We’re pleased to announce that a developer preview release of JetPack 3.2 is now available for Jetson TX1 and TX2!
Highlights include support for TensorFlow models in TensorRT 3.0 GA, up to 15% perf/W improvement for DL applications, out-of-the-box kernel support for Docker, and support for Ubuntu 16.04 on your host PC (Ubuntu 14.04 on your host PC will also work, except cross-development packages for OpenCV and VisionWorks will be unavailable on that host PC). With JetPack 3.2, NVIDIA has also enabled Jetson TX2i for industrial environments. For more info, please view the full Release Notes.
I’m currently working on installing the newly released Jetpack 3.2 on a TX1.
I’m having to install some software on the TX1, by hand, and allow the JetPack installer to continue once I’ve done that.
At this point in the installation, the JetPack installer is complaining, in XTerm, about not being able to find:
libopencv4tegra-repo-dev_2.4.13-17-g5317135_arm64_l4t-r24.deb
libopencv4tegra-repo-python_2.4.13-17-g5317135_arm64_l4t-r24.deb
libopencv4tegra-repo-samples_2.4.13-17-g5317135_arm64_l4t-r24.deb
libopencv4tegra-repo_2.4.13-17-g5317135_arm64_l4t-r24.deb was downloaded by the installer, but the above files weren’t. This is the only libopencv file I see in the jetson_download folder.
Another issue I’ve run into with r28.1 and now r28.2 is that regulator@210 (tegra210-jetson-cv-power-fixed-p2180-p2597-a00.dtsi) was giving TEGRA_GPIO(S, 4) as it’s gpio.
This is the same pin as CAM0_RST_L, which is one of the reserved camera reset pins. Any driver that has this pin as a reset gpio will fail to probe because gpio_request() can’t take it away from the regulator. Below is an excerpt from the Sensor Driver Programming Guide showing that S4 is the Camera0 Reset pin.
In r24.2 this regulator had no GPIO, so to get my camera to probe I clear the gpio in my dtsi.
regulators {
/* Clear CAM1_RST_L as the regulator@210 gpio. */
en_vdd_vcm_2v8: regulator@210 {
gpio = <>;
I am addressing an error about VisionWorks as installing JetPack 3.2 for TX1 on the Ubuntu 16.04 host machine.
The Error is as follows:
Installing VisionWorks 1.6 failed.
Return Code: 1
Error installing libvisionworks libvisionworks-dev libvisionworks-samples to host, please check /home/wds/Desktop/JetPack/_installer/logs/visionworks_host.log for more details
Then I checked the install log file where said:
"[b]The following information may help to resolve the situation:
The following packages have unmet dependencies:
libvisionworks-samples : Depends: libgstreamer1.0-dev but it is not going to be installed
Depends: libgstreamer-plugins-base1.0-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages[/b]."
Yes, I did try to install those two packages you mentioned above separately. The results are same and are as follows:
"The following packages have unmet dependencies:
libgstreamer1.0-dev : Depends: libgstreamer1.0-0 (= 1.8.0-1) but 1.8.3-1~ubuntu0.1 is to be installed
Depends: gir1.2-gstreamer-1.0 (= 1.8.0-1) but 1.8.3-1~ubuntu0.1 is to be installed
E: Unable to correct problems, you have held broken packages.
Then I tried to install libgstreamer1.0-0 and gir1.2-gstreamer-1.0 , and the terminal indicated:
"wds@ubuntu16:~$ sudo apt-get install libgstreamer1.0-0
Reading package lists… Done
Building dependency tree
Reading state information… Done
libgstreamer1.0-0 is already the newest version (1.8.3-1~ubuntu0.1).
0 upgraded, 0 newly installed, 0 to remove and 95 not upgraded.
wds@ubuntu16:~$ sudo apt-get install gir1.2-gstreamer-1.0
gir1.2-gstreamer-1.0 is already the newest version (1.8.3-1~ubuntu0.1).
I looks like both versions of these packages are exceeded the requirement of VisionWorks.
Since I am a fresh user of Linux, Would you please show me how to degrade those versions? TIA!
Frustratingly, More and more errors has occurred.
In addtion, I foud a post (libgstreamer1.0 on R28.2 - Jetson TX2 - NVIDIA Developer Forums) which is about my problem. The author told me to modify the content of file named as “sources.list”. Do you have an idea about how to do that? Really appreciated!
You can use any text editor on that file (you need sudo due to permissions). A common simple editor is “nano”, e.g.:
sudo nano /etc/apt/sources.list
Lines with a starting “#” are comments. Other lines are active. Changes are noted only after you run the command “sudo apt update”.
If you don’t have nano installed use “sudo apt-get install nano”. The reminder bar at the bottom has the carot “^” symbol to note this is control key, e.g., control-x to exit is shown as “^x”.
Hello, Ivan,
Sorry for the delay! I still have no idea what was going wrong. I just made advance by install it in a totally fresh ubuntu16.04 running in another computer. Maybe you too can have a try!
The gstreamer dependency issue appears to be between vision works and ubuntu desktop. The JetPack downloaded rootfs that is flashed to device has a bunch of extras you don’t really need. So if you aren’t particularly interested in preserving the default software on target then this is a heavy handed nuclear option that did the trick for me with JetPack 3.2 and Ubuntu 16.04 on TX2:
Then press Enter key 3x times in XTerm on host to continue push and cross-compile of samples.
P.S. you can reclaim a fair amount of your SD card by purging things you don’t need on device like libreoffice however it is probably more advisable to customize your rootfs on host before flashing the system image with JetPack in the first place.
