**• Hardware Platform: 3060 in a laptop ** • NVIDIA GPU Driver Version: 515.65.07
Hello, I’m following a dgpu guide here:
I managed to install a working 515.65.07 driver from graphics-drivers repo
(I have no idea where to install 515.65.01 - i did found a .run file, but I got a recommendation to not use .run files earlier on these forums).
I have been successfully using driver 520 with Deepstream, but I’m just trying to setup a few machines that need to be on exact version, and - for max stability - exactly what the guide recommends.
My problem is that I cant install cuda from a local repo
I did download this: cuda-repo-debian11-11-7-local_11.7.1-515.65.01-1_amd64.deb
and if I follow the guide as is, it just drops my driver, installs 520 and cuda 11.8
if i specify “apt install cuda-11-7” - it still tries to drop my current driver and install 520, and also - re-download all the packages from the online repo.
How do I just install the packages from the .deb file?
You can use docker ( DeepStream | NVIDIA NGC) if you don’t want to change the driver. You need to follow the installation guide exactly in order to install DeepStream on your laptop.
