Deepstream 7 crashes after few seconds on Jetpack 6
I have an Orin AGX with Jetson 36.2 installed (BSPs from the vendor).
It came though without the entire Jetpack stack, so had to install it with apt-install.
I’m trying to run the AI-NVR use case from Metropolis. I was already able to run it on another AGX from another vendor with Jetson 36.3.
However, with this one ( 36.2), deepstream crashes after few seconds, and when I see my dmesg dump, I can see a lot of errors related to nvgpu:
[263902.173416] __ga10b__ 472-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173417] __ga10b__ channel status:  in use idle not busy
[263902.173419] __ga10b__ RAMFC: TOP: 000000000000 PUT: 0002018505e8 GET: 0002018505e8 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173420] __ga10b__
[263902.173421] __ga10b__ 473-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173422] __ga10b__ channel status:  in use idle not busy
[263902.173423] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201755844 GET: 000201755844 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 002004420000 payload 0000000000001384 execute 00000001
[263902.173424] __ga10b__
[263902.173425] __ga10b__ 474-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173426] __ga10b__ channel status:  in use idle not busy
[263902.173427] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201651afc GET: 000201651afc FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173428] __ga10b__
[263902.173429] __ga10b__ 475-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173430] __ga10b__ channel status:  in use idle not busy
[263902.173431] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201557014 GET: 000201557014 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 002004400000 payload 0000000000001386 execute 00000001
[263902.173433] __ga10b__
[263902.173434] __ga10b__ 476-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173434] __ga10b__ channel status:  in use idle not busy
[263902.173436] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201451dd8 GET: 000201451dd8 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 0020043f0000 payload 0000000000000fa2 execute 00000001
[263902.173437] __ga10b__
[263902.173438] __ga10b__ 477-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173439] __ga10b__ channel status:  in use idle not busy
[263902.173440] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201355634 GET: 000201355634 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 0020043e0000 payload 0000000000001386 execute 00000001
[263902.173441] __ga10b__
[263902.173442] __ga10b__ 478-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173443] __ga10b__ channel status:  in use idle not busy
[263902.173444] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201251fe4 GET: 000201251fe4 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173445] __ga10b__
[263902.173446] __ga10b__ 479-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173447] __ga10b__ channel status:  in use idle not busy
[263902.173448] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201157370 GET: 000201157370 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 0020043c0000 payload 0000000000001384 execute 00000001
[263902.173449] __ga10b__
[263902.173450] __ga10b__ 480-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173451] __ga10b__ channel status:  in use idle not busy
[263902.173452] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201051dd8 GET: 000201051dd8 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 0020043a0000 payload 0000000000000fa2 execute 00000001
[263902.173453] __ga10b__
[263902.173455] __ga10b__ 481-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173455] __ga10b__ channel status:  in use idle not busy
[263902.173457] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200f55570 GET: 000200f55570 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 002004390000 payload 0000000000001386 execute 00000001
[263902.173458] __ga10b__
[263902.173459] __ga10b__ 482-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173460] __ga10b__ channel status:  in use idle not busy
[263902.173461] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200e51fe4 GET: 000200e51fe4 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173462] __ga10b__
[263902.173463] __ga10b__ 483-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173464] __ga10b__ channel status:  in use idle not busy
[263902.173465] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200d574e4 GET: 000200d574e4 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 002004370000 payload 0000000000001385 execute 00000001
[263902.173466] __ga10b__
[263902.173467] __ga10b__ 484-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173468] __ga10b__ channel status:  in use idle not busy
