Hello sir, I am trying to install Jetpack 3.3 on Jetson Tx1. I downloaded Jetpack 3.3 to my host machine. My host pc is using Ubuntu 16.04 and is a customized system having GeForce GTX 1080 Gpu with CUDA 9 and CUDnn 7. I already installed some Deep Learning Libraries like Caffe and Tensorflow on host system along with OpenCV 3.4.1. So when i am trying to extract Jetpack using given guide i am getting an error like:
root 11081 0.1 0.0 199828 2816 ? Ssl 16:30 0:01 /home/rohit/_installer/sudo_daemon -installer=10935 -d=/home/rohit/_installer/tmp
0
/home/rohit//_installer/run_command -c="apt install -y /home/rohit/jetpack_download/libopencv_3.3.1_amd64.deb" -d=/home/rohit//_installer/tmp -l=/home/rohit/_installer/logs//opencv_host.log
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Reading package lists...
Building dependency tree...
Reading state information...
The following packages were automatically installed and are no longer required:
linux-headers-4.13.0-43 linux-headers-4.13.0-43-generic
linux-headers-4.13.0-45 linux-headers-4.13.0-45-generic
linux-image-4.13.0-43-generic linux-image-4.13.0-45-generic
linux-image-extra-4.13.0-43-generic linux-image-extra-4.13.0-45-generic
linux-modules-extra-4.15.0-24-generic
Use 'apt autoremove' to remove them.
The following NEW packages will be installed:
libopencv
0 upgraded, 1 newly installed, 0 to remove and 260 not upgraded.
Need to get 0 B/27.7 MB of archives.
After this operation, 149 MB of additional disk space will be used.
Get:1 /home/rohit/jetpack_download/libopencv_3.3.1_amd64.deb libopencv amd64 3.3.1 [27.7 MB]
dpkg-preconfigure: unable to re-open stdin: No such file or directory
Selecting previously unselected package libopencv.
(Reading database ... 508304 files and directories currently installed.)
Preparing to unpack .../libopencv_3.3.1_amd64.deb ...
Unpacking libopencv (3.3.1) ...
Setting up libopencv (3.3.1) ...
Processing triggers for libc-bin (2.23-0ubuntu10) ...
root 11081 0.1 0.0 199828 3024 ? Ssl 16:30 0:01 /home/rohit/_installer/sudo_daemon -installer=10935 -d=/home/rohit/_installer/tmp
0
/home/rohit//_installer/run_command -c="apt install -y /home/rohit/jetpack_download/libopencv-dev_3.3.1_amd64.deb" -d=/home/rohit//_installer/tmp -l=/home/rohit/_installer/logs//opencv_host_dev.log
libhighgui-dev libilmbase-dev libopencv-calib3d2.4v5 libopencv-contrib2.4v5
libopencv-gpu2.4v5 libopencv-legacy2.4v5 libopencv-ml2.4v5
libopencv-ocl2.4v5 libopencv-photo2.4v5 libopencv-stitching2.4v5
libopencv-superres2.4v5 libopencv-ts2.4v5 libopencv-videostab2.4v5
libopencv2.4-java libopencv2.4-jni libopenexr-dev linux-headers-4.13.0-43
linux-headers-4.13.0-43-generic linux-headers-4.13.0-45
linux-headers-4.13.0-45-generic linux-image-4.13.0-43-generic
linux-image-4.13.0-45-generic linux-image-extra-4.13.0-43-generic
linux-image-extra-4.13.0-45-generic linux-modules-extra-4.15.0-24-generic
The following packages will be REMOVED:
libcv-dev libcvaux-dev libopencv-calib3d-dev libopencv-contrib-dev
libopencv-core-dev libopencv-features2d-dev libopencv-flann-dev
libopencv-gpu-dev libopencv-highgui-dev libopencv-imgproc-dev
libopencv-legacy-dev libopencv-ml-dev libopencv-objdetect-dev
libopencv-ocl-dev libopencv-photo-dev libopencv-stitching-dev
libopencv-superres-dev libopencv-ts-dev libopencv-video-dev
libopencv-videostab-dev
The following packages will be upgraded:
libopencv-dev
1 upgraded, 0 newly installed, 20 to remove and 260 not upgraded.
Need to get 0 B/1,120 kB of archives.
After this operation, 27.6 MB disk space will be freed.
Get:1 /home/rohit/jetpack_download/libopencv-dev_3.3.1_amd64.deb libopencv-dev amd64 3.3.1 [1,120 kB]
dpkg: libopencv-ts-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-dev depends on libopencv-ts-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
(Reading database ... 508362 files and directories currently installed.)
Removing libopencv-ts-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-core-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-imgproc-dev:amd64 depends on libopencv-core-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
libopencv-gpu-dev:amd64 depends on libopencv-core-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
libopencv-ml-dev:amd64 depends on libopencv-core-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
libcv-dev:amd64 depends on libopencv-core-dev.
libopencv-dev depends on libopencv-core-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
libopencv-flann-dev:amd64 depends on libopencv-core-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
libcvaux-dev:amd64 depends on libopencv-core-dev.
