While attempting to install Jetpack 3.2 on Jetson TX2 using host pc with ubuntu 16.04, following message pop up and cannot proceed.
Return Code: 1
Error: libopencv-python libopencv-samples cannot be installed on host. Please manually run following command in terminal to install packages before continuing:
sudo apt install /home/ladar/jetson/jetpack_download/libopencv_3.3.1_amd64.deb /home/ladar/jetson/jetpack_download/libopencv-dev_3.3.1_amd64.deb /home/ladar/jetson/jetpack_download/libopencv-python_3.3.1_amd64.deb /home/ladar/jetson/jetpack_download/libopencv-samples_3.3.1_amd64.deb
Seems like it fails to install opencv package however I already build installed opencv 3.3.1 on my PC.
I checked it by
$ dpkg -l | grep libopencv
ii libopencv 3.3.1 amd64 Open Computer Vision Library
ii libopencv-calib3d2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision Camera Calibration library
ii libopencv-contrib2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision contrib library
ii libopencv-core2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision core library
ii libopencv-dev 2.4.9.1+dfsg-1.5ubuntu1 amd64 development files for opencv
ii libopencv-features2d2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision Feature Detection and Descriptor Extraction library
ii libopencv-flann2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision Clustering and Search in Multi-Dimensional spaces library
ii libopencv-gpu2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision GPU library
ii libopencv-highgui2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision High-level GUI and Media I/O library
ii libopencv-imgproc2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision Image Processing library
ii libopencv-legacy2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision legacy library
ii libopencv-ml2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision Machine Learning library
ii libopencv-objdetect2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision Object Detection library
ii libopencv-ocl2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision OpenCL support library
ii libopencv-photo2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision computational photography library
ii libopencv-stitching2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision image stitching library
ii libopencv-superres2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision Super Resolution library
ii libopencv-ts2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision ts library
ii libopencv-video2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision Video analysis library
ii libopencv-videostab2.4v5:amd64 2.4.9.1+dfsg-1.5ubuntu1 amd64 computer vision video stabilization library
ii libopencv2.4-java 2.4.9.1+dfsg-1.5ubuntu1 all Java bindings for the computer vision library
ii libopencv2.4-jni 2.4.9.1+dfsg-1.5ubuntu1 amd64 Java jni library for the computer vision library
and
$ pkg-config --modversion opencv
3.3.1
Should I just ignore this and press NEXT button?