[263902.173470] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200c51dd8 GET: 000200c51dd8 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 002004360000 payload 0000000000000fa3 execute 00000001
[263902.173471] __ga10b__ 485-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173472] __ga10b__ channel status:  in use idle not busy
[263902.173473] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200b57294 GET: 000200b57294 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 002004350000 payload 0000000000001387 execute 00000001
[263902.173474] __ga10b__
[263902.173475] __ga10b__ 486-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173476] __ga10b__ channel status:  in use idle not busy
[263902.173478] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200a51fe4 GET: 000200a51fe4 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173479] __ga10b__
[263902.173480] __ga10b__ 487-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173480] __ga10b__ channel status:  in use idle not busy
[263902.173482] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200955678 GET: 000200955678 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 002004330000 payload 0000000000001387 execute 00000001
[263902.173483] __ga10b__
[263902.173484] __ga10b__ 488-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173485] __ga10b__ channel status:  in use idle not busy
[263902.173486] __ga10b__ RAMFC: TOP: 000000000000 PUT: 0002008502c0 GET: 0002008502c0 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 002004310000 payload 0000000000000fa3 execute 00000001
[263902.173487] __ga10b__
[263902.173488] __ga10b__ 489-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173489] __ga10b__ channel status:  in use idle not busy
[263902.173490] __ga10b__ RAMFC: TOP: 000000000000 PUT: 0002007556bc GET: 0002007556bc FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 002004300000 payload 0000000000001389 execute 00000001
[263902.173491] __ga10b__
[263902.173492] __ga10b__ 490-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173493] __ga10b__ channel status:  in use idle not busy
[263902.173494] __ga10b__ RAMFC: TOP: 000000000000 PUT: 0002006502c0 GET: 0002006502c0 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 002004070000 payload 0000000000000fa4 execute 00000001
[263902.173495] __ga10b__
[263902.173496] __ga10b__ 491-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173497] __ga10b__ channel status:  in use idle not busy
[263902.173498] __ga10b__ RAMFC: TOP: 000000000000 PUT: 0002005356d4 GET: 0002005356d4 FETCH: 000000000000 HEADER: 2150006c COUNT: 00000000 SEMAPHORE: addr 002004060000 payload 0000000000001389 execute 00000001
[263902.173499] __ga10b__
[263902.173500] __ga10b__ 492-ga10b, TSG: 6, pid 2412555, thread name pool-deepstream, refs: 4, deterministic: yes, domain name: (no domain)
[263902.173502] __ga10b__ channel status:  in use on_pbdma, on_eng, pbdma_busy, eng_busy busy
[263902.173503] __ga10b__ RAMFC: TOP: 000000000000 PUT: 00020043039c GET: 00020043039c FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 00020063fdf0 payload 0000000000000056 execute 00001003
[263902.173504] __ga10b__
[263902.173506] __ga10b__ 493-ga10b, TSG: 5, pid 2368317, thread name gnome-shell, refs: 2, deterministic: no, domain name: (no domain)
[263902.173507] __ga10b__ channel status:  in use idle not busy
[263902.173508] __ga10b__ RAMFC: TOP: 8000002004008078 PUT: 002004008078 GET: 002004008078 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[263902.173509] __ga10b__
[263902.173510] __ga10b__ 494-ga10b, TSG: 4, pid 2368174, thread name Xorg, refs: 2, deterministic: no, domain name: (no domain)
[263902.173511] __ga10b__ channel status:  in use idle not busy
[263902.173513] __ga10b__ RAMFC: TOP: 8000002004033168 PUT: 002004033168 GET: 002004033168 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004320000 payload 0000000000000000 execute 00000001
[263902.173514] __ga10b__
[263902.173515] __ga10b__ 495-ga10b, TSG: 3, pid 2368174, thread name Xorg, refs: 2, deterministic: no, domain name: (no domain)
[263902.173516] __ga10b__ channel status:  in use idle not busy
[263902.173517] __ga10b__ RAMFC: TOP: 8000002004040f00 PUT: 002004040f00 GET: 002004040f00 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004020000 payload 0000000000000000 execute 00100001
[263902.173518] __ga10b__
[263902.173519] __ga10b__ 496-ga10b, TSG: 2, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173520] __ga10b__ channel status:  in use idle not busy
[263902.173522] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201350020 GET: 000201350020 FETCH: 000000000000 HEADER: 21540300 COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173523] __ga10b__