Removing libopencv-core-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-videostab-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-dev depends on libopencv-videostab-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-videostab-dev:amd64 is to be removed.
Removing libopencv-videostab-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-features2d-dev:amd64: dependency problems, but removing anyway as you requested:
libcv-dev:amd64 depends on libopencv-features2d-dev; however:
Package libopencv-features2d-dev:amd64 is to be removed.
libopencv-dev depends on libopencv-features2d-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
libopencv-calib3d-dev:amd64 depends on libopencv-features2d-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
libcvaux-dev:amd64 depends on libopencv-features2d-dev; however:
Removing libopencv-features2d-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-stitching-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-dev depends on libopencv-stitching-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-stitching-dev:amd64 is to be removed.
Removing libopencv-stitching-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-flann-dev:amd64: dependency problems, but removing anyway as you requested:
libcv-dev:amd64 depends on libopencv-flann-dev; however:
Package libopencv-flann-dev:amd64 is to be removed.
libopencv-dev depends on libopencv-flann-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Removing libopencv-flann-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-superres-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-dev depends on libopencv-superres-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-superres-dev:amd64 is to be removed.
Removing libopencv-superres-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-highgui-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-contrib-dev:amd64 depends on libopencv-highgui-dev (= 2.4.9.1+dfsg-1
5ubuntu1).
libopencv-dev depends on libopencv-highgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-highgui-dev:amd64 is to be removed.
libopencv-ocl-dev:amd64 depends on libopencv-highgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
libhighgui-dev:amd64 depends on libopencv-highgui-dev.
libopencv-objdetect-dev:amd64 depends on libopencv-highgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
libopencv-legacy-dev:amd64 depends on libopencv-highgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
Removing libopencv-highgui-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-ocl-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-dev depends on libopencv-ocl-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-ocl-dev:amd64 is to be removed.
Removing libopencv-ocl-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-video-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-contrib-dev:amd64 depends on libopencv-video-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-video-dev:amd64 is to be removed.
libcv-dev:amd64 depends on libopencv-video-dev; however:
libopencv-dev depends on libopencv-video-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
libopencv-legacy-dev:amd64 depends on libopencv-video-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
libcvaux-dev:amd64 depends on libopencv-video-dev; however:
Removing libopencv-video-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-imgproc-dev:amd64: dependency problems, but removing anyway as you requested:
libcv-dev:amd64 depends on libopencv-imgproc-dev; however:
Package libopencv-imgproc-dev:amd64 is to be removed.
libopencv-dev depends on libopencv-imgproc-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
libcvaux-dev:amd64 depends on libopencv-imgproc-dev; however:
libopencv-photo-dev:amd64 depends on libopencv-imgproc-dev (= 2.4.9.1+dfsg-1.5ubuntu1).
Removing libopencv-imgproc-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libcv-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-dev depends on libcv-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libcv-dev:amd64 is to be removed.
Removing libcv-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-legacy-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-dev depends on libopencv-legacy-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-legacy-dev:amd64 is to be removed.
libcvaux-dev:amd64 depends on libopencv-legacy-dev; however:
Removing libopencv-legacy-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-ml-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-contrib-dev:amd64 depends on libopencv-ml-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-ml-dev:amd64 is to be removed.
libopencv-dev depends on libopencv-ml-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Removing libopencv-ml-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-objdetect-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-contrib-dev:amd64 depends on libopencv-objdetect-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-objdetect-dev:amd64 is to be removed.
libopencv-dev depends on libopencv-objdetect-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
libcvaux-dev:amd64 depends on libopencv-objdetect-dev; however:
Removing libopencv-objdetect-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-photo-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-dev depends on libopencv-photo-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-photo-dev:amd64 is to be removed.
Removing libopencv-photo-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-gpu-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-dev depends on libopencv-gpu-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-gpu-dev:amd64 is to be removed.
Removing libopencv-gpu-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-contrib-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-dev depends on libopencv-contrib-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-contrib-dev:amd64 is to be removed.
libcvaux-dev:amd64 depends on libopencv-contrib-dev; however:
Removing libopencv-contrib-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: libopencv-calib3d-dev:amd64: dependency problems, but removing anyway as you requested:
libopencv-dev depends on libopencv-calib3d-dev (= 2.4.9.1+dfsg-1.5ubuntu1); however:
Package libopencv-calib3d-dev:amd64 is to be removed.
libcvaux-dev:amd64 depends on libopencv-calib3d-dev; however:
Removing libopencv-calib3d-dev:amd64 (2.4.9.1+dfsg-1.5ubuntu1) ...
(Reading database ... 508074 files and directories currently installed.)
Preparing to unpack .../libopencv-dev_3.3.1_amd64.deb ...
