I did by using same command as him, ./flash.sh on devkit then i switch the module on custom board.
So the whole process is to rebuild kernel when the source files are modified, then always reflash manually to be sure that modification are made.
| HDMI Output cannnot work in AGX Orin based CustomBoard 35.3.1 | 65 | 4758 | August 7, 2023 | |
| Custom board HDMI hotplug detect(HPD) did't work | 34 | 7962 | October 9, 2022 | |
| HDMI | 51 | 1006 | June 13, 2025 | |
| HDMI_BRING_UP | 35 | 849 | April 9, 2025 | |
| Unable to enable hdmi on jetson orin Nano for custom carrier board Jetpack 5.1.2 | 42 | 1854 | May 8, 2024 | |
| Configure display on AGX THOR | 34 | 454 | August 17, 2026 | |
| Enabling and display with HDMI on Custom Carrier Boards | 17 | 2845 | June 7, 2022 | |
| HDMI Display does not work after update to JetPack 5.0.2 | 50 | 9012 | September 28, 2022 | |
| HDMI direct output not functional on AGX Orin Industrial (p3701-0008) custom carrier — DCE ch[2] never created | 5 | 135 | May 14, 2026 | |
| Display is not workig in Jetson Orin Nano custom carrier board | 27 | 612 | April 14, 2025 |
