We are working on Deepstream 5.0.1-python. The code is running inside a container.
Source - RTSP stream
But the code is getting stuck with no errors or no logs after running sometimes for few hours and sometimes few minutes only. I am completely clueless about what’s happening.
• DeepStream Version
• TensorRT Version
• The pipeline being used
1.Can you update deepstream to the latest ?
Your driver version is 470, I guess you are using deepstream 6.0.1 ?
2. Which example did you use to reproduce this issue?
Can you share sample code for me reproduce this issue ?
3.when the application is stucked, the rtsp stream is ok ?