Unpacking libopencv-dev (3.3.1) over (2.4.9.1+dfsg-1.5ubuntu1) ...
dpkg: error processing archive /home/rohit/jetpack_download/libopencv-dev_3.3.1_amd64.deb (--unpack):
trying to overwrite '/usr/include/opencv/cvaux.hpp', which is also in package libcvaux-dev:amd64 2.4.9.1+dfsg-1.5ubuntu1
dpkg-deb (subprocess): decompressing archive member: internal gzip write error: Broken pipe
dpkg-deb: error: subprocess <decompress> returned error exit status 2
dpkg-deb (subprocess): cannot copy archive member from '/home/rohit/jetpack_download/libopencv-dev_3.3.1_amd64.deb' to decompressor pipe: failed to write (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
root 11081 0.1 0.0 199828 3252 ? Ssl 16:30 0:01 /home/rohit/_installer/sudo_daemon -installer=10935 -d=/home/rohit/_installer/tmp
0
/home/rohit//_installer/run_command -c="apt install -y /home/rohit/jetpack_download/libopencv-python_3.3.1_amd64.deb" -d=/home/rohit//_installer/tmp -l=/home/rohit/_installer/logs//opencv_host_python.log
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies:
libcvaux-dev : Depends: libopencv-core-dev but it is not installed
Depends: libopencv-imgproc-dev but it is not installed
Depends: libopencv-features2d-dev but it is not installed
Depends: libopencv-calib3d-dev but it is not installed
Depends: libopencv-objdetect-dev but it is not installed
Depends: libopencv-legacy-dev but it is not installed
Depends: libopencv-video-dev but it is not installed
Depends: libopencv-contrib-dev but it is not installed
libhighgui-dev : Depends: libopencv-highgui-dev but it is not installed
libopencv-dev : Depends: libopencv-core-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-ml-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-imgproc-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-video-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-objdetect-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-highgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-calib3d-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-flann-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-features2d-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-legacy-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-contrib-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-ts-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-photo-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-videostab-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-stitching-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-gpu-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-superres-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-ocl-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libcv-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
E: Unmet dependencies. Try using -f.
root 11081 0.1 0.0 199828 3264 ? Ssl 16:30 0:01 /home/rohit/_installer/sudo_daemon -installer=10935 -d=/home/rohit/_installer/tmp
0
/home/rohit//_installer/run_command -c="apt install -y /home/rohit/jetpack_download/libopencv-samples_3.3.1_amd64.deb" -d=/home/rohit//_installer/tmp -l=/home/rohit/_installer/logs//opencv_host_sample.log
root 11081 0.1 0.0 273560 3276 ? Ssl 16:30 0:02 /home/rohit/_installer/sudo_daemon -installer=10935 -d=/home/rohit/_installer/tmp
0
root 11081 0.1 0.0 273560 3336 ? Ssl 16:30 0:02 /home/rohit/_installer/sudo_daemon -installer=10935 -d=/home/rohit/_installer/tmp
0
root 11081 0.1 0.0 273560 3380 ? Ssl 16:30 0:02 /home/rohit/_installer/sudo_daemon -installer=10935 -d=/home/rohit/_installer/tmp
0
root 11081 0.1 0.0 273560 3392 ? Ssl 16:30 0:02 /home/rohit/_installer/sudo_daemon -installer=10935 -d=/home/rohit/_installer/tmp
0
Also i tried to remove the error by manually installing the required packages through terminal but got this error:
sudo apt -f install /home/rohit/jetpack_download/libopencv_3.3.1_amd64.deb /home/rohit/jetpack_download/libopencv-dev_3.3.1_amd64.deb /home/rohit/jetpack_download/libopencv-python_3.3.1_amd64.deb /home/rohit/jetpack_download/libopencv-samples_3.3.1_amd64.deb
Reading package lists... Done
Reading state information... Done
Correcting dependencies... Done
Note, selecting 'libopencv' instead of '/home/rohit/jetpack_download/libopencv_3.3.1_amd64.deb'
Note, selecting 'libopencv-dev' instead of '/home/rohit/jetpack_download/libopencv-dev_3.3.1_amd64.deb'
Note, selecting 'libopencv-python' instead of '/home/rohit/jetpack_download/libopencv-python_3.3.1_amd64.deb'
Note, selecting 'libopencv-samples' instead of '/home/rohit/jetpack_download/libopencv-samples_3.3.1_amd64.deb'
libopencv is already the newest version (3.3.1).
Use 'sudo apt autoremove' to remove them.
libcvaux-dev
libopencv-python libopencv-samples
libopencv-dev
1 upgraded, 2 newly installed, 1 to remove and 260 not upgraded.
Need to get 0 B/2,210 kB of archives.
After this operation, 7,948 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:2 /home/rohit/jetpack_download/libopencv-python_3.3.1_amd64.deb libopencv-python amd64 3.3.1 [906 kB]
Get:3 /home/rohit/jetpack_download/libopencv-samples_3.3.1_amd64.deb libopencv-samples amd64 3.3.1 [184 kB]
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Can you please suggest me how can i overcome this error ?
