I am trying to get fast boot time on TX1. In the effort to do so, I am trying to run Debian on the board and get rid of all the unnecessary packages and services Ubuntu provides.
Started with the net installer and after the installation completed I executed ./apply_binaries.sh on top of the FS. So far so good - got boot time of 8 seconds :) :)
Distributor ID: Debian
Description: Debian GNU/Linux 8.7 (jessie)
Release: 8.7
Codename: jessie
Then I continued with putting cuda and related accelerated libraries:
- CUDA framework - OK
- VisionWorks lib - OK
- OpenCV4Tegra - wasn’t so lucky:
Got some dependency errors here and Debian doesn’t seem to support the packages in any release so far, including testing and unstable.
The following packages have unmet dependencies:
libopencv4tegra : Depends: libavcodec54 (>= 6:9.1-1) but it is not installable or
libavcodec-extra-54 (>= 6:9.11) but it is not installable
Depends: libavformat54 (>= 6:9.1-1) but it is not installable
Depends: libavutil52 (>= 6:9.1-1) but it is not installable
Depends: libjpeg8 (>= 8c) but it is not installable
Depends: libswscale2 (>= 6:9.1-1) but it is not installable
Depends: cuda-cudart-7-0 but it is not installable
Depends: cuda-npp-7-0 but it is not installable
Depends: cuda-cufft-7-0 but it is not installable
E: Unable to correct problems, you have held broken packages.
The other problem I encountered was error from the famous nvcamera-daemon. Output on the console is like this:
[ 27.885299] Library at 0x403138: 0x400000 /usr/sbin/nvcamera-daemon
[ 27.893920] Library at 0x4022a8: 0x400000 /usr/sbin/nvcamera-daemon
[ 27.902466] vdso base = 0x7f8f8f8000
And this used to work in Ubuntu and my camera.
Any help with these issues, please?
