/carb.NqQBWd/options.28x28.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000013 (/tmp/carb.NqQBWd/eye_header.44x28.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000014 (/tmp/carb.NqQBWd/options.28x32.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000015 (/tmp/carb.NqQBWd/layers.36x36.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000016 (/tmp/carb.NqQBWd/layer_save.28x28.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000017 (/tmp/carb.NqQBWd/layers_switch_local.84x44.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000018 (/tmp/carb.NqQBWd/cloud.28x28.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000019 (/tmp/carb.NqQBWd/drop_down.12x12.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x10000001a (/tmp/carb.NqQBWd/layers_switch_global.84x44.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x10000001b (/tmp/carb.NqQBWd/external_link.52x52.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x10000001c (/tmp/carb.NqQBWd/new_layer.52x52.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x10000001d (/tmp/carb.NqQBWd/trash.44x44.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x200000028 (/tmp/carb.NqQBWd/toolbar_stop.56x56.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000031 (/tmp/carb.NqQBWd/Plus.20x20.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000032 (/tmp/carb.NqQBWd/layers.40x40.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000033 (/tmp/carb.NqQBWd/layer_delta.24x24.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000034 (/tmp/carb.NqQBWd/Prim.40x40.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000035 (/tmp/carb.NqQBWd/sensor_icon.52x28.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned snapshot handle 0x100000036 (/tmp/carb.NqQBWd/Xform.40x40.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000000 (/tmp/carb.NqQBWd/plus.24x32.png)
2022-06-14 07:00:02 [58,324ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000001 (/tmp/carb.NqQBWd/angle_left.32x32.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000002 (/tmp/carb.NqQBWd/angle_right.32x32.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000003 (/tmp/carb.NqQBWd/bookmark_grey.36x36.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000004 (/tmp/carb.NqQBWd/search.32x32.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000005 (/tmp/carb.NqQBWd/settings.28x40.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000006 (/tmp/carb.NqQBWd/filter.28x32.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000008 (/tmp/carb.NqQBWd/list.32x40.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000009 (/tmp/carb.NqQBWd/toolbar_select_model.56x56.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x10000000a (/tmp/carb.NqQBWd/toolbar_select_prim.56x56.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x10000000b (/tmp/carb.NqQBWd/toolbar_select_models.56x56.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x10000000c (/tmp/carb.NqQBWd/toolbar_move_global.56x56.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x10000000d (/tmp/carb.NqQBWd/toolbar_rotate_global.56x56.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x10000000e (/tmp/carb.NqQBWd/toolbar_scale.56x56.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x10000000f (/tmp/carb.NqQBWd/toolbar_snap.56x56.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000010 (/tmp/carb.NqQBWd/toolbar_play.56x56.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000011 (/tmp/carb.NqQBWd/toolbar_pause.56x56.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000012 (/tmp/carb.NqQBWd/filter.28x28.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000013 (/tmp/carb.NqQBWd/options.28x28.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000014 (/tmp/carb.NqQBWd/eye_header.44x28.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000015 (/tmp/carb.NqQBWd/options.28x32.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000016 (/tmp/carb.NqQBWd/layers.36x36.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000017 (/tmp/carb.NqQBWd/layer_save.28x28.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000018 (/tmp/carb.NqQBWd/layers_switch_local.84x44.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000019 (/tmp/carb.NqQBWd/layers_switch_global.84x44.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x10000001a (/tmp/carb.NqQBWd/cloud.28x28.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x10000001b (/tmp/carb.NqQBWd/drop_down.12x12.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x10000001c (/tmp/carb.NqQBWd/external_link.52x52.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x10000001d (/tmp/carb.NqQBWd/new_layer.52x52.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x10000001e (/tmp/carb.NqQBWd/trash.44x44.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000032 (/tmp/carb.NqQBWd/Plus.20x20.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000033 (/tmp/carb.NqQBWd/layers.40x40.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000034 (/tmp/carb.NqQBWd/Prim.40x40.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000035 (/tmp/carb.NqQBWd/layer_delta.24x24.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000036 (/tmp/carb.NqQBWd/sensor_icon.52x28.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000037 (/tmp/carb.NqQBWd/toolbar_stop.56x56.png)
2022-06-14 07:00:02 [58,325ms] [Warning] [carb.assets.plugin] Evicting asset type c1237a43d569db21 v0.1 orphaned asset 0x100000038 (/tmp/carb.NqQBWd/Xform.40x40.png)
[58.343s] [ext: omni.usd.schema.physics-1.0.0] shutdown
[58.362s] [ext: omni.uiaudio-1.0.0] shutdown
[58.362s] [ext: omni.kit.audiodeviceenum-1.0.0] shutdown
[58.363s] [ext: carb.audio-0.1.0] shutdown
[58.363s] [ext: omni.kit.renderer.init-0.0.0] shutdown
2022-06-14 07:00:03 [58,759ms] [Error] [carb.graphics-vulkan.plugin] pipelineLayouts: 3 or descriptorSetLayouts: 3 is leaking memory. Missing call to destroyResourceBindingSignature()
2022-06-14 07:00:03 [58,806ms] [Error] [carb.graphics-vulkan.plugin] pipelineLayouts: 3 or descriptorSetLayouts: 3 is leaking memory. Missing call to destroyResourceBindingSignature()
[58.873s] [ext: carb.windowing.plugins-1.0.0] shutdown
[58.874s] [ext: omni.renderer-rtx-0.0.0] shutdown
[58.875s] [ext: omni.client-0.1.0] shutdown
[58.875s] [ext: omni.assets.plugins-0.0.0] shutdown
[58.876s] [ext: omni.hydra.scene_delegate-0.2.0] shutdown
[58.876s] [ext: omni.gpu_foundation-0.0.0] shutdown
[58.876s] [ext: omni.hydra.rtx-0.1.0] shutdown
[58.881s] [ext: omni.kit.async_engine-0.0.0] shutdown
[58.881s] [ext: omni.kit.commands-1.2.2] shutdown
[58.882s] [ext: omni.mdl-0.1.0] shutdown
[58.882s] [ext: omni.graph.tools-1.3.5] shutdown
[58.882s] [ext: omni.kit.numpy.common-0.1.0] shutdown
[58.882s] [ext: omni.kit.pip_archive-0.0.0] shutdown
[58.882s] [ext: omni.kit.pipapi-0.0.0] shutdown
[58.882s] [ext: omni.mdl.neuraylib-0.1.0] shutdown
[58.882s] [ext: omni.stats-0.0.0] shutdown
[58.882s] [ext: omni.timeline-1.0.2] shutdown
[58.882s] [ext: omni.usd.schema.omnigraph-1.0.0] shutdown
[58.882s] [ext: omni.usd.schema.semantics-0.0.0] shutdown
[58.882s] [ext: omni.usd.schema.anim-0.0.0] shutdown
[58.882s] [ext: omni.usd.schema.audio-0.0.0] shutdown
[58.883s] [ext: omni.usd.libs-1.0.0] shutdown
[58.887s] [ext: omni.usd.config-1.0.0] shutdown
[58.887s] [ext: omni.kit.widget.stage_icons-1.0.2] shutdown
Simulation App Shutdown Complete
