deepstream-custom
DeepStreamSDK 5
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 7.0.0.11
cuDNN Version: 7.6.5
NVIDIA GTX 960m
I want to integrate TLT-fasterrcnn-resnet50-model trained for ‘hand’ into deepstream sdk for inference
i get the .etlt file by using tlt-export command in docker.
I have built the TRT-OSS for the cropAndResizePlugin for frcnn to deploy into deepstream from deepstream-tlt-apps,
I can also run the sample for deepstream-custom.
but when i try to use my etlt file in the pgie_frcnn_tlt_config.txt for deepstream-custom i get the following error :
command : “deepstream-custom -c pgie_frcnn_tlt_config.txt -i …/…/streams/sample_720p.h264 -d”
Now playing: pgie_frcnn_tlt_config.txt
0:00:00.352753517 21517 0x563527917d80 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1591> [UID = 1]: Trying to create engine from model files
WARNING: …/nvdsinfer/nvdsinfer_model_builder.cpp:759 FP16 not supported by platform. Using FP32 mode.
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: Parameter check failed at: …/builder/Network.cpp::addInput::957, condition: isValidDims(dims, hasImplicitBatchDimension())
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: UFFParser: Failed to parseInput for node input_1
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: UffParser: Parser error: input_1: Failed to parse node - Invalid Tensor found at node input_1
parseModel: Failed to parse UFF model
ERROR: tlt/tlt_decode.cpp:274 failed to build network since parsing model errors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:797 Failed to create network using custom network creation function
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:862 Failed to get cuda engine from custom library API
0:00:00.982060040 21517 0x563527917d80 ERROR nvinfer gstnvinfer.cpp:596:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1611> [UID = 1]: build engine file failed
Segmentation fault
my config file is following : (pgie_frcnn_tlt_config.txt) :
[property]
gpu-id=0
net-scale-factor=1.0
offsets=103.939;116.779;123.68
model-color-format=1
labelfile-path=./nvdsinfer_customparser_frcnn_tlt/frcnn_labels.txt
#tlt-encoded-model=./models/frcnn/faster_rcnn_resnet10.etlt
tlt-encoded-model=./models/frcnn/frcnn_kitti_epoch8_fp16.etlt
#tlt-model-key=tlt
tlt-model-key=c2NuOGlxOGlxMmhvbW05aG85YjVmbW8xN2Y6N2ZmMzNhZjMtYjdmOS00ZDFmLTk5NGEtY2YyQ5
uff-input-dims=3;640;640;0
uff-input-blob-name=input_image
batch-size=10=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=2
interval=0
gie-unique-id=1
is-classifier=0
#network-type=0
output-blob-names=dense_regress_td/BiasAdd;dense_class_td/Softmax;proposal
parse-bbox-func-name=NvDsInferParseCustomFrcnnTLT
custom-lib-path=./nvdsinfer_customparser_frcnn_tlt/libnvds_infercustomparser_frcnn_tlt.so[class-attrs-all]
#pre-cluster-threshold=0.6
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
What I am missing or doing wrong??
do I need to do anything with the uff parser?
please give me a direction!
Thanks in advance
