Hi
I curious about date-time synconization in Jetson Orin Nano Dev Kit (8GB). My device was flashed with Jetpack 5.1.1 by micro-sd card approach. When I use my device at my home, it can connect to wifi (private IP address) and date-time sync automatically. Whereas, when I use this device at my company with ethernet cable (need to pass user and pass to authen bofore connecting to internet) date-time cann’t sync. I run timedatectl in terminal and it show “system clock synchronized: no”. Does automatic synchronization support both wi-fi and ethernet ?
Have you checked the value of system clock synchro when you connect to wifi? Are you sure it gives you “yes” in wifi case?
