Hi!
I have trained a YOLOv3 network with our own dataset with images. Now I will export the model to my Jetson Xavier.
I am using a Jetson Xavier with deep-stream 5-0. I am trying to run deepstream- app but i get follwing error. I’m following this guide(option 1)
https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/text/deploying_to_deepstream.html#integrating-the-model-to-deepstream
I dont reallt understand what file I should run,
config_fig_infer_primary.txt or source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx1.txt
When I run config_fig_infer_primary.txt i get following
** ERROR: main:655: Failed to set pipeline to PAUSED
Quitting
ERROR from src_bin_muxer: Output width not set
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmultistream/gstnvstreammux.c(2283): gst_nvstreammux_change_state (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstNvStreamMux:src_bin_muxer
App run failed
The config file I am trying to tun is following:
[property]
gpu-id=0
#net-scale-factor=0.0039215697906911373
net-scale-factor=1
#tlt-encoded-model=frcnn_kitti_resnet10_train_fp16.etlt
tlt-encoded-model=…/…/models/YOLO/yolo_resnet18_epoch_080.etlt
tlt-model-key=Z2o0aGRiaHNvcXFzNzViYWM0a3FuYW9vZzk6YWIxMDFhYmQtMDNhOS00OTYxLTg5YzMtODM4NzRmNmFlZTI0labelfile-path=…/…/models/YOLO/labels.txt
#batch-size=4
batch-size=1
process-mode=1
model-color-format=00=FP32, 1=INT8, 2=FP16 mode
#network-mode=1
network-mode=0
#num-detected-classes=4
#um-detected-classes=6
interval=0
gie-unique-id=1
#output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
output-blob-names=BatchedNMS
force-implicit-batch-dim=1
parse-bbox-func-name=NvDsInferParseCustomYOLOV3TLT
custom-lib-path=/home/jetson/deepstream_tlt_apps/nvdsinfer_customparser_yolov3_tlt0=Group Rectangles, 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
#cluster-mode=1
#scaling-filter=0
#scaling-compute-hw=0#Use these config params for group rectangles clustering mode
[class-attrs-all]
pre-cluster-threshold=0.2
group-threshold=1
eps=0.2
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0#Use the config params below for dbscan clustering mode
#[class-attrs-all]
#detected-min-w=4
#detected-min-h=4
#minBoxes=3Per class configurations
#[class-attrs-0]
#pre-cluster-threshold=0.05
#eps=0.7
#dbscan-min-score=0.95#[class-attrs-1]
#eps=0.7
#dbscan-min-score=0.5#[class-attrs-2]
#pre-cluster-threshold=0.1
#eps=0.6
#dbscan-min-score=0.95#[class-attrs-3]
#eps=0.7
When i run source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx1.txt i get follwoing error
** WARN: <parse_gie:1189>: Unknown key ‘tlt-encoded-model’ for group [primary-gie]
** WARN: <create_pipeline:1143>: Num of Tiles less than number of sources, readjusting to 8 rows, 1 columns
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
ERROR: Could not open lib: /home/jetson/deepstream_tlt_apps/nvdsinfer_customparser_yolov3_tlt, error string: /home/jetson/deepstream_tlt_apps/nvdsinfer_customparser_yolov3_tlt: cannot read file data: Is a directory
0:00:00.219964404 19013 0x19d20470 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1139> [UID = 1]: Could not open custom lib: (null)
0:00:00.220053177 19013 0x19d20470 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:00.220074587 19013 0x19d20470 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary_gie> error: Config file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primare_fastrcnn.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(809): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
the source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx1.txt is following:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://…/…/streams/Explorer_HD1080_SN21262960_14-57-18=LEFT.png
num-sources=8
#drop-frame-interval=2
gpu-id=0(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=5
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=8
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000Set muxer output width and height
width=1920
height=1080
#enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0If set to TRUE, system timestamp will be attached as ntp timestamp
If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
attach-sys-ts-as-ntp=1
config-file property is mandatory for any gie section.
Other properties are optional and if set will override the properties set in
the infer config file.
[primary-gie]
enable=1
gpu-id=0
#model-engine-file=…/…/models/Primary_Detector_Nano/resnet10.caffemodel_b8_gpu0_fp16.engine
tlt-encoded-model=…/…/models/fast-rcnn/frcnn_kitti_resnet10_train_fp16.etlt
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=4
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primare_fastrcnn.txt[tracker]
enable=1For the case of NvDCF tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_iou.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_nvdcf.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
#ll-config-file=tracker_config.yml
#ll-config-file=config_infer_primary.txt
gpu-id=0
#enable-batch-process and enable-past-frame applicable to DCF only
enable-batch-process=1
enable-past-frame=0
display-tracking-id=1[tests]
file-loop=0
