Hi,my hardware configuration are:
| Driver Version: 516.94 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 3070 | Yes: 0 | | 8043 MB | 10de | c9240000.. |
| | | | | | 2488 | 0 |
| OS: Windows, Version: 10.0, Build: 19044
| Processor: 12th Gen Intel(R) Core(TM) i7-12700F | Cores: 12 | Logical: 20
| Total Memory (MB): 65293 | Free Memory: 58424
| Total Page/Swap (MB): 75021 | Free Page/Swap: 65315
and my code of the replicator part is as follow:
def start(name):
#region read config
Material = []
Demos=[]
Material=Readfile(MaterialPath,ratio=6) #read the material path and save as a list
Demos=Readfile(DomePath)
print(len(Material))#about 150
print(len(Demos))#about 25
DemosIndex=np.random.randint(0, len(Demos)-1, size=1)[0]
#endregion
carb.settings.get_settings().set("/omni/replicator/RTSubframes", 5)
#rep.settings.set_render_pathtraced()
with rep.new_layer():
path=CarPath
portprims=["/Replicator/Ref_Xform/Ref/compound_23/port"]
mats = rep.create.material_omnipbr(diffuse=rep.distribution.uniform((0, 0, 0), (1, 1, 1)), count=100)
car = rep.create.from_usd(path)
camera=rep.create.camera(
position=cameraInitpos,
rotation=cameraInitrotation,
focus_distance=rep.distribution.normal(400.0, 100),
f_stop=0,
focal_length=8
rep.modify.semantics([("class", "port")], input_prims=portprims)
# region plane
def get_planeDR():
with car:
rep.randomizer.materials(materials=Material,input_prims =["/Replicator/Ref_Xform/Ref/compound_23/compound_23/Material_00"])
rep.randomizer.materials(materials=Material,input_prims=["/Replicator/Ref_Xform/Ref/compound_23/compound_23/Material_01"])
rep.randomizer.materials(materials=Material,input_prims=["/Replicator/Ref_Xform/Ref/compound_23/compound_23/Material_03"])
return car.node
#endregion
def get_PortDR():
spheres = rep.get.prims(semantics=[('class', "port")])
with spheres:
rep.randomizer.materials(materials=Material)
return spheres.node
def get_CameraDR():
with camera:
rep.modify.pose(
position=rep.distribution.uniform((cameraInitpos[0]-15, cameraInitpos[1]-20, cameraInitpos[2]-20),
(cameraInitpos[0]+15, cameraInitpos[1]+20, cameraInitpos[2]+20),
seed=np.random.randint(0, 1000, size=1)),
rotation=rep.distribution.uniform((cameraInitrotation[0]-5, cameraInitrotation[1]-5, cameraInitrotation[2]-30),(cameraInitrotation[0]+5,cameraInitrotation[1]+ 5,cameraInitrotation[2]+ 30)),
input_prims=["/Replicator/Camera_Xform/Camera"]
return camera.node
def get_Light1DR():
domelight = rep.create.light(
light_type="Dome",
rotation=rep.distribution.uniform((0, 0, 0), (0, 0, 360)),
texture=rep.distribution.choice(Demos)
return domelight.node
def get_GoblaLightDR():
goballight = rep.create.light(light_type="Sphere",
temperature=rep.distribution.normal(6500, 500),
intensity=rep.distribution.normal(3500000, 5000),
position=rep.distribution.uniform((-300, -300, 200), (300, 300, 300)),
rotation=rep.distribution.uniform((0, 0, 0), (360, 360, 360)),
scale=rep.distribution.uniform(50, 100),
count=1)
return goballight.node
rep.randomizer.register(get_planeDR)
rep.randomizer.register(get_PortDR)
rep.randomizer.register(get_CameraDR)
rep.randomizer.register(get_Light1DR)
rep.randomizer.register(get_GoblaLightDR)
numf=0
with rep.trigger.on_frame(num_frames=num_frames):
numf=numf+1
print("now frames is=",numf)
rep.randomizer.get_planeDR()
rep.randomizer.get_PortDR()
rep.randomizer.get_CameraDR()
rep.randomizer.get_Light1DR()
rep.randomizer.get_GoblaLightDR()
