Hi guys,
Does anyone know the current output capacity of the Jetson Nano?
For my system, I need :
- 4x 1mA to power the base of 4x 2N2222A transitors with control the coil of a relay.
- 2x 0.1 mA to power also 2 2N2222A transistors for supply two LEDs.
The LEDs work properly but not the relay.
I think the GPIO haven’t the capacity to provide a sufficient amount of current…
And my command relay works ;) in case of doublt (I test with the pin 1 of the GPIO).
Best regards,
John
P.S: Attachement → schematic of the command relay
