I am designing a custom carrier board for Jetson Xavier nx module and I am trying to add a second IMX477 to the mix. Both cameras are meant to be in 2x CSI lane configuration but the main IMX477 has the CSI lanes 0-1 reserved for the possible of 4x configuration.
My question is does matter which CSI lane pairs I use for the second camera?
Currently I have connected it to the:
My first instinct was to use the CSI2 lanes but the CSI3 lanes are much more closer to the cameras connector therefore I’d like to use them if possible.
it’s by default support raspberry pi v3, imx477.
you may check reference camera driver as an example,
i.e. $public_sources/kernel_src/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-camera-jakku-rbpcv3-imx477.dtsi
furthermore,
please see-also Jetson Xavier NX Product Design Guide for [Table 9-3. CSI Configurations].
Thank you for your reply. So can I assume that these connections would work and that one can define in the camera driver which CSI port is being used for the camera and which pins are used for PWDN and MCLK.
