Deepstream 9.* licensing
• Hardware Platform (Jetson / GPU) ==> RTX PRO 6000 Blackwell
• DeepStream Version ==> 9.* (latest)
• TensorRT Version ==> NA
• NVIDIA GPU Driver Version (valid for GPU only) ==> 595.91.07
I plan to use the latest Deepstream SDK (v9.2) for building a commercial application. I checked the EULA licence and felt its pointing to version 6.0. So wanted to double confirm if this v9 version SDK can be used commercially. This includes using TensorRT/Triton plugins provided by Deepstream as well.
The EULA license is also for DeepStream 9.2. And the most source codes of DeepStream have been open sourced. The open source DeepStream license is DeepStream/LICENSE at main · NVIDIA/DeepStream
Thanks for the response. I will need to explain a bit more in detail.
Can we redistribute libnvbufsurface and libnvbufsurftransform from the
deepstream-binaries package inside a customer-facing container, alongside our own Apache-2.0-built plugins?
Are TensorRT and Triton covered by the same terms?
All DeepStream package needs binaries are in Releases · NVIDIA/DeepStream
