When I compile the debugemu profiles, I still can’t step into device functions. It asks for a non-existant stub source file. Is there some trick to creating these? I tried several of the cuda samples and none of them seem to work out of the box.
e.ping
1
Try setting a breakpoint in the kernel and then running the program.
Related topics
| debugging kernel functions with gdb | 2 | 6706 | August 17, 2008 | |
| Debuging problems | 6 | 3142 | September 4, 2008 | |
| Debugging CUDA on VS2005 C++ express | 2 | 3454 | August 23, 2008 | |
| Nsight can not Debug into kernel | 1 | 689 | February 13, 2020 | |
| Debugging CUDA How to step into a kernel function | 5 | 16254 | June 4, 2021 | |
| How to debug when device emu no longer shows the bug? (and you dont have cuda-gdb capable hardware.. | 2 | 1946 | July 31, 2009 | |
| Debugger fails to enter kernel | 2 | 1415 | January 16, 2019 | |
| Debugging CUDA Kernel Sobel Filter Project from SDK | 8 | 23163 | October 15, 2010 | |
| problem with debugging kernel with VS2008 -- error 'missing source code' | 1 | 1049 | February 17, 2009 | |
| CUDA emudebug? How to enable in Visual Studio 2005? | 11 | 24805 | December 10, 2009 |
