Hi, i have encountered an out of memory issue while running the sample application on occupancy analytic provided by NVIDIA. The memory usage increases gradually until it becomes out of memory. The sample application (GitHub - NVIDIA-AI-IOT/deepstream-occupancy-analytics: This is a sample application for counting people entering/leaving in a building using NVIDIA Deepstream SDK, Transfer Learning Toolkit (TLT), and pre-trained models. This application can be used to build real-time occupancy analytics applications for smart buildings, hospitals, retail, etc. The application is based on deepstream-test5 sample application.) runs continuously for for hours without the message broker. But, when the msgbroker is enabled , the system runs out of memory. (within 30mins). Please provide guidance to solve this issue.
The following are the configurations used ;
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
#sync=0
#qos=0
msg-conv-config=dstest5_msgconv_sample_config.txt
msg-conv-payload-type=0
msg-broker-proto-lib=libnvds_kafka_proto.so
msg-broker-conn-str=localhost;9092;ds_app
msg-broker-config=cfg_kafka.txt
Please provide guidance as the issue occurs even with other brokers.