# Initialize and attach writer
writer = rep.WriterRegistry.get("BasicWriter")
output_directory = "C:/Users/robot/Desktop/writer/"
now = datetime.now()
timestr = now.strftime("%Y%m%d%H%M%S")
output_directory = output_directory + timestr
if os.path.exists(output_directory):
print("exist")
else:
os.makedirs(output_directory)
print("###################################Outputting data to ", output_directory)
writer.initialize(
output_dir=output_directory,
rgb=True,
bounding_box_2d_tight=True
RESOLUTION = (1024, 1024)
driver_rp = rep.create.render_product(camera, RESOLUTION)
writer.attach([driver_rp])
run_orchestrator()
the warning message when running are,It seems that there has no message about the IO bottleneck
[47.373s] app ready
[50.471s] Simulation App Startup Complete
120
27
2023-01-14 05:34:08 [50,963ms] [Warning] [carb.flatcache.plugin] UsdRelationship /Replicator/SDGPipeline/OgnGroup.inputs:prims has multiple targets, which is not supported
now frames is= 1
###################################Outputting data to C:/Users/robotkk/Desktop/writer/20230114133408
2023-01-14 05:34:08 [51,264ms] [Warning] [carb.flatcache.plugin] Type tag does not have a corresponding USD type
2023-01-14 05:34:10 [53,065ms] [Warning] [carb.flatcache.plugin] No source has valid data elemSize=8 array=0000025FEEC4EDC0 usdValid=0 cpuValid=0 gpuValid=0 gpuAllocedWithCuda=0
2023-01-14 05:34:10 [53,065ms] [Warning] [carb.flatcache.plugin] No source has valid data elemSize=8 array=0000025FEEC4CC00 usdValid=0 cpuValid=0 gpuValid=0 gpuAllocedWithCuda=0
2023-01-14 05:34:10 [53,065ms] [Warning] [carb.flatcache.plugin] No source has valid data elemSize=8 array=0000025FEEC4D6A0 usdValid=0 cpuValid=0 gpuValid=0 gpuAllocedWithCuda=0
2023-01-14 05:34:10 [53,065ms] [Warning] [carb.flatcache.plugin] No source has valid data elemSize=8 array=0000025FEEC0F080 usdValid=0 cpuValid=0 gpuValid=0 gpuAllocedWithCuda=0
2023-01-14 05:34:10 [53,066ms] [Warning] [carb.flatcache.plugin] No source has valid data elemSize=8 array=0000025FEEC4D420 usdValid=0 cpuValid=0 gpuValid=0 gpuAllocedWithCuda=0
2023-01-14 05:34:10 [53,067ms] [Warning] [carb.flatcache.plugin] No source has valid data elemSize=8 array=0000025FEEC0F080 usdValid=0 cpuValid=0 gpuValid=0 gpuAllocedWithCuda=0
2023-01-14 05:34:10 [53,068ms] [Warning] [omni.syntheticdata.plugin] OgnSdInstanceMapping missing valid input renderVar InstanceSemanticMapSD
2023-01-14 05:34:10 [53,281ms] [Warning] [carb.flatcache.plugin] No source has valid data elemSize=8 array=0000025FEEC4EDC0 usdValid=0 cpuValid=0 gpuValid=0 gpuAllocedWithCuda=0
2023-01-14 05:34:10 [53,282ms] [Warning] [carb.flatcache.plugin] No source has valid data elemSize=8 array=0000025FEEC4CC00 usdValid=0 cpuValid=0 gpuValid=0 gpuAllocedWithCuda=0
2023-01-14 05:34:10 [53,282ms] [Warning] [carb.flatcache.plugin] No source has valid data elemSize=8 array=0000025FEEC4D6A0 usdValid=0 cpuValid=0 gpuValid=0 gpuAllocedWithCuda=0
2023-01-14 05:34:10 [53,283ms] [Warning] [carb.flatcache.plugin] No source has valid data elemSize=8 array=0000025FEEC0F080 usdValid=0 cpuValid=0 gpuValid=0 gpuAllocedWithCuda=0
2023-01-14 05:34:10 [53,283ms] [Warning] [carb.flatcache.plugin] No source has valid data elemSize=8 array=0000025FEEC4D420 usdValid=0 cpuValid=0 gpuValid=0 gpuAllocedWithCuda=0
2023-01-14 05:34:17 [59,949ms] [Warning] [gpu.foundation.plugin] Requesting texture to use texture streaming, but the service isn't available.The texture will be created as a regular resource.