[263902.173524] __ga10b__ 497-ga10b, TSG: 2, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173524] __ga10b__ channel status:  in use idle not busy
[263902.173526] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201250020 GET: 000201250020 FETCH: 000000000000 HEADER: 21540300 COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173527] __ga10b__
[263902.173528] __ga10b__ 498-ga10b, TSG: 2, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173529] __ga10b__ channel status:  in use idle not busy
[263902.173530] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201150020 GET: 000201150020 FETCH: 000000000000 HEADER: 21540300 COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173531] __ga10b__
[263902.173532] __ga10b__ 499-ga10b, TSG: 2, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173533] __ga10b__ channel status:  in use idle not busy
[263902.173534] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000201050020 GET: 000201050020 FETCH: 000000000000 HEADER: 21540300 COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173535] __ga10b__
[263902.173536] __ga10b__ 500-ga10b, TSG: 1, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173537] __ga10b__ channel status:  in use idle not busy
[263902.173538] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200f50020 GET: 000200f50020 FETCH: 000000000000 HEADER: 21540300 COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173539] __ga10b__
[263902.173540] __ga10b__ 501-ga10b, TSG: 1, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173541] __ga10b__ channel status:  in use idle not busy
[263902.173542] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200e50020 GET: 000200e50020 FETCH: 000000000000 HEADER: 21540300 COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173543] __ga10b__
[263902.173544] __ga10b__ 502-ga10b, TSG: 1, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173545] __ga10b__ channel status:  in use idle not busy
[263902.173546] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200d50020 GET: 000200d50020 FETCH: 000000000000 HEADER: 21540300 COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173547] __ga10b__
[263902.173548] __ga10b__ 503-ga10b, TSG: 1, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173549] __ga10b__ channel status:  in use idle not busy
[263902.173550] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200c519a8 GET: 000200c519a8 FETCH: 000000000000 HEADER: 21540300 COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173551] __ga10b__
[263902.173552] __ga10b__ 504-ga10b, TSG: 0, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173553] __ga10b__ channel status:  in use idle not busy
[263902.173554] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200b50294 GET: 000200b50294 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173555] __ga10b__
[263902.173556] __ga10b__ 505-ga10b, TSG: 0, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173557] __ga10b__ channel status:  in use idle not busy
[263902.173559] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200a50294 GET: 000200a50294 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173560] __ga10b__
[263902.173561] __ga10b__ 506-ga10b, TSG: 0, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173562] __ga10b__ channel status:  in use idle not busy
[263902.173563] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200950294 GET: 000200950294 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173564] __ga10b__
[263902.173565] __ga10b__ 507-ga10b, TSG: 0, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173566] __ga10b__ channel status:  in use idle not busy
[263902.173567] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200850294 GET: 000200850294 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173568] __ga10b__
[263902.173569] __ga10b__ 508-ga10b, TSG: 0, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173570] __ga10b__ channel status:  in use idle not busy
[263902.173572] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200750294 GET: 000200750294 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173573] __ga10b__
[263902.173574] __ga10b__ 509-ga10b, TSG: 0, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173574] __ga10b__ channel status:  in use idle not busy
[263902.173576] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200650294 GET: 000200650294 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173577] __ga10b__
[263902.173578] __ga10b__ 510-ga10b, TSG: 0, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173578] __ga10b__ channel status:  in use idle not busy
[263902.173580] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200530294 GET: 000200530294 FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
[263902.173581] __ga10b__
