Deepstream FPS drops to 0 with no error
Jetson and GPU
• DeepStream Version
6.2
5.1
• TensorRT Version
8.5.2.2
525
Question
Deepstream FPS drops to 0 and the video sink gets stuck after processing the first 10 or so frames. The current model we use has a 99% GPU utilization rate on the Jetson device and less on a T4. I have noticed that the GPU usage abruptly falls to 0 once the FPS hits 0. And any print statements on the probe function which is connected to the source pad of the primary inference also stops printing. I am using a custom struct to pass information from the model by the same probe function mentioned above. And since there is no stacktrace available or error available, it has become impossible to monitor it. The nsys report generated is not opening in the nsights system either. Once I remove the probe function, it works properly. Attaching the function as below:
def sink_probe(pad, info, user_data):
    gst_buffer = info.get_buffer()
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    frame_list = batch_meta.frame_meta_list
    while frame_list is not None:
        try:
            frame_meta = pyds.NvDsFrameMeta.cast(frame_list.data)
        except StopIteration:
            continue
        frame_user_meta_list = frame_meta.frame_user_meta_list
        while frame_user_meta_list is not None:
            try:
                frame_user_meta = pyds.NvDsUserMeta.cast(frame_user_meta_list.data)
                continue
            meta_type = frame_user_meta.base_meta.meta_type
            if meta_type == pyds.NVDSINFER_TENSOR_OUTPUT_META:
                tensor_meta = pyds.NvDsInferTensorMeta.cast(frame_user_meta.user_meta_data)
                layer = pyds.get_nvds_LayerInfo(tensor_meta, 0)
                ptr = ctypes.cast(pyds.get_ptr(layer.buffer), ctypes.POINTER(ctypes.c_float))
                detections = np.ctypeslib.as_array(ptr, shape=(64512,6))
                nms_dets = nms(detections=detections, image_size=(512, 512)).flatten().tolist()
                data = pyds.alloc_rapid_struct(frame_user_meta)
                data.num_detections = len(nms_dets) // 5
                data.detections = nms_dets
                frame_user_meta.user_meta_data = data
                frame_user_meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_USER_META
            try:
                frame_user_meta_list = frame_user_meta_list.next
                break
        try:
            frame_list = frame_list.next
            break
    return Gst.PadProbeReturn.OK
Pybind11 for custom metadata
#include "bind_string_property_definitions.h"
#include "include/bindrapidmeta.hpp"
namespace py = pybind11;
namespace pydeepstream {
    void* copy_rapid_struct(void* data, void* user_meta) {
        NvDsUserMeta* source_meta = (NvDsUserMeta*) data;
        RapidOutputStruct* source_data = (RapidOutputStruct*) source_meta->user_meta_data;
        RapidOutputStruct* destination_data = (RapidOutputStruct*) g_malloc0(sizeof(RapidOutputStruct));
        int num_detections = source_data->num_detections;
        destination_data->num_detections = source_data->num_detections;
        if (num_detections > 0) {
            for (int i = 0; i < num_detections * 5; i++) {
                destination_data->detections.push_back(source_data->detections[i]);
        return destination_data;
    void release_rapid_struct(void* data, void* user_data) {
        if (source_meta != nullptr) {
            if (source_data != nullptr) {
                free(source_data);
    void bindrapid(py::module &m) {
        py::class_<RapidOutputStruct>(
            m, "RapidOutputStruct", pydsdoc::rapid::RapidStructDoc::descr)
        .def(py::init<>())
        .def_readwrite("num_detections", &RapidOutputStruct::num_detections)
        .def_readwrite("detections", &RapidOutputStruct::detections)
        .def(
            "cast", [](void* data) {
                return (RapidOutputStruct*) data;
            py::return_value_policy::reference,
            pydsdoc::rapid::RapidStructDoc::cast
        m.def(
            "alloc_rapid_struct",
            [](NvDsUserMeta *meta) {
                auto* mem = (RapidOutputStruct* ) g_malloc0(sizeof(RapidOutputStruct));
                meta->base_meta.copy_func = (NvDsMetaCopyFunc) pydeepstream::copy_rapid_struct;
                meta->base_meta.release_func = (NvDsMetaReleaseFunc) pydeepstream::release_rapid_struct;
                return mem;
            pydsdoc::methodsDoc::alloc_rapid_struct
So it’s got stuck when you are running? Is this your own demo code or modified on our basis? Could this issues be reproduced in our demo?
Yes, it’s says 0 Fps while running. Something like this:
0:00:05.842002678  8249      0x2f6e490 INFO                 nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<rapid-detector> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /home/ubuntu/video-analytics-v2/models/rapid.onnx_b1_gpu0_fp32.engine
0:00:05.850513395  8249      0x2f6e490 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<rapid-detector> [UID 1]: Load new model:configs/rapid.config.txt sucessfully
**PERF : FPS_0 (0.00)
This is my own code which I wrote referring the python custom binding example. I don’t think this can be reproduced because of the extra angle parameter in the model output.
[UPDATE]
So after a few trial and error, I found out that the issue is with the release_rapid_struct function. The RapidOutputStruct is the following:
struct RapidOutputStruct {
    int num_detections;
    vector<float> detections = vector<float>(500);
Am i doing anything wrong while freeing the memory? (Pardon, I don’t have a lot of experience with C++). The nvdslogger outputs 0 FPS when this line: meta->base_meta.release_func = (NvDsMetaReleaseFunc) pydeepstream::release_rapid_struct; is commented out.
We have already bound simailar API like: custom_binding. Could you use our API to bind your data structure?
This is the API that I’ve referred to while creating my codebase. Since, there is no strings inside the struct that I’m using, I’ve not copied the release function as it is. Instead, I’ve freed the entire struct itself.
Can you provide us with a simplified version of your demo? We can try to run in our environment.
