**• Hardware Platform (Jetson / GPU) RTX2060laptop
**• DeepStream Version 6.1
• TensorRT Version
**• Issue Type( questions, new requirements, bugs)question
Currently i am using peoplenet as nvinfer(pgie), and the pipeline is based on deepstream-app.
The tracker model is original deepsort model and i am testing it with an rtsp ip camera.
One situation is when i am inside the images, the person id and face id can persist for a while, but when i covered my face for a second, the id of face changed and did not come back.
Another situation is when i walk out of the image and show up again, the face id and person id also changed.
So how to solve the problem? :0
For more detail, below is the config i used for deepstream-app to run.
you can easily reproduce the result if you have an ip camera.
source1_1080p_dec_infer-resnet_tracker_tiled_display.txt (4.4 KB)
config_tracker_DeepSORT.yml (5.0 KB)
