Above i attached the file please look once.
USB2_SOM_DP_0 and USB2_SOM_DN_0 (F12,F13) we are teken out pins from SOM directly to type c connector through VPX connector.
In Custom usb2_0 is not working could i change any where let me know.
If that means you want to make USB2-0 to be host mode only but not have any OTG function, please refer to above document link and modify the device tree to match host mode only case.
Hi sir, i gone through the document. i am using the same pins A10,A11 of SOM for usb , i connected the mouse while booting mouse light is working after dtb loading mouse not working.
can you please guide where i am missing
i disabled the cypress status = ādisabledā but it is not working.did i miss anything .
one more thing i want know confirmation from you if i change ODM data is there effect on usb and uart peripherals.
ODMDATA=āgbe-uphy-config-0,hsstp-lane-map-3,hsio-uphy-config-16,nvhs-uphy-config-0ā;