[263902.173582] __ga10b__ 511-ga10b, TSG: 0, pid 38494, thread name nvargus-daemon, refs: 2, deterministic: yes, domain name: (no domain)
[263902.173583] __ga10b__ channel status:  in use idle not busy
[263902.173584] __ga10b__ RAMFC: TOP: 000000000000 PUT: 000200437b2c GET: 000200437b2c FETCH: 000000000000 HEADER: 21511b0c COUNT: 00000000 SEMAPHORE: addr 00020063ff70 payload 0000000000000054 execute 00001003
[263902.173585] __ga10b__
[263902.173587] __ga10b__ PBDMA Status - chip ga10b
[263902.173588] __ga10b__ -------------------------
[263902.173591] __ga10b__ pbdma 0:
[263902.173593] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[263902.173598] __ga10b__   PBDMA_PUT 0000002004008078 PBDMA_GET 0000002004008078
[263902.173602] __ga10b__   GP_PUT    0000000e  GP_GET  0000000e  FETCH   0000000e HEADER 2140006c
[263902.173607] __ga10b__   HDR       2001001b  SHADOW0 b51d8bc4  SHADOW1 863968dc
[263902.173608] __ga10b__ pbdma 1:
[263902.173609] __ga10b__   id: 6 - [tsg]     next_id: - -1 [channel] | status: valid
[263902.173614] __ga10b__   PBDMA_PUT 00000002004303e8 PBDMA_GET 00000002004303d0
[263902.173619] __ga10b__   GP_PUT    0000036d  GP_GET  0000036d  FETCH   0000036d HEADER 20111b00
[263902.173622] __ga10b__   HDR       200426c0  SHADOW0 0043039c  SHADOW1 00004e02
[263902.173624] __ga10b__ pbdma 2:
[263902.173625] __ga10b__   id: 10 - [tsg]     next_id: - -1 [channel] | status: valid
[263902.173630] __ga10b__   PBDMA_PUT 0000000200f50020 PBDMA_GET 0000000200f50020
[263902.173634] __ga10b__   GP_PUT    00000001  GP_GET  00000001  FETCH   00000001 HEADER 21540300
[263902.173638] __ga10b__   HDR       200180c0  SHADOW0 9a072818  SHADOW1 830d2472
[263902.173640] __ga10b__ pbdma 3:
[263902.173641] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[263902.173645] __ga10b__   PBDMA_PUT 0000009d4dc2d004 PBDMA_GET 000000eadc7415b8
[263902.173650] __ga10b__   GP_PUT    00000000  GP_GET  40ba12c4  FETCH   00000000 HEADER e10732d8
[263902.173654] __ga10b__   HDR       a9da1ce6  SHADOW0 48039e37  SHADOW1 d136000b
[263902.173655] __ga10b__ pbdma 4:
[263902.173657] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[263902.173661] __ga10b__   PBDMA_PUT 000000013a90f690 PBDMA_GET 0000003e26409d84
[263902.173713] __ga10b__   GP_PUT    00000000  GP_GET  274796b4  FETCH   00000000 HEADER 00128090
[263902.173718] __ga10b__   HDR       3455511b  SHADOW0 0a392028  SHADOW1 3ea36054
[263902.173721] __ga10b__ pbdma 5:
[263902.173722] __ga10b__   id: 11 - [tsg]     next_id: - -1 [channel] | status: valid
[263902.173727] __ga10b__   PBDMA_PUT 0000000201350020 PBDMA_GET 0000000201350020
[263902.173732] __ga10b__   GP_PUT    00000001  GP_GET  00000001  FETCH   00000001 HEADER 21540300
[263902.173735] __ga10b__   HDR       200180c0  SHADOW0 9fbda746  SHADOW1 15542009
[263902.173736] __ga10b__
[263902.173741] __ga10b__ ga10b eng 0:
[263902.173743] __ga10b__ id: 6 (tsg), next_id: -1 (channel), ctx status: valid
[263902.173744] __ga10b__ busy
[263902.173747] __ga10b__ ga10b eng 1:
[263902.173748] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[263902.173749] __ga10b__
[263902.173751] __ga10b__ ga10b eng 2:
[263902.173752] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[263902.173754] __ga10b__
[263902.173756] __ga10b__ ga10b eng 3:
[263902.173757] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[263902.173758] __ga10b__
[263902.173761] __ga10b__ ga10b eng 4:
[263902.173762] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[263902.173763] __ga10b__
[263902.173765] __ga10b__ ga10b eng 5:
[263902.173766] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[263902.173767] __ga10b__
[263902.272449] nvgpu: 17000000.gpu nvgpu_cic_mon_report_err_safety_services:60   [ERR]  Error reporting is not supported in this platform
[263902.272461] nvgpu: 17000000.gpu gv11b_mm_mmu_fault_handle_buf_valid_entry:532  [ERR]  page fault error: err_type = 0x8, fault_status = 0x200
[263902.272468] nvgpu: 17000000.gpu      gv11b_fb_mmu_fault_info_dump:294  [ERR]  [MMU FAULT] mmu engine id:  65, ch id:  492, fault addr: 0x282f7a000, fault addr aperture: 0, fault type: invalid pte, access type: virt read,
[263902.272473] nvgpu: 17000000.gpu      gv11b_fb_mmu_fault_info_dump:307  [ERR]  [MMU FAULT] protected mode: 0, client type: gpc, client id:  t1_6, gpc id if client type is gpc: 0,
[285064.306306] loop1: detected capacity change from 0 to 8
[288651.708559] loop1: detected capacity change from 0 to 8
[325661.099924] nvmap_alloc_handle: PID 2434468: deepstream-test: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
Any idea ? Can this be related to the Jetpack version, or really a hardware issue ?
Are there any other tests I can do ?
Please follow this guide to run AI NVR: Quick Start Guide — Metropolis on Jetson documentation 0.1.0 documentation
You need run AI NVR on Jetpack 6.0GA(r36.3).
